MHB Answer: How Many Elementary Operations for Adding Two Numbers with $n$ Digits?
  • Thread starter Thread starter mathmari
    Operations
The discussion centers on the concept of elementary operations in arithmetic, specifically regarding the addition and multiplication of n-digit numbers. It is established that adding two n-digit numbers requires at least n elementary operations, as each digit must be processed along with any carry from previous additions. When it comes to multiplication, the conversation shifts to the complexity involved. The traditional method of multiplying two n-digit numbers necessitates n² elementary multiplications and approximately 2n-1 elementary additions. However, the Fast Fourier Transform (FFT) offers a more efficient approach, potentially reducing the number of required operations to about cn log n, where c is a constant. The relationship between FFT and multiplication is explained through the convolution theorem, which allows for faster computation of the product of two polynomials represented by the n-digit numbers. While the exact workings of this method remain somewhat unclear to participants, its efficiency compared to traditional multiplication is acknowledged.
mathmari
MHB
Hey! :o
With the term "elementary operation" we mean to add two digits of the decimal system and to write the result and the carries. How many elementary operations do we need for the addition of two numbers with $n$ digits?
(we consider that the addition of two digits together with the carry that comes from previous operations is one elementary operation)
If we add two numbers with $n$ digits, we add at each step two digits, one of each number, and possibly a carry. That means that we need $n$ elementary operations.
Is this correct?
How could we show that the addition of any two numbers with $n$ digits each one of them, cannot be done with less than $n$ steps/elementary operations?
Technology news on Phys.org
Hey! (Smile)
Yes, that is correct. (Nod)
To add two n-digit numbers, each digit will have to be processed.
So we need at least n operations. (Wasntme)
(Smile)
I see... What about the multiplication? In this case we have to count separately the number of elementary additions and elementary multiplications (i.e., multiplications of two digits and writing the carries).
Can the multiplication of two $n$-digit numbers be done in less than $n$ elementary multiplications?
(we have to notice that the answer is not obvious as in the case of the addition. It can be done in about $cn \ln n$ elementary multiplications, for a constant $c$. This can be achieved using the Fast Fourier Transform. It is not known if this bound is optimal.) To multiplicate two $n$-digit numbers, do we not have to execute $n^2$ elementary multiplications and $2n-1$ elementary additions?
Could you explain to me how the Fast Fourier Transform is related to the multiplications of two numbers?
The straight forward way to multiply requires indeed $n^2$ elementary multiplications.
After that, I think it takes $n^2-1$ elementary additions though. (Wasntme)
Well, this is the first time I hear about it.
Let me see... (Thinking)
If we multiply $\sum a_i 10^i$ with $\sum b_j 10^j$, we get:
$$\sum_i a_i 10^i \cdot \sum_j b_j 10^j
= \sum_i\sum_j (a_i 10^i) \cdot (b_j 10^j)
= \sum_m\sum_i (a_i 10^i) \cdot (b_{m-i} 10^{m-i})
= \sum_m c_m
This is the sum of a sequence of convolutions, meaning we can apply the convolution theorem:
c_m = \mathscr F^{-1}\{\mathscr F\{a_m10^m\} \cdot \mathscr F\{b_m10^m\}\}
Since the FFT takes $O(n\log n)$ operations, evaluating all $c_m$ also takes $O(n\log n)$ operations.
After that they only need to be summed.
To be honest, I'm still not clear how it would work exactly, but I suspect it works something like this. (Wasntme)
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
I am trying to run an .ipynb file and have installed Miniconda as well as created an environment as such -conda create -n <env_name> python=3.7 ipykernel jupyter I am assuming this is successful as I can activate this environment via the anaconda prompt and following command -conda activate <env_name> Then I downloaded and installed VS code and I am trying to edit an .ipynb file. I want to select a kernel, via VS Code but when I press the button on the upper right corner I am greeted...
