Angular velocity of a cylinder
In summary, James50 tried to solve a problem involving rotating bodies by using work energy equations, but found that he couldn't remember how to do it. He eventually figured it out thanks to a forum search.
James50
I've got a synoptic paper coming up and for the life in me I can't remember how to do some basic dynamics!
A massless rope is wrapped several times around a solid cylinder of radius R = 20 cm, and mass M = 20 kg, which is at rest on a horizontal surface. Someone pulls 1 m or the rope with a constant force of 100 N, setting the cylinder in motion. Assuming that the rope neither stretches nor slips, and that the cylinder rolls without slipping, what is the final angular velocity of the cylinder of mass M and radius R. The moment of inertia of the cylinder is MR2/2.
T = F.R
L = Iw
T = dL/dt
T is torque, F force, R radius, I moment of inertia, W angular speed, L angular momentum, Y is the angle
Torque is 100x0.2 = 20 Nm. Moment of inertia is 0.4 kg m2. Now rearranging torque as a function of angular momentum, you get T = I dw/dt.
Some chain rule... dw/dt = w dw/dY. A little bit of integrating... 0.5 w2 = (T/I)Y -> using Y=0 as the lower boundary.
Okay, now because 1m is pulled from the rope, and the circumference of the cylinder is 1.256m, it works out that the sphere has rotated by 5 rads. Put that, along with T=20 and I=0.4 into the above equation, you come out with 22.36 rad /s. The actual answer is 18.4 rad /s. Ugh!
Welcome to PF!
Hi James50! Welcome to PF! :smile:
(have a theta: θ and an omega: ω :wink:)
eek!
You clearly need to do a lot of worked examples on rolling motion. :redface:
(btw, what's a synoptic paper? :confused:)
With rolling, you need two types of equation, one for rotational motion and one for linear motion …
you also need a rolling constraint (usually v = rω).
And in this case, since you're given distance (instead of time), mightn't a work energy equation save you … erm … both work and energy? :wink:
Thanks! I saw some symbols hanging around in the latex reference things but then it messed up all my paragraphing!
You're telling me! Nuclear physics and baryon decuplets I can do... But rotating bodies!
A synoptic paper is a general one, it lasts for something like 4 hours and has questions on all the modules in my degree (I've done over 30, ugh!)
I can't believe I didn't think of doing it that way. Got the right answer straight away, thanks! Although I still can't figure out the normal way of getting there!
hmm … I think I'd call that panoptic :wink:
Do F = ma and τ = Iω.
Do a forum search for "rolling" to find some other examples to work through. :smile:
I understand your frustration with forgetting concepts and equations. However, it seems like you have a good understanding of the problem and have approached it correctly. One possible explanation for the discrepancy between your calculated answer and the actual answer could be rounding errors or slight differences in the values used for R and M. I would suggest double-checking your calculations and using more precise values for R and M to see if that makes a difference. If not, it could also be helpful to review the equations and make sure you are using them correctly. Good luck on your synoptic paper!
Related to Angular velocity of a cylinder
1. What is angular velocity?
Angular velocity is a measure of how fast an object is rotating around a fixed point or axis. It is usually represented by the Greek letter omega (ω) and is measured in radians per second.
2. How is angular velocity calculated?
Angular velocity is calculated by dividing the change in angle (in radians) by the change in time. The formula for angular velocity is ω = Δθ/Δt, where ω is angular velocity, Δθ is the change in angle, and Δt is the change in time.
3. What is the unit of measurement for angular velocity?
Angular velocity is measured in radians per second (rad/s). However, it can also be measured in revolutions per minute (RPM) or degrees per second (°/s).
4. Does the radius of a cylinder affect its angular velocity?
Yes, the radius of a cylinder does affect its angular velocity. The larger the radius, the greater the distance from the axis of rotation, and therefore the greater the angular velocity.
5. How does friction affect the angular velocity of a cylinder?
Friction can affect the angular velocity of a cylinder by slowing it down. This is because friction creates resistance against the motion of the cylinder, causing it to lose some of its rotational speed.
9K
