Asphyxiated
- 264
For:
[tex] \lim_{x \to 1^{-}} \frac {1}{1-x^{2}} = \infty [/tex]
Find [tex]\; \delta > 0 \;[/tex] such that whenever:
[tex] 1-\delta<x<1 \;\;[/tex] then [tex] \; \frac {1}{1-x^{2}} > 100 [/tex]
[tex] |x-a| < \delta [/tex]
[tex] |f(x)-L| < \epsilon [/tex]
So as it is set right now, this:
[tex] \frac {1}{1-x^{2}} > 100 [/tex]
when solved for x will give me the upper limit but I am looking for the lower limit so I solve for x starting with this:
[tex] \frac {1}{1-x^{2}} < -100 [/tex]
[tex] 1-x^{2} > -10^{-2} [/tex]
[tex] -x^{2} > -10^{-2}-1 [/tex]
[tex] x^{2} > 10^{-2}+1 [/tex]
[tex] x > \sqrt{10^{-2}+1} [/tex]
and then since:
[tex] 1-\delta<x<1 = -\delta<x-1<0 [/tex]
then I will subtract 1 from both sides of the inequality to get:
[tex] x-1 > \sqrt{10^{-2}+1}-1 [/tex]
which works out to be:
[tex] x-1 > .0049 \; or \; \approx 5*10^{-3} [/tex]
which 5*10^-3 is the correct answer but I am not sure that I did the work correctly. They got an exact answer of:
[tex] \delta = 1 - \sqrt{.99} [/tex]
which is actually about .00504, so not my answer exactly
Someone help with where I went wrong?
I say that 5*10^-3 is correct because the answer in the back reads like so:
[tex] \delta = 1 - \sqrt{.99} \; or \; \approx 5*10^{-3} [/tex]
thanks!
