Angular velocity of a door as a truck accelerates
In summary, the conversation is discussing a physics problem involving a door attached to a moving truck and the forces and torques acting on it. The participants consider different approaches, including considering an equivalent scenario with a fixed axis and acceleration due to gravity, and using symmetry to find a solution. They also mention the importance of understanding forces and torque in order to solve the problem.
Pushoam
962
52
Let's consider a cylindrical coordinate system whose z-axis coincides with the hinge and origin is the lowest point of the hinge.
Let's say that the truck moves along the x-axis.
W.r.t. this frame,
Torque about the hinge ## \vec \tau = \vec r \times \vec F_{n-in}
\\= [\frac w 2 \hat s + \frac h 2 \hat s ] \times [ mg (-\hat z )+m A (-\hat x)]
\\\hat x = \cos \phi \hat s+ \sin \phi \hat \phi
\\\vec \tau = \frac m 2 [ \{ wg - h \cos \phi \} \hat \phi - \hat z~w \sin \phi + h \sin \phi \hat s ]##
The body can rotate only about the hinge, so the torque should be only about the ##\hat z ## direction. I can take the component of the torque in the ##\hat \phi ## to be 0 as there is both negative and positive terms but how to make the component of the torque in the ##\hat s ## zero?
First of all: You have written ##\vec r = (w \hat s + h \hat s)/2##. This does not seem correct, the width and the height are in different directions.
Second: Which point are you computing the torque relative to? Is the inertial force the only force on the door that gives a torque relative to this point? If not: What other forces are there and how will they cancel the torque in the ##\hat s## direction?
Third: You do not need to compute the torque. There is a much more efficient way to solve this problem if you think a bit about it.
Suppose the door were attached to a fixed horizontal axis (instead of the moving vertical axis).
And suppose that the acceleration due to gravity were A (instead of g).
Does that suggest a method of solution?
I think that Einstein postulated that a person in an isolated enclosure had no way of knowing
whether any experienced force would be due to an acceleration of the enclosure or due
to gravitational attraction by a massive object.
Likes kuruman, Pushoam, TSny and 1 other person
GREAT! :bow::bow::bow:
Likes Pushoam
What I understood is:
Let's keep the gate in the x-y plane such that it is free to rotate about x-axis. Its length along x-axis is h and y-axis is w.
Under the effect of gravity, it will rotate towards the earth. I have to calculate its angular velocity when it is in the x -z plane.
Now the center of mass motion is motion of the simple pendulum with length w/2.
So, the angular velocity is equal to the angular frequency : ##\omega = \sqrt (\frac {2g}{w/2})##
Is this correct?
Orodruin said:
You have written ⃗r=(w^s+h^s)/2r→=(ws^+hs^)/2\vec r = (w \hat s + h \hat s)/2. This does not seem correct, the width and the height are in different directions.
It's ##\hat z##.
Orodruin said:
Which point are you computing the torque relative to? Is the inertial force the only force on the door that gives a torque relative to this point? If not: What other forces are there and how will they cancel the torque in the ^ss^\hat s direction?
I was calculating about the origin of the hinge.
The other forces acting are friction forces, normal forces. There must be a component of contact force in the ##\hat x ## direction because of which the gate remains attached to the car. The torque due to this component of the force will cancel the torque( earlier calculated) in ##\hat s ## direction.
But since I don't have the detail knowledge of these forces, I can't use torque analysis.
Is the other way already pointed out by J Hann?
Pushoam said:
So, the angular velocity is equal to the angular frequency : ω=√(2gw/2)ω=(2gw/2)\omega = \sqrt (\frac {2g}{w/2})
Is this correct?
No. First of all, the moment of inertia for a rod is not the same as the moment of inertia for a mass placed at its centre. Second, the motion is harmonic only for small deviations from the equilibrium point.
You can pick a different origin around which the components that are not in the ##z## direction cancel by symmetry.
That is part of it. You need to figure out how you can use this to solve the problem.
So, the angular velocity is equal to the angular frequency : ω=(2gw/2)'>ω=√(2gw/2)ω=(2gw/2) \omega = \sqrt (\frac {2g}{w/2})
Is this correct?
The door is not a simple pendulum but can be considered a compound pendulum.
Also, the basic pendulum equations only pertain to small displacements ( sin theta = theta).
Likes Pushoam
To elaborate on post #3 by @J Hann: Imagine being the truck driver. You are at rest with respect to the truck and so is the door hinge. As the truck accelerates, you are pinned to the back of your seat. You interpret this as an additional horizontal "gravitational" acceleration A. This acceleration A also acts at the center of mass of the door (see figure below). Thus, the situation is equivalent to one in which the truck is hanging vertically at rest, the door is open horizontally and the acceleration of gravity is A instead of g.
Likes Pushoam
The motion of the gate can be taken as pure rotation about x - axis.
Applying work kinetic energy theorem,
Work done by the torque = change in its rotational kinetic energy
## Mgw/2 = I \omega^2 /2
\\ \omega = \sqrt { \frac { Mgw}{I} }##
I about x-axis = ## \frac {Mw^2 } 3##
##\\ \omega = \sqrt { \frac { 3g}{w} }##
Is this correct?
Here g = A.
That is correct.
Likes Pushoam
In part b, is the horizontal force (being asked ) that component of contact force which keeps the door together with the truck? If this is so, then the horizontal force is in the direction of acceleration.
Or is it the force exerted by the truck on the door when the door is shut? Then it will be perpendicular to the acc. of the truck.
They are asking for the force from the truck on the door when it has swung 90 degrees. This would mean the door is pointing in the "back" direction. I suggest you again analyse the problem in the accelerated frame.
I solved it.
Thanks for the guidance.
Is this correct?
Here g = A.
Are you sure you want to use torque?
The force producing the torque is only perpendicular to the door when the door is wide open.
Also, is there not a change in the potential energy since it would take work to open the door
while the truck is accelerating?
Although, I agree with the answer you obtained.
He has taken this into account. The potential energy is on the left-hand side.
He never used the torque itself, although that is possible, but only its potential energy.
Another attempt to solve part (a)
wrt accelerated frame,
Considering COM motion,
Applying work - kinetic energy theorem,
##MAw/2 = ½ Mv^2 = ½M {\omega}^2 (w/2)^2
\\ \omega = \sqrt {(2A/w) }##
What is wrong here?
The kinetic energy ##\frac{1}{2}Mv^2## due to motion of the COM is only part of the total kinetic energy. There is additional kinetic energy due to rotation about the COM. The total of these two contributions should equal the kinetic energy you calculated in post #9 (edited) as rotational kinetic energy about the hinges (x axis).
TSny said:
The kinetic energy 12Mv2\frac{1}{2}Mv^2 due to motion of the COM is only part of the total kinetic energy. There is additional kinetic energy due to rotation about the COM. The total of these two contributions should equal the kinetic energy you calculated in post #14 as rotational kinetic energy about the hinges (x axis).
Or you can use ## \frac{1}{2}I_h\omega^2## for the kinetic energy, where ##I_h## is the moment of inertia about the hinge. Either way should give the same answer.
He already did that in post #9.
Related to Angular velocity of a door as a truck accelerates
1. What is angular velocity?
Angular velocity is a measure of the rotational speed of an object around a fixed axis. It is typically measured in radians per second or degrees per second.
2. How is angular velocity different from linear velocity?
Angular velocity refers to the rotation of an object around a fixed axis, while linear velocity refers to the movement of an object in a straight line. Angular velocity is typically measured in radians per second while linear velocity is measured in meters per second.
3. How does a truck's acceleration affect the angular velocity of a door?
As a truck accelerates, the door attached to its side will experience a change in angular velocity. This is because the door is rotating around the axis of the truck's hinge, and the acceleration of the truck will cause the door to rotate faster or slower depending on the direction of the acceleration.
4. Is angular velocity affected by the mass of the door?
Yes, the mass of the door can affect its angular velocity. Objects with larger masses typically have a larger moment of inertia, which is a measure of an object's resistance to changes in its rotational motion. This means that a door with a larger mass will require more torque to rotate at a certain angular velocity compared to a door with a smaller mass.
5. How can the angular velocity of a door be calculated?
The angular velocity of a door can be calculated by dividing the change in angular displacement by the change in time. In other words, it is the rate at which the door is rotating around its fixed axis. It can also be calculated using the equation: angular velocity = (2π x frequency) or (2π x revolutions per second).
