Angular Speed Between 2 rims attached by a belt
In summary, a user on Physics Forums is seeking help with a problem involving two wheels, A and C, connected by a belt. The angular speed of wheel A is being increased at a constant rate, and the user is trying to find the time it takes for wheel C to reach a certain angular speed. They attempted to use a ratio method but were unsuccessful. Another user on the forum suggests using the equation for acceleration to find the time needed.
dimmermanj
So I'm new to the Physics Forums and am looking for some help on this problem:
Wheel A of radius r=10cm is coupled by belt B to wheel C with radius R=25cm.
the angular speed of wheel A is increased from rest at a constant rate of 1.6 rad/s^2.
Find the time needed for wheel C to reach an angular speed of 100 rev/min, assuming the belt does not slip (hint: the linear speeds of the two rims must be equal)
my original process of solving was to try and relate the two speeds with a ratio, but that method has proven unsuccessful.
I get really confused whenever dealing with angular speed so if anyone could help that'd be great!
thanks
Jim
Ok using your method if
[tex]\frac{\omega_B}{\omega_C} = \frac{R_C}{R_B}[/tex]
when ωC is 100 rpm what is ωB ?
Then you know that
[tex]\alpha = \frac{\omega_2 - \omega_1}{t}[/tex]
FAQ: Angular Speed Between 2 rims attached by a belt
What is the formula for calculating angular speed between two rims attached by a belt?
The formula for calculating angular speed between two rims attached by a belt is given by:
Angular Speed = (V/R), where V is the linear speed of the belt and R is the radius of the rim.
How is angular speed different from linear speed?
Angular speed is the rate at which an object rotates around an axis, while linear speed is the rate at which an object moves in a straight line. In the case of two rims attached by a belt, angular speed refers to how fast the rims are rotating around their axes, while linear speed refers to how fast the belt is moving in a straight line.
What factors affect the angular speed between two rims attached by a belt?
The angular speed between two rims attached by a belt is affected by the linear speed of the belt, the radius of the rims, and the friction between the rims and the belt. If the linear speed of the belt increases, the angular speed will also increase. Similarly, a larger radius of the rims will result in a lower angular speed.
Can the angular speed between two rims attached by a belt be negative?
No, the angular speed between two rims attached by a belt cannot be negative. Since angular speed is a measure of how fast an object is rotating, it is always a positive value. A negative value would indicate that the rims are rotating in the opposite direction, which is not possible in this scenario.
How does the direction of the belt affect the angular speed between two rims attached by a belt?
The direction of the belt does not affect the angular speed between two rims attached by a belt. The angular speed is dependent on the linear speed of the belt and the radius of the rims, both of which remain the same regardless of the direction of the belt. However, the direction of the belt may affect the direction of rotation of the rims.
