Angular Motion Question Understanding help ?
In summary, this conversation discussed the concept of angular velocity and acceleration in relation to a figure skater completing a double axle. The calculated values for angular velocity and average angular velocity were found to be 1440 deg/s and 23.132 rad/s, respectively. The calculation for angular acceleration resulted in a value of 960 rad/s^2, with the understanding that when the skater comes to rest, the acceleration would be negative. The correct formula for calculating average angular velocity is using the total angular displacement over the total time, while the formula for calculating angular acceleration is the change in angular velocity over the change in time.
uaeXuae
54
A figure skater completes a double axle (2 complete rotations) in 0.5 seconds. Calculate
the skater’s angular velocity and average angular velocity in a) deg/sec, and b) rad/sec.
If the skater manages to stop spinning in a time of 1.5 seconds,
what was the angular acceleration and average angular acceleration during this period (in deg/s)?
Average Angular Velocity => w=(Theta2-Theta1)/(t2-t1)
Angular Velocity = theta/time
Average Angular Acceleration => Alfa = (w2-w1)/(t2-t1)
Angular Acceleration => Alfa = (w)/(t)
wf=wi + alfa*(t)
Angular Velocity => w=(360*2)/0.5 = 1440 deg/s
1440 * (pi/180) = 23.132 rad/s
Average Angular Velocity => w=(360-360)/0.5 = 0 rad/s
Angular Acceleration => Alfa = 1440/1.5 = 960 rad/s^2
Average Angular Acceleration => Alfa = (w2-w1)/(t2-t1)= (0-1440)/1.5 = -960rad/s^2
wf=wi + alfa*(t) = > alfa = (wf-wi)/t ==> alfa = (0-1440)/1.5 = -960 rad/s^2
im almost sure about my results in the (Angular Velocity and Average Angular Velocity ) but for the (Angular Acceleration and Average Angular Acceleration i am not )
could someone correct my answers and explain the changes that has been made.
Thanx in Advance.
One is correct. One revolution is 360° or 2[itex]\pi[/itex] radians, and one correctly used the relationship [itex]\pi[/itex]/180 rad/deg.
Thanx but can anyone explain what is the correct angular acceleration (+960 or -960)and why ? and what is the difference in the pronouncings Average angular acceleration and angular acceleration hence
average speed = total distance / time.
average velocity = displacement / time.
<up>
Average velocity or acceleration is calculated if they are not uniform. In your problem there is no indication of that.
What do u mean not uniform ? and what is the indication or the thing that will make me know wheather its uniform or not ?
http://img516.imageshack.us/img516/3300/1234rr6.jpg
i still don't know how the second part is solved. Can someone clarify things to me ?
Average Angular Velocity => w=(Theta2-Theta1)/(t2-t1)This is not true.
average angular velocity = total angular displacement / total time.
ok
applying the law
average angular velocity = 1440/ 1.5 = 960
how is it -960 ?
and what would that
angular velocity be equal to in this case ?!
1440 * (pi/180) = 23.132 rad/s. = Average angular velocity
When the body comes to rest the acceleration cannot be positive.
uaeXuae said:
ok
applying the law
how is it -960 ?
As one worked out initially - Average Angular Acceleration => Alfa = (w2-w1)/(t2-t1)= (0-1440)/1.5 = -960rad/s^2
The skater starts with an initial angular velocity wi at ti, and then decelerates to wf at tf.
The change in angular velocity is wf-wi and the change in time is tf-ti, and the angular acceleration is alfa = (wf-wi)/(tf-ti). If the body comes to rest, wf=0, to alfa = -wi/(tf-ti), and since tf > ti, the difference is positive, to the angular acceleration is negative.
w=(Theta2-Theta1)/(t2-t1) is correct, but one must be careful that Theta2 and Theta1 represent cumulative angular displacements from the same reference angle, and not just the angular displacement on a circle, i.e. Theta2 and Theta1 could > 360° or 2pi rad. In the given expression Theta2-Theta1 is the total angular displacement occurring between t2 and t1.
thanx for your help but sorry for insisting ...
Understood
Thats just the same its converting from degree to radian( so converting from degree to radian is average angular velocity
Not sure about that.
Understood.
Once again why was the average angular velocity = 0 but there was a valus for the angular velocity. Not only that but what law should be used when calculating
Angular Acceleration & average Angular Acceleration.
FAQ: Angular Motion Question Understanding help ?
What is angular motion?
Angular motion is the movement of an object or body along a circular path or rotation about an axis. It is a type of motion that involves both linear and rotational components.
What is the difference between linear and angular motion?
Linear motion is the movement of an object in a straight line, while angular motion is the movement of an object along a circular path or rotation around an axis. Linear motion is also known as translational motion, while angular motion is also referred to as rotational motion.
How is angular motion measured?
Angular motion is measured in units of degrees (°) or radians (rad). Degrees are commonly used for larger angles, while radians are used for smaller angles. The unit of measurement depends on the context and application of the angular motion.
What is the relationship between angular motion and angular velocity?
Angular motion and angular velocity are closely related concepts. Angular motion refers to the movement of an object along a circular path or rotation, while angular velocity refers to the rate at which that movement occurs. In other words, angular velocity measures the change in angular motion over time.
How is angular motion used in real life?
Angular motion has many practical applications in everyday life. It is used in the design and operation of machines, such as engines and turbines, as well as in sports, such as figure skating and gymnastics. It is also essential in understanding celestial motion, such as the orbit of planets and satellites.
