Another Beat Frequency Question
In summary, the conversation discusses determining the original frequency of a guitar string after tightening it and hearing 12 beats in 2 seconds when it is sounded against a 440 Hz tuning fork. It is mentioned that the possible frequencies of the string can be found using the formula #beats = |f_1 - f_2|. Additionally, it is suggested that as the beat frequency decreases, the values for f_1 and f_2 must approach each other, making it difficult to determine which one is the original frequency.
Alain12345
37
I have another beat frequency question. I understand how to get the possible frequencies of a string or tuning fork, but I don't know how to determine which one is the original frequency.
When a guitar string is sounded against a 440 Hz tuning fork, twelve beats are heard in two seconds.
a) What are the possible frequencies of the string?
b) If the person tightens the string, the beat frequency decreases. What then is the original frequency of the string, and why?
So, I assume you know [itex]\#beats = |f_1 - f_2|[/itex]:
Since the beat frequency decreases [tex]f_1[/itex] and [itex]f_2[/itex] must approach each other. If this is the case, which one would you pick?
a) The possible frequencies of the string can be determined by using the formula for beat frequency, which is the difference between the two frequencies being sounded. In this case, we know that the beat frequency is 12 beats in 2 seconds, which translates to 6 beats per second. Using this information, we can set up the equation 6 beats/1 second = f1 - 440 Hz, where f1 is the frequency of the string. Solving for f1, we get a possible frequency of 446 Hz. However, this is not the only possible frequency. The string could also be tuned to a frequency of 434 Hz, which would also result in a beat frequency of 6 beats per second.
b) If the person tightens the string, the beat frequency will decrease. This is because tightening the string increases its tension, which in turn increases its frequency. If we use the same formula as before, but with the new beat frequency (let's say 4 beats per second), we can solve for the new frequency of the string. This would give us a frequency of 442 Hz. However, since we know that the original frequency of the string was either 434 Hz or 446 Hz, we can deduce that the original frequency must have been 446 Hz. This is because tightening the string would decrease the beat frequency, which means that the frequency of the string must have been closer to 446 Hz (since the beat frequency was originally 6 beats per second). Therefore, the original frequency of the string is 446 Hz.
FAQ: Another Beat Frequency Question
What is the concept of "Another Beat Frequency Question"?
"Another Beat Frequency Question" refers to the phenomenon where two sound waves with slightly different frequencies interfere with each other, resulting in a perceived beat frequency. This effect is commonly heard in music and can be explained by the principles of wave interference.
How does beat frequency occur?
Beat frequency occurs when two sound waves with slightly different frequencies overlap and interact with each other. This creates a periodic variation in the overall amplitude of the sound, resulting in a beat frequency that is equal to the difference between the two original frequencies.
What factors affect beat frequency?
The factors that affect beat frequency include the difference in frequency between the two sound waves, the amplitude of the waves, and the distance between the source of the waves and the listener. Additionally, the medium through which the waves travel can also have an impact on the perceived beat frequency.
Can beat frequency be used in practical applications?
Yes, beat frequency has practical applications in various fields such as music, physics, and engineering. In music, beat frequency is used to tune instruments and create harmonies. In physics, beat frequency is used to study wave properties and interference. In engineering, beat frequency is used in the design of filters and signal processing techniques.
How can beat frequency be demonstrated?
Beat frequency can be demonstrated by using two tuning forks with slightly different frequencies and holding them close to each other. The resulting beat frequency can be heard as a pulsating sound. It can also be demonstrated through computer simulations or using an oscilloscope to visualize the interference of the two waves.
