Another question about projections.
  • Thread starter evilpostingmong
  • Tags
    Projections
In summary, the conversation discusses the application of a transformation T to a subspace U of V, with T being a non-projection and U being a projection. The question is whether applying T after U would result in a different output than applying U to the image of T. An example is provided to show that in general, the outputs would not be the same.
evilpostingmong
339
Say we have a transformation T[tex]\in[/tex]L(V). Now suppose a subspace of V (U) is in the rangespace of T. Now suppose PUv=u with u=a1u1+...+amvm.
Now apply T to u to get T(u)=b1u1+...+bmum=/=a1u1+...+amvm. What would happen
if we apply PUto T(u)? In other words, what would we end up with after computing PUT(u)?
I'm just wondering whether or not applying a transformation (a non-projection in this case) after a projection would result
in a different output after applying the projection to the image of T? In other words, would
PUT(u) map to a1u1+..+amum or would it map to b1u1+..+bmum?
Thank you for your response!
Em..It's a bit hard to understand your post, could you explain what do these mean:
T [tex]
\in
[/tex] L(V),
V (U) (what does U mean)
PU (projection?)
It would be helpful if you can clarify these
T [tex]
\in
[/tex] L(V),
PU (projection?)
T is a transformation that sends a vector from V to V.
U is a subspace of V. PU is a projection onto U. And T(u)=b1u1+..+bmum=/=a1u1+...+amum means that T is not
an identity operator, since u=a1u1+...+amum.
I think in general cases they wouldn't be same, just take an exmple
projection
[tex]
P = \left( {\begin{array}{*{20}c}
1 & 0 \\
0 & 0 \\
\end{array}} \right)
[/tex]
transformation(I take a rotation)
[tex]
T = \left( {\begin{array}{*{20}c}
0 & { - 1} \\
1 & 0 \\
[/tex]
take a vector
[tex]
\overrightarrow v = \left[ \begin{array}{l}
1 \\
1 \\
\end{array} \right]
[/tex]
then compute as what you said
[tex]
P\overrightarrow v = \left[ \begin{array}{l}
1 \\
0 \\
\end{array} \right]
[/tex]
[tex]
PT\overrightarrow v = \left[ \begin{array}{l}
- 1 \\
0 \\
\end{array} \right]
[/tex]
projection
[tex]
1 & 0 \\
0 & 0 \\
[/tex]
transformation
[tex]
0 & { - 1} \\
1 & 0 \\
[/tex]
take a vector
[tex]
1 \\
1 \\
\end{array} \right]
[/tex]
[tex]
1 \\
0 \\
\end{array} \right]
[/tex]
[tex]
- 1 \\
0 \\
\end{array} \right]
[/tex]
That answers it! Thank you!
Related to Another question about projections.
1. What is a projection in relation to science?
A projection in science refers to the process of representing a three-dimensional object or phenomenon in a two-dimensional form. This is often done to study or analyze the object or phenomenon from a different perspective.
2. How are projections used in scientific research?
Projections are commonly used in scientific research to visualize and analyze data. They can help scientists better understand complex concepts and make predictions about future outcomes.
3. What are the different types of projections used in science?
There are various types of projections used in science, including cartographic projections, statistical projections, and spatial projections. Each type serves a different purpose and is used in different fields of study.
4. Can projections be inaccurate?
Yes, projections can be inaccurate. They are representations of reality and are subject to errors and distortions. It is important for scientists to understand the limitations of projections and use them appropriately.
5. Are there any ethical concerns surrounding the use of projections in science?
There can be ethical concerns surrounding the use of projections in science, particularly when it comes to the interpretation and communication of results. It is important for scientists to be transparent and cautious when using projections to avoid misleading the public or making decisions based on flawed data.
