Angular velocity, torque and work
In summary, the conversation discusses a setup with two supports, each turning clockwise at a constant angular velocity of w, and two pulleys, one on each support. Pulley 1, with a radius of 3R, can turn around an axis fixed on Support1, while Pulley2, with a radius of R, can turn around an axis fixed on Support2. The two pulleys are connected by a belt. Pulley1 is driven by a motor fixed on Support1 and turns at 2w clockwise in the lab reference, while Pulley2 acts as a brake and turns at 4w clockwise in the lab reference. The conversation then goes on to discuss various calculations, such as the work of the brake,
  • #36
Maybe it's that I don't understand. 2 pulleys are connected with the belt. If I want to turn the big pulley (with a small mass), I need to give a torque, what torque I need to give ? For me, it's not 0, because when I turn the big pulley, the belt move and want to turn the small pulley, if the small pulley has a mass, a force appear on the belt, this force will give F5 to the big pulley, no ? For me it's logical, in the contrary I can turn something without an energy.
  • #37
The pulley is only an intermediary. There is no net torque on the pulley. The torque exerted by the motor should be exactly canceled by the other forces acting on the pulley. With the magnitudes you claim, that won't happen.
  • #38
I'm agree. No net torque on the big pulley.
For me 6*R*F1 = 3*R*F5 so there is no torque on the big pulley. In my last image F1=0.5*F5
I said ok but for me forces are :
|2F1|= |2F2|= |2F3|= |2F4|= |F6|= |F7|= |F8|= |F9| = |F5|, it's possible, no ?
  • #39
V711 said:
I'm agree. No net torque on the big pulley.For me 6*R*F1 = 3*R*F5 so there is no torque on the big pulley. In my last image F1=0.5*F5
Yes, that all looks ok now.
  • #40
ok, great ! I would like to know if the forces F6/F8 gives a torque to the support ?
  • #41
Yes, I said so in post #25.
  • #42
ok, and at a time, the motor needs the energy -3FRwt (the motor turn at 2w but it is on a support that turn at w), the support receives -3FRwt (from F3/F4). The small pulley receives +6FRwt and the support receives +2FRwt, the sum is not at 0 so I suppose the small pulley don't receive 6FRwt but 4FRwt, no ?
  • #43
Let's look at all the torques.
Suppose the motor exerts torque T. I'll not bother with signs, just magnitudes.
Motor:large pulley = T
Axle+belt:large pulley = F7*3R
Motor : support = T
Two axles : support = F6*2R
Support : small pulley = brake torque (B)
Belt+axle : small pulley = F7*R.
What equations do those give you?
  • #44
Like I drawn my forces in my last image, I supposed the small pulley is not brake, the small pulley has a mass and it is accelerate more and more.
Motor : support = T
I'm agree with that.
Sorry, I don't understand your question.
  • #45
Ah, yes. But that means there's an unbalanced torque on the support, so that will accelerate the other way. And nothing will make sense unless you assign a moment of inertia to it.
  • #46
Ok, I understood. So with a brake on the small pulley, the support don't receive a torque, correct ?
With a brake, the friction gives the energy 5FRwt (at a time) ?
  • #47
It depends where the brake is mounted. I would imagine it would be mounted on the support, so the torque of the brake would be transferred to the suppor. If the pulleys are not accelerating then there should be no net torque on the support. Alternatively, the brake may be mounted on something outside entirely.
  • #48
yes, and like the angular velocity of the small pulley is 6w, on the support that angular velocity is 6w-w=5w, correct ? So I thought the work from friction is 5FRwt.
  • #49
If I resume:
The support turns at +w (clockwise)
The stator of the motor is fixed on the support so it turns at +w
The rotor turns at +w relatively to the stator, so it turns at +2w in the lab ref
The small pulley turns at +6w (lab ref) so it turns at 5w in the support ref, the small pulley is braking on the support at the radius R
The motor consume the power -3FRw
The brake (small pulley) gives the power +6FRw
So if the support don't receive any torque, this could say the power from brake is lower, could you explain please ?
