- #36
The Electrician
- 207
The analysis can be extended to accommodate the resistance of the wire used to wind the inductances. R1 is in series with L1 and R2 is in series with L2:
I wound a couple of inductors on high permeability, low loss, ferrite toroids. The two windings on each core consist of 20 turns of 16 gauge wire for L1 and 10 turns of 16 gauge wire for L2:
One of them was wound with tight coupling between L1 and L2; the other has considerably looser coupling. The values of L1, L2, R1, R2, k and f (the measurement frequency) for the tightly coupled inductors can be seen in the following image, along with the calculated values of the currents. The real and imaginary parts of I1 are blue and red; the real and imaginary parts of I2 are green and orange. Just below those values is the value of IT. Also shown is the calculated value of the apparent inductance of the two inductors in parallel, with R1 and R2 taken into account.
The formula for the apparent inductance of the parallel combination of L1 and L2 with the resistances of the winding taken into account is shown in magenta. This formula corresponds to the formula of the referenced web page. Notice the presence of the frequency variable f in the magenta formula. This was unexpected.
I measured the apparent inductance of the tightly coupled inductor pair with an LCR meter at three frequencies and compared the measured result to the calculated values:
The calculated results are close to the measured results, considering that it's somewhat difficult to get good results of inductance measurements on ferromagnetic cores.
Code:
Frequency Calculated Measured
1000 Hz 2.023 uH 2.02 uH
100 Hz 4.658 uH 4.62 uH
20 Hz 66.92 uH 67.0 uH
