I Angular Velocity: Vector or Not?
Angular velocity is classified as an axial vector, which behaves differently from traditional vectors under transformations, particularly during reflections. In three dimensions, it is considered a pseudovector, possessing both magnitude and direction, but remaining unchanged when the coordinate system is mirrored. The cross product of two polar vectors results in a pseudovector, while the cross product of a pseudovector and a polar vector yields a vector. This distinction is crucial for understanding the relationship between angular velocity and tangential velocity, especially when considering the cross product with the radius vector. Overall, the discussion clarifies the mathematical properties of angular velocity and its implications in vector calculus.
e2m2a
I understand that angular velocity is technically not a vector so does that mean the cross product of the radius vector and the angular velocity vector, the tangential vector, is also not a vector?
Angular velocity is an axial vector, i.e., it transforms as ##\vec{\omega} \rightarrow \vec{\omega}## under space reflections, while a polar vector like the usual velocity transforms as ##\vec{v} \rightarrow -\vec{v}##. Wrt. rotations axial vectors transform in the same as polar vectors.
An axial vector is always equivalent to an antisymmetric tensor. For Cartesian components you can map the axial-vector components to the tensor components via
$$\Omega_{jk}=\epsilon_{jkl} \omega_l$$
and the other way
$$\omega_l=\frac{1}{2} \epsilon_{jkl} \Omega_{jk}.$$
In both formulae the Einstein summation convention is used, and ##\epsilon_{jkl}## is the Levi-Civita symbol which is defined by ##\epsilon_{123}=1## and being antisymmetric under exchange of any index pair. This implies that it's 0 if at least two of the indices are equal.
It's also easy to see that the cross product of two polar or two axial vectors is an axial vector, while the cross product of a polar and axial vector is a polar vector.
e2m2a said:
I am told that angular velocity is not a vector so does that mean the cross product between the radius vector and angular velocity vector, the tangential velocity vector, is also not a vector?
If you are working in the two dimensional plane then angular velocity has only one dimension. It is a scalar.
If you are working in three dimensions then angular velocity is a pseudovector. It has magnitude and direction, but if you do a mirror reflection on your coordinate system so that all of your vectors change signs, the pseudovectors remain unchanged. So picky mathematical types do not want to call them vectors.
Taking the cross product of the angular momentum [pseudo]vector and the radius vector will do just fine to get you a velocity vector.
Likes vanhees71 and berkeman
In three dimensions, the cross product of two (polar) vectors gives a pseudovector. The cross product of a pseudovector and a vector gives a vector. The cross product of two pseudovectors gives a pseudovector.
Likes vanhees71 and jbriggs444
Ok. Thanks for the explanation.
All right. Thanks. That clears things up.
Thread ''splain this hydrostatic paradox in tiny words'
This is (ostensibly) not a trick shot or video*. The scale was balanced before any blue water was added. 550mL of blue water was added to the left side. only 60mL of water needed to be added to the right side to re-balance the scale. Apparently, the scale will balance when the height of the two columns is equal. The left side of the scale only feels the weight of the column above the lower "tail" of the funnel (i.e. 60mL). So where does the weight of the remaining (550-60=) 490mL go...
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
