Ansys Basic Structure random Force/Deformation
In summary, the conversation discusses a problem with a structure bending to the left and a force acting in the x-direction. The solution is to add a horizontal constraint at the top joint to prevent the structure from rotating. The conversation also mentions the importance of not posting wide images directly to the forum page.
Po1ng
Ok I've been surfing trough the internet for quite some time now trying to find a solution to my problem but nothing similair pops up.
This is my problem:
http://i40.tinypic.com/295dc9f.png
For some peculiar reason the structure tends to bend over to the left. I have no idea why and I've tried to change te thickness and strength of the center Link/2d Spar without any luck.
The results show a force acting in the x direction in the top and bottom as if some kind of torque is applied..
When I remove the center piece the results do not include the erroneous force/deformation and it just streches while keeping the horizontal bar absolutely horizontal.
Does anybody know why this deformation is not symmetric ?
Po1ng: Yes, it appears your structure is unstable; therefore, the structural analysis solution is ill-conditioned. Therefore, the slightest numerical inaccuracy (random round-off error) might cause the structure to rotate to one side or the other, randomly.
Add a horizontal constraint (Tx) at the top joint in your structure, where your applied load is applied, to prevent your structure from rotating about the bottom joint in your structure (where your Tx and Ty translational constraints are currently located).
By the way, please do not post wide images directly to the forum page. If your image is wider than 640 px (pixels), just post a plain text link to the image.
Thank you very much! It totally makes sense now that you've explained it. You've just made my day nvn! Now I can finally continue with learning Ansys.
Sorry about the awfully wide pic.
FAQ: Ansys Basic Structure random Force/Deformation
What is Ansys Basic Structure random Force/Deformation?
Ansys Basic Structure random Force/Deformation is a feature in the Ansys software used for structural analysis. It allows you to apply random forces or deformations to a structure and analyze its response. This can be useful in predicting the behavior of a structure under varying and unpredictable conditions.
How do I use Ansys Basic Structure random Force/Deformation?
To use this feature, you need to first create a structural model in Ansys. Then, you can select the random force/deformation option and specify the magnitude, direction, and distribution of the random load. Finally, you can run the analysis and view the results.
What types of random forces/deformations can be applied in Ansys Basic Structure?
Ansys Basic Structure allows you to apply various types of random forces or deformations, such as random vibrations, thermal loads, wind loads, and seismic loads. You can also apply combinations of these loads to simulate real-world conditions.
How accurate are the results from Ansys Basic Structure random Force/Deformation?
The accuracy of the results depends on the accuracy of the input parameters and the assumptions made in the analysis. Ansys Basic Structure uses advanced algorithms and techniques to simulate random loads and provide accurate results. However, it is always recommended to validate the results with physical testing.
Can Ansys Basic Structure random Force/Deformation be used for all types of structures?
Yes, Ansys Basic Structure can be used for a wide range of structures, including buildings, bridges, aircraft, and mechanical components. However, the complexity and accuracy of the analysis may vary depending on the type of structure and the level of detail in the model.
19K
