Another thought experiment about spin 1/2
In summary: It doesn't result in spin impurity. It results in loss of coherence. The spin state remains pure, you just can't tell what it was with certainty anymore.Ah, OK, I had thought that 'decoherence' was a phenomenon that affected the spin state itself.In summary, the conversation discusses the preparation of a beam of spin 1/2 particles in the state |up> in the Z direction, passing it through a Stern& Gerlach apparatus in the X direction to get two beams of spin |right> and spin |left>, and then redirecting these two beams directly in another inverted S&G to reunite them in one unique beam. The question is whether the resulting
Christian Thom
38
TL;DR Summary
Let's take a beam of spin 1/2 particles prepared in the state |up> in the Z direction, let's pass it through a Stern& Gerlach apparatus in the X direction and then directly in another inverted S&G to reunite the two beams. My question is : will we get only spin |up> particles at the exit of the system ?
Let's take a beam of spin 1/2 particles prepared in the state |up> in the Z direction, let's pass it through a Stern& Gerlach apparatus in the X direction to get two beams of spin |right> and spin |left>, and then redirect these two beams directly in another inverted S&G to reunite them in one unique beam. My question is : will we get only spin |up> particles in this beam ?
Christian Thom said:
Summary:: Let's take a beam of spin 1/2 particles prepared in the state |up> in the Z direction, let's pass it through a Stern& Gerlach apparatus in the X direction and then directly in another inverted S&G to reunite the two beams. My question is : will we get only spin |up> particles at the exit of the system ?
Yes.
Likes DrChinese and Christian Thom
Thank you.
PeroK said:
Yes.
Would you mind elaborating on this just a bit? It was always my understanding that a beam of left- (or right-) spin particles would be a 50-50 mix of up- and down- spin particles, regardless of the preparation before the left-right split. What am I missing?
It's not a mix, it's a superposition of spin states that equate to z-spin-up. If the spatially separated superposition is perfectly recombined, then you still have a beam of z-spin-up particles.
If, however, you pass either spatially separated component of the superposition through a z-aligned SG magnet and measure the outcome, you will find a 50-50 split representing z-spin-up and z-spin-down (i.e. either x-spin up in one component and x-spin-down in the other).
Thanks for the clarification. Back to QM kindergarten I go.
PeroK said:
Yes.
How this result depends on the equality of the path lengths of the two separated beams ?
It's a thought experiment because the recombination would have to be perfect. I don't believe it's a experiment that is practically achievable.
Likes Lord Jestocost and vanhees71
That reminds me of the "Humpty Dumpty Papers" by Schwinger et al.
https://link.springer.com/article/10.1007/BF01909939
https://link.springer.com/article/10.1007/BF01384847
https://journals.aps.org/pra/abstract/10.1103/PhysRevA.40.1775
Of course you cannot do such experiments with the original SGE, because it's impossible to make the magnets as accurate as needed, but in a sense a setup like a Penning trap is a kind of SGE too.
Another modern realization of a coherent-spin experiment is here:
https://www.nature.com/articles/ncomms3424?origin=ppub
Likes Lord Jestocost, DrClaude and PeroK
I would think that there must be some leeway, otherwise free beams of definite spin particles would loose more or less quickly their spin definiteness due to spurious magnetic gradients that are always present in actual experiments.
You'll need to explain what you mean by that.
Note that the SG experiment itself is fuzzy rather than precisely clear-cut.
Likes vanhees71
If you consider a beam like the one at the origin of the experiment above, in absence of S&G devices, the slightest natural magnetic gradients would play the same role as the S&G device, and if the recombination was so difficult to obtain, that would result in the loosing of the spin purity of the original beam after some propagation. This effect would have surely already been observed (maybe it has ?).
If you consider a beam like the one at the origin of the experiment above, in absence of K&G devices, the slightest natural magnetic gradients would play the same role as the K&E device, and if the recombination was so difficult to obtain, that would result in the loosing of the spin purity of the original beam after some propagation. This effect would have surely already been observed (maybe it has ?).
What you are describing is simply state evolution. You would gradually lose the spatial coherence of the beam.
For SG, you need a powerful magnet with a specific varying magnetic field to create a superposition of spatially distinct wavefunctions. Putting those together by perfectly reversing that separation process is theoretically possible but practically very difficult.
Likes vanhees71 and Lord Jestocost
The SG experiment requires a very specific and controlled magnetic field. Just any weak background field won't do.
Likes vanhees71
Thank you all.
