Animation using matplotlib query
In summary, the conversation is about trying to animate a plot of two distinct points moving about the complex unit circle using Python's Matplotlib library. The problem is that the animation does not remove and update the previous data points, resulting in a smudging effect. The goal is to have two distinct points moving about the unit circle as a function of time. The code for executing the animation and creating a complex unit circle is shown, and the code for the animation itself is also provided. Suggestions for solving the issue include clearing the plot before animating.
Danny Boy
49
TL;DR Summary
Trying to correct my code which animates data as two points on a unit circle.
I am trying to animate a plot of two distinct points (blue and green points) moving about the complex unit circle using Python's Matplotlib library. The problem I am having is that the animation does not remove and update the previous data points but rather sequentially smears it on the unit sphere as in the accompanying image. Hence the animation is just a smudging of the various data points as shown in the image. What I am trying to achieve is two distinct points moving about the unit circle as a function of time (as shown here but with only two points orbiting).
The following is the code where I call 'animation.FuncAnimation' using data in arrays which I call 'A' and 'B'.
PythonCodeforExecutingAnimationPythonCodeforExecutingAnimation
Python:
##Python Code for Executing Animation##
import matplotlib.animation as animation
import matplotlib.pyplot as plt
import numpy as np
from pylab import *
#Example Data
A = array([0., 0.03435915,  0.06328989, 0.0880305, 0.14199928, 0.2044361, 0.26287941,  0.32484623])
B = array([ 1.75, 1.71564086, 1.69358362, 1.68499179, 1.68255084, 1.67808712, 1.66169597,  1.64407287])
# Total time.
T = 1.0
# Number of steps.
NS = 100
# Time step size
dt = T/NS
t = np.linspace(0.0, NS*dt, NS+1)
# So here are a few utility functions for multiplying scalars and vectors.
# a scalar times a vector returns a vector
def scale_vector(scale, vector):
  result = [0]*len(vector)
  for i in range(len(result)):
    result[i] = scale * vector[i]
  return result
# dot product of two vectors = sum(x[0]*y[0] + ... + x[n-1]*y[n-1])
def vector_dot(vector1, vector2):
  result = 0
  for i in range(len(vector1)):
    result += vector1[i] * vector2[i]
  return result
# return real part of a vector
def real_vector(vector):
  return map(lambda x: x.real, vector)
# return imaginary part of a vector
def imag_vector(vector):
  return map(lambda x: x.imag, vector)
## Creating complex unit circle
r = []
im = []
def main():
  # Generate numbers around the complex unit circle.
  N = 128
  theta = scale_vector(2*pi/N, range(N))
  exp_theta = map(lambda x: exp(1j * x), theta)
  real_part = real_vector(exp_theta)
  imag_part = imag_vector(exp_theta)
  r.append(real_part)
  im.append(imag_part)
  # And wait until the user is done with it.
  done = raw_input("done? ")
if __name__ == "__main__":
  main()
#Form two arrays which have the real and imaginary components of the unit circle
r2 = r[0][:]
im2 = im[0][:]
##Code for Animation##
Aan = np.zeros([len(A),2], float)
for i in range(2):
  for j in range(len(A)):
    if i == 0:
      Aan[j][i] = math.cos(A[j])
    elif i == 1:
      Aan[j][i] = math.sin(A[j])
Ban = np.zeros([len(B),2], float)
for i in range(2):
  for j in range(len(B)):
    if i == 0:
      Ban[j][i] = math.cos(B[j])
    elif i == 1:
      Ban[j][i] = math.sin(B[j])
##Plots and animation
fig = figure()
plt.title('Phase Space')
plt.xlabel('Re')
plt.ylabel('Im')
#Plots complex unit circle
plot1 = plt.plot(r2,im2, color = 'g',alpha = 0.4)
#Animation functions
def animate(i):
     plot(Aan[i, 0], Aan[i, 1], color='blue', marker= 'o')
     plot(Ban[i, 0], Ban[i, 1], color='orange', marker= 'o')
ani = animation.FuncAnimation(fig, animate, interval=101)
show()
243260
Can anyone advise on how this problem could be solved? Thanks for any assistance.
Technology news on Phys.org
Related to Animation using matplotlib query
1. How do I create an animated plot using matplotlib?
To create an animated plot using matplotlib, you will need to use the FuncAnimation class. This class allows you to update the data in your plot at specific intervals, creating the illusion of animation.
2. Can I customize the animation in matplotlib?
Yes, you can customize the animation in matplotlib by specifying various parameters such as duration, frames per second, and animation style. You can also add additional elements to the animation, such as text or annotations.
3. How do I save an animated plot in matplotlib?
To save an animated plot in matplotlib, you will need to use the save method of the FuncAnimation class. This will allow you to save the animation as a video file, such as .mp4 or .gif.
4. Is it possible to create a 3D animated plot in matplotlib?
Yes, it is possible to create a 3D animated plot in matplotlib. You will need to use the mplot3d toolkit, which provides functions for creating 3D plots and animations.
5. Can I combine multiple animated plots in matplotlib?
Yes, you can combine multiple animated plots in matplotlib by using the subplots function. This will allow you to create a figure with multiple subplots, each with its own animation.
