Another problem dealing with heat transfer
In summary, the problem involves calculating the amount of Fe needed to raise the temperature of 100.00 g of water from 20C to 35C, assuming that the energy required to raise water is 6300 J. The correct amount of Fe is approximately 85 g. However, there may be an error in the check as the final temperature should be Tf-20 instead of 35-Tf.
Rhine720
88
How much Fe at 200.0C must be placed in 100.00g of water at 20C so that the temperature of both will be at 35.0?
Q=MCdeltaT
Energy required to raise water is 6300 J
So I did by:
(keep in mind I used sig figs)
Q=100.00(4.18)15
Q=6300
And then..
I assumed I must plug in 6300 as a negative to the FE to get the amount needed
I did
-6300=x(.449)165
x=-6300/74.1
x=85g
I go to check my work by doing taking out the final temp and trying to solve for it by using the grams
I did so by:
(85).449(Tf-200.0)=(100.0)4.18(35.0-Tf)
38Tf-7600=14600-418Tf
456Tf=22200
And got 48.7 Which is not so close to 35C
Am I checking this wrong or am I doing the problem wrong?
I think you have done the problem correctly and the problem with the check is that the "35-Tf" should be "Tf - 20".
You know, your work would be so much clearer if you put in a few words like this:
Heat lost by iron = heat gained by water
mC(delta T) = mC(delta T)
m(.449)(165) = 100*4.18*15
m = 100*4.18*15/(.449*165) = 84.6 g
It seems like you have the right approach to solving this problem. However, it is important to note that the specific heat capacity of iron (Fe) is 0.449 J/g°C, not 0.449 J/g. This small mistake could have affected your final answer. Additionally, when plugging in the values for the final temperature, make sure to use the same units (in this case, either °C or K). Using different units can also lead to an incorrect answer. It would be helpful to double check your calculations and units to ensure accuracy.
FAQ: Another problem dealing with heat transfer
What is heat transfer?
Heat transfer is the movement of thermal energy from one object to another due to a difference in temperature. This can occur through three main mechanisms: conduction, convection, and radiation.
What causes heat transfer?
Heat transfer is caused by a temperature difference between two objects. Heat will always flow from a hotter object to a cooler object until they reach thermal equilibrium.
What are the factors that affect heat transfer?
The rate of heat transfer is influenced by several factors including the temperature difference between two objects, the thermal conductivity of the materials involved, the surface area and distance between the objects, and the presence of any insulating materials.
How is heat transfer used in everyday life?
Heat transfer is an essential aspect of our daily lives. It is responsible for keeping our homes warm, cooking our food, and even regulating our body temperature. It is also used in industries such as power generation, refrigeration, and heating and cooling systems.
How can heat transfer be controlled or manipulated?
Heat transfer can be controlled or manipulated through various methods such as insulation, convection currents, and heat exchangers. These methods can be used to either increase or decrease the rate of heat transfer between objects.
