MHB Another work to paint house problem
  • Thread starter Thread starter karush
    Paint Work
Clarissa and Shawna can paint a house together in 6 days, with Clarissa taking 5 days less than Shawna to complete the job alone. The equation derived from their combined work rate leads to a quadratic equation, which simplifies to find Clarissa's solo work time. Solving the equation reveals that Clarissa can paint the house by herself in 10 days. The discussion emphasizes the clarity and correctness of the solution compared to other sources. Ultimately, the conclusion is that Clarissa's time to complete the job alone is 10 days.
karush
MHB
Clarissa and Shawna, working together, can paint the exterior of a house in $$6$$ days. Clarissa by herself can complete this job in $$5$$ days less than Shawna. How long will it take Clarissa to complete the job by herself?
well if they work equally then
$\frac{1}{12}+\frac{1}{12}=\frac{1}{6}$
but I didn't know how to change this to match what the problem says.
The answer is "Clarissa 10 days by herself".
Mathematics news on Phys.org
how about this if $c =$ Clarissa then
$$\frac{1}{c+5}+\frac{1}{c}=\frac{1}{6}$$
For this problem, we'll start more generally:
Given that it takes them 6 days to paint the house, we can let $c$ and $s$ be the rate of painting in days/house. Then, one way of setting an equation (such that the units cancel) and works with the question:
$$6 \text{ days }\cdot\left( \frac{1}{c \frac{\text{days}}{\text{house}}}+\frac{1}{s \frac{\text{days}}{\text{house}}}\right) = 1 \text{ house}$$
From the second part of the question, we can formulate another equation. What is it?
That is correct because we know that $c=s-5$, then $s=c+5$ and we can plug that back into the first equation. How can we solve for $c$? (Wondering)
ok from this I got by LCD $$c^2-7c-30=0$$ factoring
$$\left(c+3\right)\left(c-10\right)=0$$
so $C$ has to positive $C=10$ days I saw some other solutions to this on the internet but MHB is really the best place to be. some solutions elsewhere really got messy with wrong answers
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
