Answer Sequence: 15+30+60+120+240+480+960=1905
  • MHB
  • Thread starter Ilikebugs
  • Tags
    Sequence
In summary, to find the $p$th term in the given sequence, we can use the formula $D(p)=\left\lceil \frac{-1+\sqrt{8p+1}}{2}\right\rceil\mod5$, where $D$ represents the $p$th digit and $p$ is the position in the sequence. This formula was used to confirm that the $2017$th term in the sequence is $4$.
Ilikebugs
94
I did 15+30+60+120+240+480+960 to get 1905, then continued the sequence to get 4. Is this right?
Mathematics news on Phys.org
Let's find the $p$th term.
I think what I would do is set:
\(\displaystyle \frac{n(n+1)}{2}=p\)
Now solve for $n$...
\(\displaystyle n(n+1)=2p\)
\(\displaystyle n^2+n-2p=0\)
Using the quadratic formula, and discarding the negative root, we find:
\(\displaystyle n=\frac{-1+\sqrt{8p+1}}{2}\)
We are interested in the smallest integer greater than $n$, so we use
\(\displaystyle \left\lceil \frac{-1+\sqrt{8p+1}}{2}\right\rceil\)
Since the digits 1-5 repeat, then the $p$th digit $D$ is:
\(\displaystyle D(p)=\left\lceil \frac{-1+\sqrt{8p+1}}{2}\right\rceil\mod5\)
And we find:
\(\displaystyle D(2017)=4\quad\checkmark\)
FAQ: Answer Sequence: 15+30+60+120+240+480+960=1905
What is the pattern in this answer sequence?
The pattern in this answer sequence is that each number is being multiplied by 2 to get the next number in the sequence. For example, 15 x 2 = 30, 30 x 2 = 60, and so on.
What is the last number in this answer sequence?
The last number in this answer sequence is 1905. This is found by multiplying the previous number, 960, by 2.
How many terms are in this answer sequence?
There are 7 terms in this answer sequence. This can be determined by counting the number of numbers in the sequence, starting from 15 and ending at 1905.
What is the total sum of all the numbers in this answer sequence?
The total sum of all the numbers in this answer sequence is 1905. This can be found by adding each number in the sequence, starting from 15 and ending at 960, and then adding the last number, 1905.
How can this answer sequence be written in mathematical notation?
This answer sequence can be written as an arithmetic sequence, with the first term being 15 and the common difference being 15. The formula for an arithmetic sequence is an = a1 + (n-1)d, where a1 is the first term, n is the term number, and d is the common difference. So, the formula for this answer sequence would be an = 15 + (n-1)15.
