Another Way of Looking at Gravitational Time Dilation?
In summary, gravitational time dilation does not depend on acceleration, i.e. there are instances where the acceleration might be zero while there would be significant time dilation.
inflector
344
https://www.physicsforums.com/showthread.php?t=433866" that relativistic time dilation does not depend on acceleration, i.e. that there are instances where the acceleration might be zero while there would be significant time dilation. The example in the other thread was gravity and acceleration in the core of a spherical planet where there would be time dilation due to the gravitational potential even though there would be no acceleration due to gravity.
This made me wonder about time dilation itself.
Would it be equivalent to look at gravitational time dilation, not as time slowing down but rather as inertia increasing? Would there be any way of experimentally differentiating between these two perspectives? I.e. how can one tell the difference through experiment between the inertial mass of a system proportionally increasing and time slowing down?
It seems to me that one would only be able to determine inertial mass by looking at the effect of a given force on the acceleration of the mass using the equation F = ma. However, since both time (through the second derivative of position implied by acceleration) and mass are present in the formula, one can't really distinguish between time slowing down and inertial mass increasing.
Does this mean that gravitational time dilation could also really be seen as gravitational inertial mass increase if the two perspectives are mathematically equivalent? Or am I missing something obvious again?
Although you have a sort of point about inertia appearing to increase, there are some time dilation aspects such as biological processes, chemical reactions and characteristic emission spectrums of excited atoms, that are difficult to explain in terms of inertial mass increase.
What is unique to these sorts of biological processes and chemical reactions that couldn't be explained by an increase in inertial mass?
For example, harmonic oscillators change frequencies when the masses involved increase, likewise there are other dynamics involved in biological processes and chemical reactions that seem to me could be explained by increased inertial mass. So I'm not sure that these would be any different than any other dynamics involving time and mass.
I'm not saying that phenomena which can only be explained in terms of time do not exist. That's why I am asking the question here. I don't know the answer.
1. By what factor does the frequency decrease due to SRT?
2. By what factor does the inertial mass increase due to SRT?
3. By what factor does the natural frequency of a harmonic oscillator change when its inertial mass is increased?
4. Is 3 consistent with 1?
How about electrical currents? EM frequency? Subatomic decay?
There are plenty of phenomena that are not directly a result of mass.
NOTE: I am referring to a time dilation due to gravitation under general relativity not SRT.
Under my proposed potential equivalence, this mass adjustment factor would need to correspond to a time dilation for the relationship of:
[tex]F = ma = m\frac{\mathrm{d}^2x}{\mathrm{d}t^2}[/tex]
The differential equation for a harmonic oscillator extends the above to account for Hooke's Law:
[tex]F = -k x[/tex]
so we get the differential equation:
[tex]F = ma = m\frac{\mathrm{d}^2x}{\mathrm{d}t^2} = -k x[/tex]
Since I'm proposing that mass be adjusted according to the same underlying second-derivative-of-x-with respect-to-t equation:
[tex]F = m\frac{\mathrm{d}^2x}{\mathrm{d}t^2}[/tex]
the change in frequency for the harmonic oscillator would be consistent with that required to satisfy the equation itself almost by definition.
Good points, I can see how electrical currents would be related to the mass of the electron, but not EM frequency or subatomic decay.
Have there been measurements of gravitational time dilation that tested these two phenomena? Or have the measurements made so far been restricted to oscillator-based timing?
I don't see how there would be enough precision for measuring time using subatomic decay measurement, so this is probably out.
It's ubiquitous in particle accelerators. That's one of the commonest ways they confirm time dilation, by watching particles decay slower exactly in accordance with SR prediction.
Except that we're talking about stationary objects in gravitational time dilation in this case, not time dilation based on the Lorentz factor.
The time dilations are going to be orders of magnitude smaller in any cases we can measure on Earth as compared with the SR time dilation of a particle close to c.
:blush: GR/SR heh
:blush: GR/SR heh
Ok, so a black hole has infinite inertial mass?
Ich said:
:blush: GR/SR heh
I made a mistake. Answered too hastily.
Related to Another Way of Looking at Gravitational Time Dilation?
1. What is gravitational time dilation?
Gravitational time dilation is a phenomenon where time passes at different rates in different regions of space, due to variations in the strength of gravity.
2. How does gravitational time dilation occur?
Gravitational time dilation occurs because gravity warps the fabric of spacetime, causing time to pass more slowly in regions with stronger gravity. This is a consequence of Einstein's theory of general relativity.
3. What is an example of gravitational time dilation?
One example of gravitational time dilation is the difference in the passage of time experienced by someone standing on the surface of the Earth compared to someone in orbit around the Earth. The person in orbit experiences time passing slightly faster due to the weaker gravitational force.
4. How does gravitational time dilation affect our everyday lives?
Gravitational time dilation is a very small effect and only becomes significant in extreme conditions, such as near massive objects like black holes. It does not have a noticeable impact on our everyday lives.
5. Is gravitational time dilation the same as time travel?
No, gravitational time dilation does not allow for time travel. It simply means that time passes at different rates in different regions of space, but does not allow for someone to travel backwards or forwards in time.
