MHB Answerer's question at Yahoo Answers regarding a trigonometric equation
The discussion addresses a trigonometric equation, specifically 3sin²x - 2sinx - 3 = 0, within the interval 0 < x < 2π. The equation is identified as a quadratic in sin(x), and the quadratic formula is applied to find the roots. After determining the valid solution, it is noted that the sine value leads to two angles: one in the fourth quadrant and another in the third quadrant. Decimal approximations for these angles are provided for clarity. The conversation encourages further trigonometry questions to foster engagement in the forum.
MarkFL
MHB
Here is the question:
PRE-CALC QUESTION!? HELP !?
0<x<2π
3sin^2x - 2sinx - 3 = 0
You can use a calculator and there's only 2 answers
Here is a link to the question:
PRE-CALC QUESTION!? HELP !? - Yahoo! Answers
I have posted a link there to this topic so the OP can find my response.
Mathematics news on Phys.org
Re: answerer's question at Yahoo! Answers regarding trigonometric equation
Hello answerer,
We are given to solve:
$$3\sin^2(x)-2\sin(x)-3=0$$ where $$0<x<2\pi$$
Recognizing that we have a quadratic in $\sin(x)$, we may use the quadratic formula to state:
$$\sin(x)=\frac{-(-2)\pm\sqrt{(-2)^2-4(3)(-3)}}{2(3)}=\frac{2\pm\sqrt{40}}{6}=\frac{1\pm\sqrt{10}}{3}$$
Since we require $$-1\le\sin(x)\le1$$ we discard the positive root, and we are left with:
$$\sin(x)=\frac{1-\sqrt{10}}{3}$$
Hence:
$$x=\sin^{-1}\left(\frac{1-\sqrt{10}}{3} \right)$$
Since this is less than zero, we need to add $$2\pi$$ to get the equivalent angle in the required interval:
$$x=2\pi+\sin^{-1}\left(\frac{1-\sqrt{10}}{3} \right)$$
Now, this is the 4th quadrant solution, but we should observe there is also a 3rd quadrant solution, given by:
$$x=\pi-\sin^{-1}\left(\frac{1-\sqrt{10}}{3} \right)$$
Note: this comes from the identity $$\sin(\pi-\theta)=\sin(\theta)$$.
If we are to use a calculator to obtain decimal approximations, then:
$$x=2\pi+\sin^{-1}\left(\frac{1-\sqrt{10}}{3} \right)\approx5.47828834852818$$
$$x=\pi-\sin^{-1}\left(\frac{1-\sqrt{10}}{3} \right)\approx3.9464896122412$$
To answerer and any other guests viewing this topic, I invite and encourage you to post other trigonometry questions here in our http://www.mathhelpboards.com/f12/ forum.
Best Regards,
Mark.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
