MHB Answer:Finding Value of k & Probability of A Winning at Least 2 Matches
  • Thread starter Thread starter Kudasai
In a series of 10 ping-pong matches, player A has a winning probability of 0.2. For part a), the probability of A winning exactly k matches does not match the given probability of 0.888 for any integer k, suggesting a possible error in the problem statement. For part b), the probability that A wins at least two matches can be calculated by subtracting the probabilities of A winning zero or one match from 1. The correct approach involves using the binomial probability formula to compute these probabilities accurately. The discussion highlights the need for careful calculation in probability problems.
Kudasai
Two ping-pong players $A$ & $B$ play a series of 10 matches. The probability that $A$ wins any of the matches is $0.2$
a) If the probability that $A$ wins exactly $k$ matches in the series is $0.888$. What's the value of $k$?
b) What's the probability that $A$ wins at least two matches?
I ain't good with these stuff, so I hope you guys may help me please. :D
The part a) states that $A$ could win 2, 3, 5 or 8 matches and the probability is the same, is this assumption correct? How to find the value of $k$?
As for b), how can I compute the asked probability? I know that $A$ has probability of wining any of the patches with value $0.2$, but when it says "at least," I can understand it.
Thank you.
Thank you.
The probability that A wins k games of the 10 games is... $\displaystyle P \{k=0 \} = \binom {10}{0}\ .2^{0}\ .8^{10} = .10737...$
$\displaystyle P \{k=1 \} = \binom {10}{1}\ .2\ .8^{9} = .2684...$
$\displaystyle P \{k=2 \} = \binom {10}{2}\ .2^{2}\ .8^{8} = .3019...$
$\displaystyle P \{k=3 \} = \binom {10}{3}\ .2^{3}\ .8^{7} = .201326...$
... and it is fully evident that P= .888 doesn't correspond to any value of k. The probability $P\{k \ge 2\}$ is... $\displaystyle P\{k \ge 2\} = 1 - P\{k = 0\} - P\{k= 1\}\ (1)$
Kind regards
$\chi$ $\sigma$
I agree with chisigma that for part a) there is no solution, however, I suspect the given probability should be approximately 0.088. Then we may write:
$${10 \choose k}(0.2)^k(0.8)^{10-k}\approx0.088$$
Try successive values for $k$.
For part b) I would use the fact that:
$$P(\text{A wins less than two})+P(\text{A wins at least two})=1$$
We can arrange this as:
$$P(\text{A wins at least two})=1-P(\text{A wins zero OR A wins 1})$$
Can you proceed?
Okay so I have for b) that
$P(A)=1-P(A^c),$ so $P(A)=1-0.2=0.8.$ Is it correct? I think it's too easy to be correct.
Thanks.
Thanks.
Yes, that's not correct. You want:
Now, we may write:
$$P(\text{A wins zero OR A wins 1})=P(\text{A wins zero})+P(\text{A wins one})$$
And apply the binomial probability formula to each event on the right.
Hello, I'm joining this forum to ask two questions which have nagged me for some time. They both are presumed obvious, yet don't make sense to me. Nobody will explain their positions, which is...uh...aka science. I also have a thread for the other question. But this one involves probability, known as the Monty Hall Problem. Please see any number of YouTube videos on this for an explanation, I'll leave it to them to explain it. I question the predicate of all those who answer this...
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
