Angular Velocity of Analog Watch
In summary, the angular velocity of the second hand is 0.1047 rad/s or 6 deg/s, the minute hand is 0.001745 rad/s or 0.1 deg/s, and the hour hand is 1.20 x 10-4 rad/s or 0.0069 deg/s. The time for one revolution of the hour hand is 12 hours and the conversion from radians to degrees is done by multiplying the angle in radians by 180 degrees and dividing by pi. The final values for the hour hand were incorrect due to incorrect conversions and the correct value is 1.20 x 10-4 rad/s or 0.0069 deg/s.
eoneil
Calculate the angular velocity of the second, minute, and hour hand of a watch.
Assuming the watch is functioning normally, a second hand must travel the entire 360 degrees in 60 second. The formula ω= ɵ/t would be used, where ω is angular velocity (rad/s), theta is the angular displacement, and t is time (s). One revolution of the second hand is equal to 2π radians, or 2π/60s, so knowing this, we can apply onward. 1 radian= approx. 57 degrees.
a) Va Second Hand= 2π/60s= 0.10471 rad/s= 6 deg/s
b) Va Minute Hand= 2π/3600s = 0.0017453 rad/s= 0.1 deg/s
c) Va Hour Hand= (2π /3600s)(60s)= 2.908 × 10-5 rad/s= 1.67 x 10-3 deg/s
Are the conversions and final values correct?
(2π /3600s)(60s)means multiplying (2π /3600s) by 60 s. It is displacement, not velocity. How much time is one revolution of the hour hand?
ehild
One revolution of the hour hand is 12hrs.
a) Va Second Hand= 2π/60s= 0.1047 rad/s= 6 deg/s
b) Va Minute Hand= 2π/3600s = 0.001745 rad/s= 0.1 deg/s
c) Va Hour Hand= 2π /12(60s)(60s)= 1.45 x 10-4 rad/s= 8.33 x 10-3 deg/s
Its not (60s)(60s), its just (60)(60)s
By what way you wrote, answer would be in rad/s2
And for rad degree conversion, use: pi rad = 180 degree
Ok, got it, (60)(60)s, giving rad/s^2. The converting angle to degrees = angle in radians x 180 / Pi
So for the hour hand, 2π /12(60)(60)s= 1.45 x 10-4 rad/s2= sqrt 1.45 x 10-4 rad/s2
final value is 1.20 x 10-4 rad/s, or 0.0069 deg/s
Related to Angular Velocity of Analog Watch
1. What is angular velocity?
Angular velocity refers to the rate at which an object rotates or travels around a fixed point. It is typically measured in radians per second.
2. How is angular velocity related to analog watches?
Analog watches use hands to display the time, and these hands rotate around a fixed point (the center of the watch) at a constant angular velocity. The angular velocity of the hands determines how fast they move, and therefore, how quickly time is displayed.
3. How is angular velocity calculated for an analog watch?
The angular velocity of an analog watch is calculated by dividing the angle traveled by the watch hands by the time it takes to travel that angle. It can also be calculated by dividing the number of revolutions made by the watch hands by the time it takes to make those revolutions.
4. Does the angular velocity of an analog watch change?
No, the angular velocity of an analog watch remains constant as long as the watch is functioning properly. The hands will continue to rotate at the same speed, regardless of the time displayed or the position of the hands.
5. How is angular velocity different from linear velocity?
Angular velocity refers to rotational motion, while linear velocity refers to straight-line motion. Angular velocity is measured in radians per second, while linear velocity is measured in meters per second. Additionally, angular velocity considers the angle traveled, while linear velocity considers the distance traveled.
