How Do Waves Propagate in an Anisotropic Dielectric Medium?
In summary, the conversation discusses a non-magnetic but anisotropic dielectric medium with relationships between D and E. The goal is to show that waves propagate only in the z-direction at one speed. The wave equation cannot be obtained using the usual method of using Maxwell's equations and the vector identity. Instead, the conversation explores including the expression grad(divE) and discusses the impact of the permittivity matrix on the wave equations. If k1=k2=k, there is a simple solution with a wave velocity of 1/sqrt(k).
sachi
75
we have a non magnetic but anisotropic dielectric medium which has the following relationships between D and E
Dx = k1*Ex, Dy = k2*Ey, Dz = k3*Ez
we have to show that waves propogate in the z-dir'n at one speed only.
I can't get the wave eq'n to fall out. Usually you just use Maxwell's equations and the vector identity
curl(curl(E)) = grad(divE)- grad squared E
and set divE = 0. You can usually say this because in a dielectric there is no free charge therefore divD = 0 and in an LIH medium E is proportional to D therefore divE = 0 . Instead now I have to include the grad(divE) expression and the algebra doesn't even resemble the wave eq'n. I'd appreciate any hints on where I've gone wrong.
Well, you'll have to see what impact does
[tex] \left(\begin{array}{c} D_{x}\\D_{y}\\D_{z}\end{array}\right)=\left(\begin{array}{ccc} k_{1} & 0 & 0 \\ 0 & k_{2} & 0\\ 0 & 0 & k_{3} \end{array}\right) \left(\begin{array}{c} E_{x}\\E_{y}\\E_{z}\end{array}\right) [/tex]
have upon the wave equations. I assume the Permittivity matrix has constant elements, if not, you'd have to be more careful with the calculus.
Daniel.
If k1=k2=k, then there is a relatively simple solution.
curl(curl B)=-del^2 B=d_t curl{[k]E}. (d_t is the partial wrt t, etc.)
For the z component in Cartesian coords:
curl{[k]E}_z=d_x(k2 E_y)-d_y(k1 E_x)=k (curl E)_x, if k1=k2=k.
Then, -del^2 B_z=-k(d_t)^2 B_z, and B_z has a wave solution with
velocity=1/\sqrt{k} (All with c=1)
Related to How Do Waves Propagate in an Anisotropic Dielectric Medium?
1. What is an anisotropic dielectric medium?
An anisotropic dielectric medium is a material that exhibits different dielectric properties in different directions. This means that the material has varying electrical conductivity and permittivity depending on the direction of the applied electric field.
2. How is an anisotropic dielectric medium different from an isotropic dielectric medium?
An anisotropic dielectric medium differs from an isotropic dielectric medium in that the latter has the same dielectric properties in all directions. In contrast, an anisotropic medium has different properties in different directions, making it more complex to study and understand.
3. What types of materials can be considered anisotropic dielectric media?
Materials such as crystals, polymers, and some liquid crystals can be considered anisotropic dielectric media. These materials have a specific molecular structure that causes them to have different dielectric properties in different directions.
4. How does the anisotropy of a dielectric medium affect its behavior in an electric field?
The anisotropy of a dielectric medium affects its behavior in an electric field by causing the electric field to interact differently with the material depending on the direction of the field. This can result in different levels of polarization and conductivity in different directions, leading to unique properties and behaviors.
5. What are some applications of anisotropic dielectric media?
Anisotropic dielectric media have many practical applications, such as in electronic devices, optical components, and telecommunications. They are also used in various scientific research and experiments, such as in NMR spectroscopy and imaging, where the anisotropic properties of certain materials can be utilized to obtain detailed information about their molecular structure.
  • Electromagnetism
9K
  • Other Physics Topics
