Answer to high-school question
  • Thread starter mzambani
In summary, the conversation discusses a sequence of terms involving mass and velocity in physics, and how it relates to conservation of mass, momentum, and energy. The mathematical sum of the sequence is also explored, but it is noted that the units do not make sense. The conversation ends with the conclusion that the sequence has no meaning in physics due to the issue with units.
mzambani
Hello,
When I was studying physics in high-school, I often wondered what would be the meaning of sequence below in physics...
m + mv + mv2 + mv3 + ...
This is equivalent to
[tex]\sum[/tex]mvn for n=0 to infinity
where m is mass, and v is velocity.
The though process was, that if mass (m) is conserved, momentum (mv) is conserved, and a form of energy (1/2 mv2) is conserved, then their sum probably should be conserved as well - resulting in above rudimentary sequence.
I never studied physics further, but I always wanted to see what this sequence - if any, would mean in physics. Can some one point me to it? Since velocity (v) is directional, I could never figure out how it can be summed in a sequence like this...
Mathematics news on Phys.org
Units don't allow summation. Adding kg to kg*m/s to J and so on doesn't make sense.
Thank you Borek. It is so obvious, and I did not see it...this sequence has no meaning in physics.
As a purely mathematical sum, it does have sense:
[tex]\sum mv^n= m \sum v^n[/tex]
is a "geometric series". If -1< v< 1, its sum is
[tex]\frac{m}{1- v}[/tex]
But yes, Borek is correct. If v has units of "distance/time" then the series, or even just "m+ mv+ mv^2" has impossible units.
I remember I re-wrote it into this form:
m + mv + 1/2 mv2 + 1/6 mv3 + ...
m + 1/1! mv + 1/2! mv2 + 1/3! mv3 + ...
m ( 1 + v/1! + v2/2! + v3/3! + ...)
which is equal to
mev (using exponential series)
But then I could never think of any meaning of ev..what could possibly be e to the power of "velocity"?
By taking it further...
m*ev = some constant (k)
then
ev = k/m
so
v = log(k/m)
where v is velocity and m is mass
There is an issue with units again. Exponents must be unitless.
HallsofIvy, Redbelly98 - thank you for taking time to answer my question. Yes, I realize there is issue with units. My curiosity is satisfied. Thanks.
FAQ: Answer to high-school question
What is the "Answer to high-school question"?
The "Answer to high-school question" is a general term used to refer to the solution or explanation to a question commonly asked in high school, usually related to a specific subject or topic.
Can you give an example of an "Answer to high-school question"?
Some examples of "Answer to high-school question" include the explanation of the Pythagorean theorem in math, the definition of photosynthesis in biology, or the causes of World War II in history.
Why is it important to know the "Answer to high-school question"?
Knowing the "Answer to high-school question" is important because it helps students understand and apply key concepts in their studies. It also prepares them for higher education and real-world scenarios where critical thinking and problem-solving skills are essential.
How can I find the "Answer to high-school question" if I don't know it?
You can find the "Answer to high-school question" by doing research, consulting with teachers or peers, and using educational resources such as textbooks, online articles, and study guides. It is also helpful to practice problem-solving and critical thinking skills to arrive at the answer.
Are there different "Answers to high-school question" for different high schools?
The "Answer to high-school question" may vary depending on the curriculum and teaching methods of different high schools. However, the core concepts and principles remain the same, and the "Answer to high-school question" should ultimately lead to the same understanding and application of knowledge.
