Anisotropic pinch force in high energy electron beam
In summary, the conversation discusses the behavior of 4 adjacent electrons in an electron beam, specifically focusing on the 2 electrons that are moving together with velocity v. It is noted that a moving charge generates circular magnetic current and the question is posed about finding the magnetic attraction force between these in-tandem electrons. The difference between tandem-pair and shoulder-pair electrons is also mentioned, with the belief that there is an anisotropic pinch force. The conversation also touches on the importance of considering the minimal distance between electrons in an accelerated packed electron bunch and the suggestion to temporarily ignore spin magnetic field. Finally, the idea of going to the rest frame of the beam to calculate forces and then transforming back is suggested as an easier approach.
kiwaho
72
Here I am only considering 4 adjacent electrons in electron beam, especially the 2 electrons that are moving in tandem with velocity v.
Moving charge will generate circular magnetic current. you can imagine magnetic flux as current, just like electric current.
So, the question is same to find the magnetic attraction force between in-tandem electrons. (their induced magnetic currents are same direction, both clockwise or counter-clockwise dependent on observation direction).
As to other 2 electrons moving in shoulder by shoulder, it is easy to calculate the pinch force, but tandem mode may be not. Many textbook just simply treat it as parallel current lines.
I believe the magnetic forces different between tandem-pair and tandem-pair, that is why I claim anisotropic pinch force.
For high energy electron beam researchers, they may concern what is the minimal electron distances in accelerated packed electron bunch. We emphasize too much on plasma particle density, but neglect the attainable minimal electron distance, though we can deduce it from density by cubic root.
Temporarily ignore spin magnetic field.
I don't know what you mean by tandem and shoulder, but you can always go to the rest frame of the beam, calculate the forces there, and transform back. Much easier because you don't have to care about retarded potentials and so on.
Tandem mode means one electron moves in front of another electron, they are moving not only in same direction but also in a line.
Shoulder mode means 2 electrons moving in same direction, but the line that crosses the 2 electrons is orthogonal to the moving direction.
Related to Anisotropic pinch force in high energy electron beam
1. What is anisotropic pinch force in high energy electron beam?
Anisotropic pinch force refers to the force that is exerted on a charged particle beam as it passes through a magnetic field. This force is dependent on the direction of the beam's motion and can cause the beam to be compressed or pinched in one direction.
2. How does anisotropic pinch force affect high energy electron beams?
Anisotropic pinch force can significantly affect high energy electron beams by causing a decrease in their beam size and an increase in their beam density. This can lead to higher beam intensities and higher energy densities, which can be useful in various applications such as particle accelerators and plasma physics experiments.
3. What factors influence the strength of anisotropic pinch force?
The strength of anisotropic pinch force is influenced by several factors, including the strength of the magnetic field, the energy of the electrons in the beam, and the angle between the direction of the beam and the magnetic field. Additionally, the shape and size of the beam can also affect the strength of the force.
4. What are some applications of anisotropic pinch force in high energy electron beams?
Anisotropic pinch force has several applications in high energy electron beams, including electron beam welding, particle accelerators, and plasma confinement. It can also be used in the production of X-rays and in research on controlled nuclear fusion.
5. How is anisotropic pinch force related to the stability of high energy electron beams?
Anisotropic pinch force plays a crucial role in the stability of high energy electron beams. A strong anisotropic pinch force can help to confine the beam, preventing it from diverging and losing its energy. This is especially important in applications where precise control and stability of the beam are essential.
  • Electromagnetism
  • Atomic and Condensed Matter
