ANSYS Mechanical APDL - High Temperature Creep Modeling via Isochronous Curves
In summary, ANSYS can be used to model creep in a number of different ways. If you are designing to ASME Section VIII, Div., 2 you might have to verify that your design meets the "shake down to elastic action" criteria. Basically, that means that the strains do not continue to increase over the number of cycles.One way to do this is to use the TB,MISO command in ANSYS and then fill the table with stress and strain at each temperature. Obtaining the values for the stress and strain as a function of time and temperature is the hardest part however, there are some places they can be obtained and a method that can be used to create them if you are using common place materials.MISO
CFDFEAGURU
783
MISO stands for Multilinear Isotropic Hardening using von Mises or Hill plasticity
If you are using the following materials then the stress and strains can be read from the isochronous curves found in ASME Section III, Division 1, Subsection NH
304 SS to a maximum temperature of 1500 F
316 SS to a maximum temperature of 1500 F
800H to a maximum temperature of 1400 F
2 1/4 Cr. - 1 Mo. to a maximum temperature of 1200 F
9 Cr - 1 Mo. - V to a maximum temperature of 1200 F
Some of these curves can be found in "Design and Analysis of ASME Boiler and Pressure Vessel Components in the Creep Range" by Jawad and Jetter. (Least expensive route)
If you have access to API-579 then you can use the Omega Method. This will require you to write a spreadsheet with the end result being a set of isochronous curves that can be used to load the TB,MISO command.
You will have to have already solved your model for the temperature distribution and then use the LDREAD command on your structural model to read in the appropriate temperature distribution per load step. Depending upon the loading, you will probably have to "fool" with the number of substeps command, NSUBST, to achieve convergence.
A 3D solid model is NOT required for this, 2D shell elements work just fine.
Example
TB,MISO,1,5,34
TBTEMP,1200
TBPT,DEFI,4.3020E-05,912.00
TBPT,DEFI,5.0192E-05,1064.00
TBPT,DEFI,5.7367E-05,1216.00
TBPT,DEFI,6.4550E-05,1368.00
TBPT,DEFI,7.1746E-05,1520.00
TBPT,DEFI,7.8964E-05,1672.00
TBPT,DEFI,8.6221E-05,1824.00
TBPT,DEFI,9.3535E-05,1976.00
TBPT,DEFI,1.0094E-04,2128.00
TBPT,DEFI,1.0846E-04,2280.00
TBPT,DEFI,1.1616E-04,2432.00
TBPT,DEFI,1.2411E-04,2584.00
TBPT,DEFI,1.3237E-04,2736.00
TBPT,DEFI,1.4107E-04,2888.00
TBPT,DEFI,1.5032E-04,3040.00
TBPT,DEFI,1.6030E-04,3192.00
TBPT,DEFI,1.7118E-04,3344.00
TBPT,DEFI,1.8321E-04,3496.00
TBPT,DEFI,1.9665E-04,3648.00
TBPT,DEFI,2.1185E-04,3800.00
TBPT,DEFI,2.2918E-04,3952.00
TBPT,DEFI,2.4911E-04,4104.00
TBPT,DEFI,2.7217E-04,4256.00
TBPT,DEFI,2.9898E-04,4408.00
TBPT,DEFI,3.3025E-04,4560.00
TBPT,DEFI,3.6683E-04,4712.00
TBPT,DEFI,4.0966E-04,4864.00
TBPT,DEFI,4.5984E-04,5016.00
TBPT,DEFI,5.1863E-04,5168.00
TBPT,DEFI,5.8746E-04,5320.00
You will also need stress and strain loading in the low temperature (non-creep) range. This can be done thru use of ASME Section VIII. Div., 2 Annex 3.D Strength Parameters.
Thanks for the post! Sorry you aren't generating responses at the moment. Do you have any further information, come to any new conclusions or is it possible to reword the post?
Related to ANSYS Mechanical APDL - High Temperature Creep Modeling via Isochronous Curves
What is ANSYS Mechanical APDL?
ANSYS Mechanical APDL (or ANSYS Classic) is a finite element analysis software used for structural and thermal analysis. It is primarily used in the engineering field for simulating and analyzing complex mechanical systems.
What is high temperature creep modeling?
High temperature creep modeling is a method used to predict the deformation and failure of materials under high temperatures and constant loads. It takes into consideration the time-dependent behavior of materials, which can be caused by thermal expansion, dislocation movements, and other mechanisms.
What are isochronous curves?
Isochronous curves are plots that show the relationship between stress and strain at different temperatures and time intervals. They are used in high temperature creep modeling to predict the long-term behavior of materials under constant load and high temperatures.
How does ANSYS Mechanical APDL use isochronous curves for high temperature creep modeling?
ANSYS Mechanical APDL uses isochronous curves to define the material properties and behavior at different temperatures and time intervals. These curves are then applied to the finite element model to simulate the creep behavior of the material under specific loading conditions.
What are the benefits of using ANSYS Mechanical APDL for high temperature creep modeling?
ANSYS Mechanical APDL offers a user-friendly interface, robust analysis capabilities, and advanced material models for accurate high temperature creep modeling. It also allows for complex simulation setups and provides detailed results, making it a valuable tool for engineers and scientists in the field of material behavior research.
  • Mechanical Engineering
30K
