Another expanding universe question
In summary, the evidence from supernovae suggests that the universe is expanding at an accelerating rate. While this has been known for some time, the current data suggest that the rate of expansion is much greater than previously thought. It is hoped that future experiments will be able to more accurately determine the rate of expansion and confirm the accelerating trend.
Sumo
28
I know there are a lot of these questions, but please bear with me, I couldn't really find these precise scenarios elsewhere.
First of all, am I correct in saying that if we took a distant galaxy that was highly redshifted, and had it emitting light pulses to us once every second from its frame, then the rate of the light pulses received from our frame would depend on its degree of redshift?
Now if you took that galaxy. After one second its distance from us would be slightly greater, yes? So according to Hubble's law it should have a slightly greater redshift. So we can assume its velocity away from us is getting greater over time. Doesn't this imply the accelerating expansion of the universe by Hubble's constant? I don't see what I am missing.
Thanks.
Astronomy news on Phys.org
Yes; the time between pulses would increase by the same factor as the redshift.
Your insight here is very good!
In fact, you are precisely correct in this sense. If Hubble's constant actually is constant, then expansion is indeed accelerating. In the case of "pure inflation", the scale factor of the universe increases exponentially, and the Hubble constant is a constant over time.
In general, however, the value for Hubble's constant will decrease over time... even in an accelerating universe, as long as the acceleration is moderated a bit from the pure exponential expansion. The rate at which Hubble's constant is decreasing is very very slow. You'd have to wait hundreds of millions of years to get any appreciable difference. Hubble's "constant" is a constant for the present epoch, but not a fixed value for all time.
Cheers -- sylas
Yeah, the differences would be so minute that I don't think we would be able to measure them yet with any substantial accuracy. There's already huge inaccuracy (I think something in the order of 10% of the value?) in the measurements and value ascribed to Hubble's constant and the distance of distant galaxies with significantly large redshifts.
I read somewhere recently (i.e. within the last 5 years) that there is evidence that the universe is expanding at a greater rate than earlier thought, though I am unable to recall any more of this including the reasoning or what form the evidence took.
The case for accelerating expansion arose from a study of high redshift supernova. See:
Measuring Cosmology with Supernovae
Saul Perlmutter, Brian P. Schmidt
http://arxiv.org/abs/astro-ph/0303428
Over the past decade, supernovae have emerged as some of the most powerful tools for measuring extragalactic distances. A well developed physical understanding of type II supernovae allow them to be used to measure distances independent of the extragalactic distance scale. Type Ia supernovae are empirical tools whose precision and intrinsic brightness make them sensitive probes of the cosmological expansion. Both types of supernovae are consistent with a Hubble Constant within ~10% of H_0 = 70 km/s/Mpc. Two teams have used type Ia supernovae to trace the expansion of the Universe to a look-back time more than 60% of the age of the Universe. These observations show an accelerating Universe which is currently best explained by a cosmological constant or other form of dark energy with an equation of state near w = p/rho = -1. While there are many possible remaining systematic effects, none appears large enough to challenge these current results. Future experiments are planned to better characterize the equation of state of the dark energy leading to the observed acceleration by observing hundreds or even thousands of objects. These experiments will need to carefully control systematic errors to ensure future conclusions are not dominated by effects unrelated to cosmology.
Related to Another expanding universe question
1. What is an expanding universe?
An expanding universe refers to the concept that the space between galaxies is getting larger over time, causing the galaxies themselves to move further apart from each other. This is supported by the observation that galaxies are constantly moving away from each other.
2. How do we know that the universe is expanding?
Scientists use a variety of methods to measure the expansion of the universe, such as studying the redshift of light from distant galaxies or observing the cosmic microwave background. These methods all provide evidence that the universe is indeed expanding.
3. What is the cause of the expansion of the universe?
The exact cause of the expansion of the universe is still a topic of debate among scientists. Some theories suggest that it is due to the effects of dark energy, a mysterious force that is pushing the galaxies apart. Others propose that it is a result of the initial Big Bang event.
4. Will the expansion of the universe ever stop?
There is currently no evidence to suggest that the expansion of the universe will stop. In fact, many theories suggest that it will continue to expand indefinitely. However, it is possible that the rate of expansion may slow down over time.
5. How does the expansion of the universe impact our daily lives?
The expansion of the universe has little to no impact on our daily lives as it is occurring on a scale that is too large to directly affect us. However, it is an important concept in understanding the origins and evolution of the universe.
