Answear to magnitude of an object slowing to a halt? negative or positive?
In summary, the conversation discussed the calculation of the magnitude of acceleration and unbalanced force for an object slowing to a stop. The magnitude of acceleration was found to be -5.1m s^-1 and the unbalanced force was calculated to be -7650 N. There was some confusion about the direction of acceleration and force, but it was clarified that the signs represent the direction of the vector. It was emphasized to choose a direction as positive and stick to it throughout the problem.
tommyboo
I have calculated magnitude of acceleration of an object slowing to a stop to be:
-5.1m s^-1.
I then had to find the magnitude of the unbalnced force applied to the object for it to stop which i found to be:
So F= 1500 kg * 5.1 m s^-2
Which equals 7650kg m s^-2
Which equals 7650 N
I have assumed this answear would have to be positive. so would this mean my answear in the first part should be positive and described as decelerating ?
Any help would be most welcome!
The direction of the acceleration is the same as the direction of the force (that doesn't seem to be the case in your calculation). How is there any confusion if you get your arrows right in the first place and stick with any signs that come out of the calculation?
It may help if you avoid using the word "deceleration". It really doesn't help except, perhaps, when you're driving. Just use negative acceleration when you are subtracting velocity (per second). That will end up with the velocity becoming negative (backwards) eventually.
So as the magnitude of the aceleration is - 5.1m s^-1
the force applied to the object woulb be -7650 N
or am I getting mixed up still?
The magnitudes of acceleration and anything else are always positive. The actual acceleration (and force) in this case is negative as your positive direction is the direction in which the mass is initially moving.
I am still unsure if the answears should be positive or negative if someone could explain to me each case it would be a great help.
Velocity, acceleration, force and others are vectors. Vectors have a magnitude (their numerical size) and direction. In your problem, the opposite directions are represented by positive or negative signs attached to the magnitude.
If you say a force is 27 Newtons, its direction is the same as if it were expressed as +27 Newtons.
Correct. Mr Newton says this, too. The acceleration is in the same direction of the force so, whatever axes you choose, they will have the same sign.
Sophiecentaur, you are correct that both the accleration and net force arenegative in this problem.
The essential thing with these problems is just to choose a direction as 'positive' and stick to the convention. I frequently have students who worry about whether to use UP or DOWN as positive for falling off cliffs and shooting rockets upwards etc. problems. They are very dubious when I tell them that it doesn't matter as long as they stick to their choice throughout. "Yebbut . . .?" I guess it's a confindence thing.
thank you that has helped clear it up.
FAQ: Answear to magnitude of an object slowing to a halt? negative or positive?
What is the meaning of "magnitude" in relation to an object slowing to a halt?
Magnitude refers to the size or extent of something, in this case, the speed or velocity of an object as it slows down to a complete stop.
How does the direction of the object's movement affect the answer to the question?
The direction of the object's movement does not affect the answer to the question. The magnitude of an object's velocity is a scalar quantity, meaning it is only concerned with the magnitude or size of the velocity, not its direction.
Is a negative or positive answer to this question more desirable?
Neither a negative nor positive answer is more desirable. The sign of the answer (negative or positive) depends on the initial velocity of the object and the direction in which it is slowing down. Both negative and positive values can be used to accurately describe the magnitude of the object's velocity as it slows to a halt.
How is the magnitude of an object's velocity calculated?
The magnitude of an object's velocity can be calculated using the formula: magnitude = |velocity|, where || denotes the absolute value. This means that the magnitude is equal to the numerical value of the velocity, regardless of its sign.
Are there any real-life applications for understanding the magnitude of an object slowing to a halt?
Yes, understanding the magnitude of an object's velocity as it slows to a halt is important in various fields such as physics, engineering, and transportation. For example, in transportation, knowing the magnitude of an object's deceleration is crucial for ensuring safe stopping distances and avoiding accidents.
