MHB Anh Nguyen's questions regarding indefinite integrals (integration by parts)
The discussion focuses on solving three specific indefinite integrals using integration by parts and trigonometric identities. The first integral, -6e^(2t)sin(t)cos(t), is simplified using a double-angle identity, leading to the result of (3/4)e^(2t)(cos(2t) - sin(2t)) + C. The second integral, 5e^(2t)sin^2(t), employs a power-reduction identity, yielding (5/8)e^(2t)(2 - sin(2t) - cos(2t)) + C. The third integral, -e^(2t)cos^2(t), is expressed in terms of the second integral and results in -(1/8)e^(2t)(2 + sin(2t) + cos(2t)) + C. The thread effectively demonstrates the application of integration techniques to derive these results.
MarkFL
MHB
Here are the questions:
I need help to solve following integrals problems?
How to solve these problems:
1) integral of -6e^2tsintcost dt
2) integral of 5e^2tsin^2t dt
3) integral of -e^2tcos^2t dt
I have posted a link there to this thread so the OP can see my work.
Mathematics news on Phys.org
Hello Anh Nguyen,
Before we work the given problems, let's develop two formulas we can use.
First, let's consider:
$$I=\int e^{x}\sin(x)\,dx$$
Let's use integration by parts, where:
$$u=\sin(x)\,\therefore\,du=\cos(x)\,dx$$
$$dv=e^{x}\,dx\,\therefore\,v=e^x$$
Hence:
$$I=\sin(x)e^{x}-\int e^{x}\cos(x)\,dx$$
Let's use integration by parts again, where:
$$u=\cos(x)\,\therefore\,du=-\sin(x)\,dx$$
Hence:
$$I=\sin(x)e^{x}-\left(\cos(x)e^{x}+\int e^{x}\sin(x)\,dx \right)$$
$$I=e^{x}\left(\sin(x)-\cos(x) \right)-I$$
Add $I$ to both sides:
$$2I=e^{x}\left(\sin(x)-\cos(x) \right)$$
Divide through by $2$ and append the constant of integration:
$$I=\frac{e^{x}}{2}\left(\sin(x)-\cos(x) \right)+C$$
Thus, we have:
(1) $$\int e^{x}\sin(x)\,dx=\frac{e^{x}}{2}\left(\sin(x)-\cos(x) \right)+C$$
Next, let's consider:
$$I=\int e^{x}\cos(x)\,dx$$
Above, we found:
$$I=\cos(x)e^{x}+\int e^{x}\sin(x)\,dx$$
Using (1), we may state:
$$I=\cos(x)e^{x}+\frac{e^{x}}{2}\left(\sin(x)-\cos(x) \right)+C$$
$$I=\frac{e^{x}}{2}\left(\sin(x)+\cos(x) \right)+C$$
Hence, we may state:
(2) $$\int e^{x}\cos(x)\,dx=\frac{e^{x}}{2}\left(\sin(x)+\cos(x) \right)+C$$
Now, armed with these two formulas, let's work the given problems.
1.) We are given to evaluate:
$$I=\int -6e^{2t}\sin(t)\cos(t)\,dt$$
Using the double-angle identity for sine, we may write:
$$I=-3\int e^{2t}\sin(2t)\,dt$$
Using the substitution $$w=2t\,\therefore\,dw-2\,dt$$ we have:
$$I=-\frac{3}{2}\int e^{w}\sin(w)\,dw$$
Using (1), we obtain:
$$I=-\frac{3}{2}\left(\frac{e^{w}}{2}\left(\sin(w)-\cos(w) \right) \right)+C$$
$$I=\frac{3}{4}e^{w}\left(\cos(w)-\sin(w) \right)+C$$
Back-substituting for $w$ and $I$, we have:
$$\int -6e^{2t}\sin(t)\cos(t)\,dt=\frac{3}{4}e^{2t}\left(\cos(2t)-\sin(2t) \right)+C$$
2.) We are given to evaluate:
$$I=\int 5e^{2t}\sin^2(t)\,dt$$
Using a power-reduction identity for sine, we may write:
$$I=\frac{5}{2}\int e^{2t}\left(1-\cos(2t) \right)\,dt$$
$$I=\frac{5}{4}\int e^{w}\left(1-\cos(w) \right)\,dw$$
$$I=\frac{5}{4}\left(\int e^{w}\,dw-\int e^{w}\cos(w)\,dw \right)$$
Using (2), we may state:
$$I=\frac{5}{4}\left(e^{w}-\frac{e^{w}}{2}\left(\sin(w)+\cos(w) \right) \right)+C$$
$$I=\frac{5}{8}e^{w}\left(2-\sin(w)-\cos(w) \right)+C$$
$$\int 5e^{2t}\sin^2(t)\,dt=\frac{5}{8}e^{2t}\left(2-\sin(2t)-\cos(2t) \right)+C$$
3.) We are given to evaluate:
$$I=\int -e^{2t}\cos^2(t)\,dt=\int e^{2t}\left(\sin^2(t)-1 \right)\,dt=\int e^{2t}\sin^2(t)\,dt-\int e^{2t}\,dt$$
Using the result of problem 2.) we may write:
$$I=\frac{1}{8}e^{2t}\left(2-\sin(2t)-\cos(2t) \right)-\frac{1}{2}e^{2t}+C$$
And so we conclude:
$$\int -e^{2t}\cos^2(t)\,dt=-\frac{1}{8}e^{2t}\left(2+\sin(2t)+\cos(2t) \right)+C$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
