Another topology on the naturals
  • Thread starter radou
  • Tags
    Topology
Overall, your solution is clear and well-written. Good job! In summary, we find that the dense subsets of the topological space (X, U) are {1, 3, 4} and the empty set. The mapping f: (X, U) --> (X, P(X)) defined as f(x) = x is continuous as the preimage of every open set in the codomain is open in the domain.
radou
3,149
Let X = {1, 2, 3, 4, 5} and V = {{2, 3, 4}, {1, 4, 5}, {2, 4, 5}, {1, 3}} be a subbasis of a topology U on X.
a) find all dense subsets of the topological space (X, U)
b) let f : (X, U) --> (X, P(X)) be a mapping defined with f(x) = x (P(X)) is the partitive set of X). Is f continuous?
a) Since V is a subbasis, then the family of all finite intersections of the elements of V form a basis B. So, B = {{2, 3, 4}, {1, 4, 5}, {2, 4, 5}, {1, 3}, {1}, {3}, {4}, {2, 4}, {4, 5}, {0}}. A subset D of X is dense in X iff every open set in X intersects D. So, D = {1, 3, 4}. To make sure this is right, we can see if Cl(D) = X. The closed sets in X are {{1, 2, 3, 5}, {1, 3, 5}, {1, 2, 3}, {2, 3, 4, 5}, {1, 5}, {2, 3}, {1, 3}, {2, 4, 5}, {1, 2, 4, 5}, {1, 2, 3, 4, 5}}. The intersection of all closed sets containing D is {1, 2, 3, 4, 5} (it's the only set containing D, btw), so Cl(D) = X.
b) A mapping f between topological spaces is continuous iff the preimage of every open set in the codomain is open in the domain. For all sets in P(X) which are contained in U, this is obvious. If we take a set in P(X) (for example {2, 3}) which is not in U, then its preimage is the empty set, and hence is open in U. So, f is continuous.
Thanks in advance.
Hello, I would like to offer some feedback on your solution.
For part a), you correctly identified the dense subset as {1, 3, 4}. However, I would suggest using the definition of a dense subset as "a subset D of X is dense in X if every point in X is either an element of D or a limit point of D". In this case, every point in X can be obtained as the intersection of two or more open sets in U, so it is not necessary to check the closure of D. It would also be helpful to mention that the empty set is always a dense subset.
For part b), your reasoning is correct but it could be made more rigorous by explicitly stating that the preimage of an open set under a continuous map is open. Additionally, it would be helpful to mention that the preimage of any set under f is either the set itself or the empty set, which is always open.
Related to Another topology on the naturals
What is "Another topology on the naturals"?
"Another topology on the naturals" refers to a way of organizing the natural numbers (1, 2, 3, ...) into a topological space, which is a mathematical concept that describes the properties of how elements in a set are related to each other.
How is this topology different from the standard topology on the naturals?
The standard topology on the naturals is based on the concept of open intervals, where every natural number has a neighborhood of infinitely many other natural numbers. "Another topology on the naturals" is based on the concept of open sets, where neighborhoods of natural numbers can include only a finite number of other natural numbers.
What are the benefits of using this topology?
This topology allows for a more refined understanding of the structure of the natural numbers. It can also be used to explore different properties and relationships between natural numbers, such as convergence and continuity.
What are some applications of this topology?
This topology has various applications in the study of number theory, combinatorics, and other areas of mathematics. It can also be used in computer science and data analysis to analyze patterns and relationships in large datasets.
Are there any drawbacks to using this topology?
One potential drawback is that it may not be as intuitive or familiar as the standard topology on the naturals. It may also require more complex mathematical concepts and techniques to fully understand and apply.
