Another word problem involving a linear system.
In summary: Re: Another word problems.there are 8 pints in a gallon and 4 quarts in a gallon. In summary, the company purchased 20 quart jugs, 40 pint jugs, and 12 gallon jugs for the picnic, totaling 22 gallons of lemonade. This was calculated by setting up equations and using the conversion rates between pints, quarts, and gallons.
paulmdrdo1
385
during its annual picnic, a company supplies lemonade for all employees and their families. the picnic committee has purchased twice as many pint jugs as quart jugs and 8 fewer gallon jugs than quart jugs. how many jugs of each type are there if 22 gallons of lemonade were purchased? (there 2 pints to a quarts and 4 quarts to a gallon.)
let
$x$= number of quart jugs
$2x=$ number pint jugs
$x-8$ = number of gallon jugs.
can you help me how i will set up my equation?
Mathematics news on Phys.org
You want to add up the number of gallons that each set of jugs can hold, and equate this to the total number of gallons purchased.
For example, if you have 12 quart jugs, how many gallons do they contain?
You will, of course, need to know how many pints there are in gallon and how many quarts in a gallon.
let
Your equations are set up well. The next step would be to make sure your units are all the same - for this exercise I would recommend using pints.
Can you work out from the information given how many pints there are in a quart and how many pints in a gallon?
i will use the unit of gallons here
$x=$ number of quart jugs
$x−8$= number of gallon jugs
using the given information i'll have
$\frac{1}{4}x=$ # of quart jugs(in gallons)
$\frac{1}{4}x=$ # of pint jugs(in gallons)
$\frac{1}{4}x-8=$ # of gallon jugs.
setting my equation,
$\frac{1}{4}x+\frac{1}{4}x+\frac{1}{4}x-8=22$
$\frac{3}{4}x=30$
$3x=120$ then, $x=40$
now i have,
$40$ quart jugs. converting it to gallons i'll have 10 gallons.
$80$ pint jugs equivalent also to 10 gallons.
$40$quartz-8= $(10-8)$gallons = 2 gallons
10gallons+10gallons+2gallons=22 gallons.
i think i got it right. but can you give me comment on my solution.
i also tried solving by choosing unknown represent $x=$# gallons jug and this is what i get,
$x=$# of gallon jug.
$x+8$=# of quart jug ---> convert to gallons
$2x+16=$#of pint jug----> convert to gallons
then,$x=$# of gallon jug
$\frac{1}{4}x+2=$#of quart jug(in gal.)
$\frac{1}{4}x+2=$# pint jug (in gal.)
$x+\frac{1}{4}x+2+\frac{1}{4}x+2=22$
$\frac{2}{4}x+x+4=22$
$x=12$
now there is 12 gallon jug, 5 gallon jug(20 quart jug), 5 gallon jug(40 pint jug).
12+5+5= 22 gallons. the total gallons matches. but the individual gallons doesn't conform with my solution above. which one is correct? please help!
let
Using your variables, I then obtained the following equation:
\(\displaystyle \frac{2x}{8}+\frac{x}{4}+x-8=22\)
\(\displaystyle \frac{3x}{2}=30\)
\(\displaystyle x=20\)
Hence, there are 40 pint jugs, 20 quart jugs, and 12 gallon jugs.
how do you get these terms $\displaystyle \frac{2x}{8}+\frac{x}{4}+x-8$
and also, can you pin point what's my mistake in my first and 2nd solution. thanks!
How many pints are in a gallon? How many quarts?
FAQ: Another word problem involving a linear system.
What is a linear system?
A linear system is a set of equations that involve two or more variables and can be solved using algebraic methods such as substitution or elimination.
How do you solve a linear system?
There are several methods for solving a linear system, including substitution, elimination, and graphing. The chosen method will depend on the specific equations given in the system.
Can a linear system have more than two equations?
Yes, a linear system can have any number of equations as long as there are at least two equations and the equations are not all dependent on each other.
Is it possible for a linear system to have no solution?
Yes, a linear system can have no solution if the equations are parallel and do not intersect. In this case, the system is considered inconsistent.
How is a linear system used in real-world applications?
Linear systems are used in many fields, including engineering, economics, and physics, to model and solve real-world problems. For example, they can be used to determine the optimal solution for a system with multiple constraints, such as maximizing profits while minimizing costs.
