Anionic ligands in coordination complexes
  • Thread starter CrimpJiggler
  • Tags
    Ligands
In summary, anionic ligands are ligands that are anions from the start and can determine the oxidation state of a metal in a complex. All ligands, including anionic ligands, are also Lewis bases.
CrimpJiggler
149
I read that all ligands are Lewis bases but I then read that the number of anionic ligands attached to a metal will determine its oxidation state. Which is it? Let's use chlorine as an example. Before this ligand binds to the metal is it a Cl- ion or a neutral Cl atom? If its the former I can see how its a Lewis base because it provides both electrons for the bond. Conversely I don't see how it could "raise" the oxidation state of the metal if its actually bonded as a Lewis base. If its the latter (if its a neutral Cl atom) then I can see how it raises the oxidation state of the metal by 1 but I don't see how its a Lewis base.
So to summarise the question, what are anionic ligands? Are they anions from the start or do they become anions by taking an electron from the metal?
Chemistry news on Phys.org
Anionic ligands are ligands that would dissociate from the metal as an anion, and are almost always anions from the start as well, neutral ligands dissociate as a neutral species.
You can use the number of anionic ligands and overall charge of a complex to determine the oxidation state of the metal. Note that the number of anionic ligands can still be 0, in which case the oxidation state is the overall charge of the complex.
Note that all ligands are Lewis bases - Lewis basic and anionic are by no means mutually exclusive!
Related to Anionic ligands in coordination complexes
1. What are anionic ligands in coordination complexes?
Anionic ligands are negatively charged molecules or ions that form coordination complexes with metal ions. They typically have lone pairs of electrons that can form coordinate bonds with the metal ion, resulting in a stable complex.
2. How do anionic ligands differ from cationic and neutral ligands in coordination complexes?
Anionic ligands differ from cationic and neutral ligands in that they have a negative charge, while cationic ligands have a positive charge and neutral ligands have no charge. This difference in charge can affect the stability and other properties of the coordination complex.
3. What are some common examples of anionic ligands in coordination complexes?
Some common examples of anionic ligands include halides (such as chloride, bromide, and iodide), hydroxide, cyanide, and nitrate. Other examples include carboxylates (such as acetate and oxalate), sulfates, and phosphates.
4. How do anionic ligands influence the properties and reactivity of coordination complexes?
The properties and reactivity of coordination complexes can be greatly influenced by the presence of anionic ligands. Anionic ligands can affect the electronic structure of the metal ion, resulting in changes in bonding, geometry, and magnetic properties. They can also affect the stability and solubility of the complex.
5. Can anionic ligands be used in biological systems?
Yes, anionic ligands can be incorporated into coordination complexes for use in biological systems. For example, they can be used as ligands for metalloenzymes, which are enzymes that contain metal ions in their active site. Anionic ligands can also play a role in the transport and storage of metal ions in biological systems.
  • Chemistry
  • Chemistry
  • Chemistry
