Answer the question about time of cooling of a ball
In summary: The law of heat conduction, also known as Fourier's law, states that the rate of heat transfer through a material is proportional to the negative gradient in the temperature and to the area, at right angles to that gradient, through which the heat flows. In the context of the question, this means that the ball will cool down the most in case #1, and the least in case #2.
Hurcane
Answer the following question:
"In which of the cases will the cooling time be the least:
1. the ball is suspended from the ceiling
2.the ball lies on a stand with a thermal conductivity greater than the thermal conductivity of the ball
3. is the ball lying on a stand with a thermal conductivity lower than the thermal conductivity of the ball?"
Hello, I'm not sure if this is the right place to post my question, however I still want to know. Recently, my teacher asked me the following question:
3. the ball lying on a stand with a thermal conductivity lower than the thermal conductivity of the ball"
I am not strong in physics, so I could not fully state the answer.
Thank you in advance for any help.
Welcome to PF.
What do you think is the correct answer and why? And why is #3 a question instead of statements like #1-#2?
Hi!
Number three should be the statement, this is my mistake. As for my opinion on the question, I believe that the ball will cool down the longest in case #1, and the least in case #2, case #3 will be between case #1 and case #2. But I can't back it up with any formulas.
Welcome to PF.
I think that is close to correct. Does the problem mention what temperatures the ball, air and stand are at initially?
No, but as far as I understand, it is assumed here that the temperature of the ball is higher than the temperature of the stand, and the air temperature is much lower than the temperature of the ball. The temperature of the stand is most likely the same as the air temperature (according to Newton's cooling law).
Question for @Hurcane: Which pair of conductivities makes more sense to compare in order to answer 3? Remember that something with very low thermal conductivity is called a thermal insulator.
A. Air and ball
B. Air and stand
C. Ball and stand
Likes Lnewqban
A. Air and ball
B. Air and stand
C. Ball and stand
As far as I know, air is a strong thermal insulator. Therefore, the ball in case #1 will cool down more slowly than in case #3, right?
We are told that the conductivity of the stand is lower than that of the ball. What if it’s also lower than that of the air?
Likes jbriggs444
I don't think this condition is implied in the task. But if we consider it, it turns out that the longest cooling time will be in case #3
I agree.
I don't see that the question is complete. Case #3 could be an insulating stand with better insulation that air. It simply doesn't say.
Maybe it's even more complicated...
Cooling of the ball will be due a mixture of conduction, convection and radiation. If the ball has only a tiny contact-area with the (say flat) stand, then conduction from the ball to the stand might be negligible! And the presence of the stand might reduce convective losses!
Likes nasu and Lnewqban
Copied from
https://en.m.wikipedia.org/wiki/Thermal_conduction#Fourier's_law
“The law of heat conduction, also known as Fourier's law, states that the rate of heat transfer through a material is proportional to the negative gradient in the temperature and to the area, at right angles to that gradient, through which the heat flows.”
Welcome, Hurcane!
FAQ: Answer the question about time of cooling of a ball
How can the time of cooling of a ball be calculated?
The time of cooling of a ball can be calculated using the formula t = (m x c x ΔT) / h, where t is the time in seconds, m is the mass of the ball in kilograms, c is the specific heat capacity of the ball in joules per kilogram per degree Celsius, ΔT is the change in temperature of the ball in degrees Celsius, and h is the heat transfer coefficient in watts per square meter per degree Celsius.
What factors can affect the time of cooling of a ball?
The time of cooling of a ball can be affected by factors such as the material and size of the ball, the initial temperature of the ball, the surrounding temperature, and the surface area of the ball.
How does the material of the ball affect its time of cooling?
The material of the ball can affect its time of cooling because different materials have different specific heat capacities and thermal conductivities. This means that they will absorb and release heat at different rates, resulting in different cooling times.
Can the time of cooling of a ball be changed?
Yes, the time of cooling of a ball can be changed by altering the factors that affect it. For example, increasing the surface area of the ball or decreasing the surrounding temperature can result in a faster cooling time.
How is the time of cooling of a ball related to its temperature?
The time of cooling of a ball is directly related to its temperature. As the ball cools, its temperature decreases and the rate of cooling slows down. This means that the time of cooling will be longer for a ball with a higher initial temperature compared to one with a lower initial temperature.
