Another Inductance winding Number question
When winding two separate inductors with different turn counts in parallel, such as 30 turns and 60 turns, the effective inductance can lead to shorting effects due to the differing turn counts. The value of N in this case is not simply the average of the two, as the turns that cancel out will not contribute to the inductance. Instead, the larger winding dominates, and the difference in turns will produce a significant current in the "shorted" section. Bifilar winding techniques are discussed for their ability to enhance coupling between coils, but caution is advised due to potential insulation issues. Overall, the conversation emphasizes the complexities of inductance calculations and the implications of winding configurations.
  • #31
Whew --- had to take some time off. All internet and no sawdust makes james a dull boy. And my alleged thinker is sooo slow these days...I worked through Baluncor's algebra, for purpose of understanding it and getting my gears synchronized with it.
Of course it is impeccable.
Our models are actually pretty doggone close to equivalent.
I did notice one thing about the posit though.
I plugged turns ratio n into balun's formulas for current and put results on the diagram.
Baluncore said:
i = ( V / r ) * ( ( n – 1 ) / ( n + 1 ) )
okay primary i = V/r * (2-1) / (2+1) = 1/3 V/r
Baluncore said:
The secondary current is, i / n.
That's 1/3 divided by 2 = 1/6 V/r
Baluncore said:
Knowing i = I + i/n, solve for driving current I = i – i/n
I = ( V / r ) * ( ( n – 1 ) / ( n + 1 ) ) * ( 1 + 1/n )
I = V/r * * (2-1)/(2+1) * (1+1/2)
I = V/r * (1/3) * (3/2)
that's 1/2 V/r
drawing those into the diagram is really interesting
each red number of course multiplied by V/r.
To satisfy Kirchoff's current law current must be same direction in both secondaries not opposite (as was most logically assumed)
because at node V, current entering must equal current leaving and 1/2 + 1/6 = 2/3 not 1/3.
Now it's pretty obvious that'd be the case were e=0. Is there any other e that'd satisfy? I haven't mustered the courage to tackle the frustration of my clumsy algebra to see.
But it's interesting he got the same current ratio in his ideal transformer as i did in my inductor.
Also interesting that he got magnitudes half mine, 1/6 and 2/6 vs my 1/3 and 2/3. Of course i assumed 1 for my I vs his 1/2 probably its that simple.
That shorting turns cancels flux, driving it toward zero, goes along with what the algebra says, current magnitude depends on resistance of windings and how it divides depends on turns ratio.. At zero flux e=0 and our models both give same result there.
Now i'll point out something about ideal transformers.
They take no magnetizing current.
That's why a model of a real transformer has a parallel branch Xm to account for magnetizing current.
That transformers do require magnetizing current is why Iprimary/ Isecondary isn't exactly equal to turns ratio, the currents differ by magnetizing current which is intentionally kept small.
So we must bear in mind that accepting an ideal transformer requires a mental leap
since it requires no magnetizing current
the presence of induction requires zero reluctance
flux = (zero amp-turns)/(zero reluctance), undefined, yet flux in a real transformer is defined.
that means infinite permeability , and some magnetic alloys do have so much permeability that for sliderule accuracy you can get away with calling it infinite. And we do often ignore magnetizing current.
That's what i was trying to allow for with my jΦ term.
( Actually I'm trying to build a mental model for myself to understand CT's with parallel secondaries of unequal turns like that guy asked us about in https://www.physicsforums.com/threads/how-many-turns-on-a-50-5-ct.586722/
tinkeringone said:
Thanks, Jim. I followed your advice, and dissected it, and saw a spot where the windings had arced across at least a couple of turns. As far as the number of turns go, it has 2 parallel wires wound around the core. I counted 19 wire turns around the core. And that's because one of the 2 parallel wires is 25" long from terminal to terminal, and the other is only 22" long. The 25" long wire had 10 turns around the core, and the 22" one had only 9 turns - it wasn't long enough for them to make the 10th turn.
The 2 parallel wires are each 0.038" in diameter, like maybe 19 gauge? I'm wondering if I could just run 9 or 10 turns of a single, 16 gauge wire, instead of paralleling 2 smaller ones like they did. But I'm wondering if they had a good reason for paralleling those 2 smaller wires. I mean it does seem like you'd be spreading out the winding a bit more by doing that. That parallel setup spanned about 3/4 of the core circumference.
Anyhow
i'd like to try baluncore's algebra with a magnetizing branch added, and induced voltage as ideal sources controlled by magnetizing current.
Sigh. That's an early morning sort of thing.​
@Baluncore core I hope this wasn't taken as criticism at all !
Instead i celebrate having learned something, and i really enjoy sharing interests with folks..In that guy's transformer i'd add a third winding with fifty amp turns .
When i get something going that'll run Basic i'll be able to tinker with core reluctance, winding resistances, and a secondary side load resistance.
But that's a few projects away.
old jim
  • #32
Thanks for the feedback Jim. I posted and ran because my analysis needed to be aired and I needed 36 hours to drive to the other end of the island and back. The 1/2, 1/3 and 1/6 current ratios for n=2 had me puzzled but I have still not had time to analyse what exactly is going on there. I just posted it with your prototype disclaimer at the end. You have identified all the worries I had about the analysis.
My circuit diagram is drawn to show how the “ideal transformer” is effectively driven through it's winding resistances. Analysis of the circuit as driving the primary gives a higher secondary voltage that provides a current loop back to the driving point. Analysis of the circuit as being driving the secondary gives a lower primary voltage that then sinks a current from the driving point. The compromise of those extremes is clearly shown by the conceptual “voltage up, current flows down” layout of my hand drawn schematic.
Regarding CTs with different turn counts in parallel. I am very suspicious that it was intentionally wound that way. In fact I cannot think of any reason why such a turn difference in parallel would be used on any magnetic core as it would be easier to use a well defined parallel resistor. CTs are usually very reliable, maybe it was faulty manufacture or a counting problem.P.S. On my system I run an evolution of the MS QuickBASIC syntax called “FreeBasic” for new and legacy code compatibility. It is free, greatly expanded, compatible with MS VB and calls C libraries without problems. http://en.wikipedia.org/wiki/FreeBASIC
  • #33
Hmm I'm beginning to wonder if @tinkeringone miscounted on his CT...
or maybe that's why his had failed...
i hope he shows up.
There exist cores with a hole drilled through so that the last turn can encircle part of the flux, so as to approximate a fractional-turn for non-integer turns ratio.
Thanks for the tip on that Basic - will get after it.
See you later !old jim
  • #34
The results for coupled inductors where the core has infinite permeability and the coefficient of coupling is unity are interesting, but for non-ideal circumstances more complete analysis is needed.
A formula for the effective inductance of imperfectly coupled inductors connected in parallel, where the inductances of the isolated windings are different, can be found on the web at: http://www.electronics-tutorials.ws/inductor/parallel-inductors.html, about a third of the way down the page under the heading "Mutually Coupled Inductors in Parallel".
Among the comments at the bottom of the page is one by someone named "Banter" who points out an apparent problem with the formula. He says "Please explain how (from the text) you get L = L1 = L2 = M where the two inductances are perfectly coupled and equal. Whether they are equal or not, if the coupling is 100% the net inductance will *always* be zero, according this equation."
The given formula appears to apply to coupled inductors that are imperfect in that the core they are wound on apparently doesn't have infinite permeability, and the formula can deal with the case where the coupling coefficient is less than unity. However, the formula apparently fails when L1 = L2 and k=1 (M = sqrt{L1*L2).
The remaining imperfections that the given formula doesn't consider is resistance in the windings and core loss.
Likes jim hardy
  • #35
We can see where the formula on the web page referenced above comes from by performing a loop analysis of this circuit:
Let a voltage source of 1 volt be applied at the left end terminals. The loop current I1 traverses the loop encompassing the source and inductor L1. Loop current I2 traverses the loop encompassing the source and inductor L2. The current out of the source IT = I1+I2.
The apparent inductance formula for the paralleled inductors can be derived by solving for the currents and dividing the applied voltage (1 volt) by s*IT like this:
This analysis hasn't taken into account any resistance in the windings, but we see where the formula on the web page came from.
Likes Baluncore and jim hardy
  • #36
The analysis can be extended to accommodate the resistance of the wire used to wind the inductances. R1 is in series with L1 and R2 is in series with L2:
I wound a couple of inductors on high permeability, low loss, ferrite toroids. The two windings on each core consist of 20 turns of 16 gauge wire for L1 and 10 turns of 16 gauge wire for L2:
One of them was wound with tight coupling between L1 and L2; the other has considerably looser coupling. The values of L1, L2, R1, R2, k and f (the measurement frequency) for the tightly coupled inductors can be seen in the following image, along with the calculated values of the currents. The real and imaginary parts of I1 are blue and red; the real and imaginary parts of I2 are green and orange. Just below those values is the value of IT. Also shown is the calculated value of the apparent inductance of the two inductors in parallel, with R1 and R2 taken into account.
The formula for the apparent inductance of the parallel combination of L1 and L2 with the resistances of the winding taken into account is shown in magenta. This formula corresponds to the formula of the referenced web page. Notice the presence of the frequency variable f in the magenta formula. This was unexpected.
I measured the apparent inductance of the tightly coupled inductor pair with an LCR meter at three frequencies and compared the measured result to the calculated values:
Code:
Frequency      Calculated      Measured
   1000 Hz       2.023 uH        2.02 uH
    100 Hz       4.658 uH        4.62 uH
     20 Hz       66.92 uH        67.0 uH
The calculated results are close to the measured results, considering that it's somewhat difficult to get good results of inductance measurements on ferromagnetic cores.
  • #37
Banter is considering parallel equal inductors with perfect coupling.
That is the special case of one inductor wound with two wires twisted together, that is, thick wire. Lt = L1 = L2.
But if L1 = L2 and M =sqrt(L1*L2) then (L1+L2 – 2M) is zero.
So throughout the equations he is actually dividing zero by zero.
  • #38
Wow ! Great find there, and wonderful experiment ! (I was still trying to remember where my old CT cores are for a similar experiment.)
So, that formula only fails when L1 and L2 are equal, ie same number of turns?
I too never expected frequency to be show up in a calculation of inductance.
I'll be some time plodding through your work , plodder that i am, until it becomes clear why.
can M involve f(frequency) ?
hyperphysics said:
The mutual inductance M can be defined as the proportionalitiy between the emf generated in coil 2 to the change in current in coil 1 which produced it.
THANKS, guys !
old jim
  • #39
It apparently fails when L1 and L2 are equal, and when the coupling coefficient is unity (M = sqrt(L1*L2) in other words).
I said apparently because when a mathematical expression degenerates to the form 0/0, oftentimes using a limiting process will give a proper result, such as I get with the limit function in my CAS software:
The result after simplifying the odd expression is simply L1, the expected result.
It could, for example due to skin and proximity effect, L1 and L2 could change a small amount with frequency, and so could M.
But the effect we're seeing here is very large increases in effective inductance at low frequencies due to changes in the ratio of reactance to resistance in the windings. The analysis shows that it happens, but an easy intuitive understanding doesn't leap out at me. We just have to trust the math, which experiment verifies.
Likes jim hardy
  • #40
Me either. It's the sort of thing one mulls over in background for days.
Great job ! Thank You !
  • #41
This coupled inductor circuit is very sensitive to the coupling coefficient. For example, plotting the phase of the total current vs. k shows that the impedance of the parallel connection of L1 an L2 looks quite inductive until the coupling coefficient gets very close to unity:
We can't really see what's going on when k gets close to unity.
Plotting with 1-k as the independent variable rather than k, and using a log plot allows us to see the details:
It looks like the phase is zero when k=1 but it isn't. As long as there is some resistance in the windings, the overall impedance is slightly inductive even when k=1, and the total current has a reactive component when k=1, as long as the permeability of the core isn't infinite.
The case where the core has infinite permeability means that the inductors have infinite inductance. If the windings have turns wound with a finite ratio, say 2 to 1, but the core has infinite permeability, the inductances would be infinite, but mathematically this case can still be treated--infinite inductances for the windings due to the infinite permeability, but with inductances having a finite ratio. This case doesn't occur with real wire and real cores.
Another interesting thing about this circuit is the fact that the currents in L1 are apparently flowing in the opposite direction to those in L2 when k is unity; this is the case with the early analyses in this thread. It turns out that this property is also affected by the coupling coefficient and the resistance of the windings. Here's a plot showing the ratio of the real part of the current in L1 to the real part of the current in L2 (blue curve). The red curve shows the ratio of the imaginary part of the currents in L1 to L2.
Notice that the sign of the ratios is negative when k is approaching unity, which means that the currents are flowing in opposite directions. As k decreases from unity to zero, the sign of the ratios becomes positive for some k. This is not unexpected. Obviously, if the inductors are not coupled at all (wound on separate cores), but connected in parallel, the currents should be in the same direction with respect to the energized terminals:
It almost looks like there is a discontinuity at k=1. Adding 1 ohm to the resistance of each winding and then plotting these ratios shows what's happening; for k large enough, the imaginary parts of the currents are again flowing in the same direction. However, for the special case where k=1 but the resistances are zero, all bets are off; the permeability of the core comes into play. The coupling in my real inductors isn't close enough to unity, and the resistances aren't large enough, to see the current directions become the same, as these plots suggest would be the case.
  • #42
This all makes a lot of sense. My simple transformer circuit model with series winding resistance can be changed to move part of the 100% coupled transformer inductance out of coupling into isolated series with the winding resistance. The division of voltage between the winding resistance and the isolated part of the inductance is then a frequency dependent function. I have seen that clearly in the spice model. Changing frequency or M changes the phase shift of the voltage to current and therefore the effective inductance.
  • #43
Yeah...wow, everytime I've come back to this thread it's grown. It's going to take me days to digest all that's been said and shown here for me to sumarise it, atm I have little no no idea lol
  • #44
There are some things electronics engineers spend their time trying to avoid. One of those things is “shorted turns” in wound magnetic components such as chokes and transformers. Your suggestion that inductors with 100% coupling, (wound on the same core, but with different numbers of turns), might be useful, has led to this little explored field of analysis. It is little explored because in real circuits it appears to always result in higher losses and inefficiency. We have yet to identify a justifiable use for such an engineered situation. I would class this field as fault analysis.
Science involves the reduction of complex situations into simple relationships. Some of us are sufficiently annoyed that we were not able to understand and explain this field using our simple rules, that we have taken your thread and torn our analysis apart in the search for a consistent interpretation.
The summary at present is that you should avoid having windings with different numbers of turns in parallel on the same magnetic core. We have a two dimensional map of coupling from 0 to 100% plotted against turns ratio, n, from 1 to infinity. The point on that map where coupling=100% and n=1 is the very special case of using one thicker wire instead of two separate wires. All other points with significant coupling appear to result in an unnecessary circulating current, higher losses and a waste of investment in winding and core materials.
  • #45
Jim mentioned in post #33: "There exist cores with a hole drilled through so that the last turn can encircle part of the flux, so as to approximate a fractional-turn for non-integer turns ratio."
One place where I've seen that is on a 10 kW variac. Here's a picture of a smaller variac:
http://en.wikipedia.org/wiki/Autotransformer#/media/File:Variable_Transformer_01.jpg
The sliding brush shorts out several adjacent turns on the toroidal core. This represents some power loss, and how much depends on how many turns per volt the core has been wound for. The 10 kW variac we used actually had two windings side by side in a single layer in the manner seen in the picture. But one of the windings was threaded at the end of the winding through a hole drilled through the core. Thus that winding was enclosing just a little less mmf; another way to look at it is the winding had a half turn. This meant that the voltage between adjacent turns (that were shorted by the sliding brush) was less, and the loss due to heating of the sliding brush was reduced.
So this is a situation where two windings of different numbers of turns (one half turn difference) were connected in parallel (by the sliding brush). This is the old engineering trade-off. You determine if the benefit outweighs the cost, and apparently it did in this case.
I hope the OP isn't annoyed by the extremes to which we've taken his thread, but it's all related to his question, so finally I'm going to post a picture of another mystery. Here's an interesting toroidal core I found at Boeing surplus years ago. Look at how it's wound. There are holes drilled around the periphery and the wire is threaded through all those holes. Why would one want to wind a core in a manner like this, not enclosing all the iron? I don't know the answer:
  • #46
Indeed it really bugs me when i can't figure something out.
You guys's wonderful work confirms what intuition says - with zero induction current divides between the coils
but at some value of induction the greater coil overwhelms the lesser one...
What happens if one makes a CT from such an inductor, adding a one turn primary ,
then adds external resistance so as to indicate current by voltage across say a 1 ohm resistor,
meaning the sum of amp-turns must become larger to produce enough flux to impress voltage across that resistor?
I think i'll take a step in that direction by tinkering with @tim9000 's original inductor, 30 and 60 turns on an unknown core.
This is just a thought experiment:
If Electrician's core were one of these
magnetics inc 01540354R
with path length 12cm
core area 0.726 square cm
permeability let's assume 5000
so inductance is
μ0 μrelative N2 X Area / length
4Π X 1e-7 X 5E3 X N^2 X 0.726E-4 / 12E-2
= N^2 X 3.8e-6 , 10 turns giving 3.8E-4 or 0.38 millihenry and 20 turns giving 1.52 millihenry
so i guess his core has reluctance about a quarter (0.26) of the one i guessed at.
Maximum flux of my core per Magnetics Inc is around 6 kilogauss (0.6 Tesla)
https://www.google.com/?gws_rd=ssl#q=magnetics+bulletin+sr-4
so if flux were 0.6cos(120 pi t ) X area of .0007264 m^2 = 4.358E-4cos(120pi t) weber , dΦ/dt would be -120 pi X 4.358E-4 sin wt, = 0.164 weber/sec
yielding 0.164 volts/turn peak sinewave voltage. That's all the core can make.
How many amp turns would that take?
Well, Φ = μ0 μrelative N X I X Area / length
N X I = Φ / ( μ0 μrelative X Area / length _
NI = 4.358E-4 / (4Π X 1e-7 X 5E3 X 0.726E-4 / 12E-2 )
NI = 4.358E-4 / (3.803E-6) = 114 amp-turns
wow seems a lot for just 164 milllivolts per turn
clearly it's going to be hard to make a 50::5 pass thru transformer with this core
(probably i made a mistake, haven't done this since mid 1960's, and then in gausses oersteds and inches...
but I've checked, so if you find one - bravo)
so let me continue
this core produces 0.164 / 114 = 1.4386E-3 volts per turn per amp-turn of MMF.
Let's round that to 1.44 millivolts per turn per amp-turn.Whew.
Now we've characterized the core.
My hypothesis two pages back was
jim hardy said:
so
i hypothesize that for OP's 2::1 ratio of turns and one unit of current applied
A = 0.666 + jΦ/3R , the current in the 30 turn winding
and B = 1 - A = 0.333 - jΦ/3R , current in 60 turn winding
where Φ is a property of the core, volts-per-turn/amp-turn
and R is a property of the wire, ohms per turn.
[Now it's unfortunate i used Φ in that sense, but i really needed a simple picture for my worn out, obsolete brain.
Volts per turn is flux, because of derivative property of sinusoids, in hindsight i should have picked a name for characterizing the core that's closer to reluctance. My bad. Apologies if it distracts anybody. ]
My core characterization constant volts per turn per ampturn , Φ, has value 1.44E-3. I'll make it red to distinguish it from flux.
and i'll guess at ohms per turn...
My hypothetical core has area of 0.7264 cm^2 which cross section might be a circle of diameter 0.4808 cm. Let's round that to 0.5cm because it's probably wrapped in something. So a turn of wire is at least pi/2 cm long.
#22 is probably the smallest one would use for 5 amps?
#22 is about 53 ohms/km, or 5.3E-4 ohms/cm
for our pi/2 long turns that's 8.325 milliohms/turn
Round up to 8.5 milliohms per turn because each turn is really a little longer than pi/2 , because with each turn it progresses partway around the 12 cm core length? And we have to add half the diameter of #22 to our radius?
Okay, now i have both Φ and ohms/turn.
A = 0.666 + jΦ/3R = 2/3 +j1.44E-3/8.5E-3, = 2/3 +j0.169 , which = 0.688 angle 14.2 degrees
B = 1 - A = 0.333 - jΦ/3R = 1/3 -j1.44E-3/8.5E-3 = 1/3 -j0.169 = 0.374 angle 26.9 degrees
So now let's sum mmf's.
twopages back,
A was the 30 turn winding
and B was the 60.
So we have
in A: 30 X (2/3 +j 0.169) amp turns
in B: 60 X (1/3 -j0.169) amp turns
sum is 40-j5.07 , which is 40.323 angle -7.22 degrees
so with an amp applied we'd have induction of 40.323 X 1.44E-3 = 10.4 millivolts per turn (peak)
which is well below the core's capability of 164 millivolts per turn.
Whew - I'm worn out.
Maybe you guys would do sanity checks on my arithmetic. Your simulations should make it a snap.
How much voltage would it take to impress an amp through that 30::60 turn inductor? Should be ohm's law...
If my arithmetic has been good, i might now have an approach for figuring out that 50::5 CT with reported dual secondaries of nine and ten turns. Could it work or not? I'll apply a fixed 50 amp turn primary and see what are currents and terminal voltage. But not right now...
Thanks guys for indulging an old fellow. I'm not done yet, but am sure done for today.
G'nite all.
Criticism welcome. Hope y'all enjoyed this.
old jim
  • #47
  • #48
oh my gosh...
  • #49
Sorry about the OP thread diversion.
An interesting one.
It would be very difficult to wind such a core with the wrong number of turns or with poor spacing.
That must be a Current Transformer core with a 24 turn secondary for control or instrumentation.
Could the holes drop the ratio back to maybe 1 : 20 ?
There is no scale, OD, ID, stack or lamination thickness shown. It looks like it is wound with a flexible wire, plastic insulated, through a stack of laminations. If laminations are standard thickness it is for mains frequency use. Thinner than normal laminations would be for 400Hz aircraft power systems. Can you count laminations, measure stack height to compute lamination thickness ?
Were the laminations pre-punched or drilled after stacking? There would be no eddy current loop problems with lack of insulation between laminations if drill holes passed through all the laminations after stacking. You might be able to tell by; if the holes run perpendicular to the face it was drilled, if each hole staggered slightly through part of the turn pitch then it was pre-punched.
Note that one of the lead wires is NOT wound back to cancel the induced turn in order to reduce external interference, so it is probably being used as a current transformer rather than an inductor.
  • #50
My core is a Magnetics inc W6113 as seen here: http://www.mag-inc.com/products/ferrite-cores/ferrite-toroids
Here's a current transformer design guide that mentions drilled holes in the core for fractional turn corrections: http://permag.net/documents/CurrentTransformerDesignGuide.pdf
We should start a new thread to continue this discussion.
  • #51
Thanks !
nH/T2 = 13690 ± 30% that'll be the proper way of expressing my Φ term...
nice core, μrelative is 10,000
Sorry for what ? You broke ground.
I learned a lot, lots more to go.
  • · Replies 28 ·
13K
  • · Replies 47 ·
