Another implicit differentiation
In summary, e^x^y=x+y. x+y is 1+1 if you find the derivatives, but e^x^2 is confusing. You need to find \frac{dy}{dx} to find e^x^2.
afcwestwarrior
457
e^x^y = x +y
ok i know i am suppost to use the chain rule and the product rule
so x+y is 1 +1 if u find the derivatives, but e^x^2 is confusing me, what is u and what is n
i think u= e^x^2 and n= y is that possible for n to equal y, this problem is confusing
So you need to find [itex] \frac{dy}{dx} [/itex]. Assume
[tex] F(x,y)=e^x^y-x-y [/tex]
What are
[tex] \frac{\partial F}{\partial x} \ , \frac{\partial F}{\partial y} [/tex]
equal to ?
afcwestwarrior said:
e^x^y = x +y
Your notation is ambiguous. Is e^x^2 supposed to be (e^x)^2 or e^(x^2). I would guess the latter since (e^x)^2 can be written more simply as e^(2x) but you should make it clear.
Oh, and what in the world do you mean by "so x+ y is 1+ 1"? If you mean "the derivative of x+ y is 1+ 1", that is wrong. What variable are you differentiating with respect to? Since you mention the "chain rule" I would guess that x and y are functions of some third variable- again you should tell us that and not make us guess. (Okay, I now notice that the title of this was "another implicit differentiation! But we still don't know whether we are to assume y is a function of x or vice-versa.)
I surely can't answer your question "what is n" because there is no "n" in your formula! Again, I can guess that you mean the "n" in the formula (xn)'= n xn-1 but I can't be sure.
PLEASE restate the problem exactly as it given! (And don't just tell us it is "e^x^y= x+y". That's not even a problem. It may well be one of a list of problems in which the "instructions" [what you are to assume and what you are to do] are at the top of the list.)
It might help you to think about how you would differentiate xx or, more generally, xf(x), since y is a function of x. (Do you remember "logarithmic differentiation"?)
FAQ: Another implicit differentiation
What is implicit differentiation?
Implicit differentiation is a method used in calculus to find the derivative of a function that is defined implicitly, meaning it cannot be explicitly expressed in terms of a single variable. It is commonly used when the equation of a curve cannot be easily solved for y in terms of x.
How is implicit differentiation different from explicit differentiation?
Explicit differentiation is used when the function is defined explicitly in terms of a single variable, and the derivative can be found by applying the rules of differentiation. Implicit differentiation, on the other hand, is used when the function is defined implicitly and requires the use of the chain rule to find the derivative.
What is the process for using implicit differentiation?
The process for implicit differentiation involves differentiating both sides of the equation with respect to x, using the chain rule when necessary, and then solving for dy/dx. It is important to remember to treat y as a function of x and use the product rule or quotient rule when differentiating terms that involve both x and y.
When is implicit differentiation useful?
Implicit differentiation is useful in situations where the equation of a curve cannot be easily solved for y in terms of x. It is commonly used in problems involving circles, ellipses, and other curves defined implicitly. It can also be used to find the derivative of inverse functions.
Are there any limitations or drawbacks to using implicit differentiation?
One limitation of implicit differentiation is that it can be more time-consuming and complex compared to explicit differentiation. It also requires a good understanding of the chain rule and other differentiation rules. Additionally, it may not always give the most simplified form of the derivative, so simplification may be necessary after finding the derivative.
