Ansys Workbench 12 Assembly question
In summary, the conversation is about using Ansys Workbench to model a copper jacketed lead bullet. The question at hand is how to mate the two solids together to use as one assembly. The solution is to either use contact surfaces to join them with separate meshes, or use a matching mesh on the interface. The person also mentions importing from Solidworks and using a body function to translate the model and solve the issue.
beho86
25
Hello,
I am used to use Ansys classic in my work. I just started to learn Ansys Workbench. I am modeling a copper jacketed lead bullet. I modeled the copper case the internal lead part.
Now I have two solids. Is there a way to mate them, and use them as one assembly, of solids?
Thanks
There are 2 ways. Either have them meshed separately and use contact surfaces to join them, or have a matching mesh on the interface. In the latter case I imagine it solves it without contact elements, but not sure. I don't have access to ANSYS these days, but here are some pictures from a tutorial -
[PLAIN]http://dl.dropbox.com/u/21857463/MatchingMesh.png
[PLAIN]http://dl.dropbox.com/u/21857463/Contact1.png
[PLAIN]http://dl.dropbox.com/u/21857463/Contact2.png
Hello,
The picture in the tutorial you provided, the two bodies are already in contact, and you are defining the contact condition (such as no separation...), I tried the mesh, but I am not sure if that what I want. they body didn't move.
Here is a picture:
[PLAIN]http://img228.imageshack.us/img228/9561/bulletf.jpg
So, in solidworks I can just mate easily, and control them as an assembly, how can I do that in workbench?
Thanks
I can't see your picture, but I misunderstood you. Somehow I assume you can just import an assembly or a CAD geometry having several disconnected parts already positioned where you want them but not actually mated. It doesn't allow that?
Here is the image: http://img228.imageshack.us/img228/9561/bulletf.jpg
I tried to import from solidworks, it works, but didn't know how to position it on a specific axis. I still think, I should be able to make them one assembly.
I will keep trying, hopefully someone can help me with this issue. thx
Solved! I figured it out, you create a body function, and use the translation method, it will give you x, y, z coordinates to move the model to.
Thanks
Related to Ansys Workbench 12 Assembly question
1. What is Ansys Workbench 12 Assembly?
Ansys Workbench 12 Assembly is a computer-aided engineering software used for performing simulations and analyses on various mechanical, electrical, and structural systems. It allows for the creation of complex assemblies and their components, as well as the simulation of their behavior under different conditions.
2. How do I create an assembly in Ansys Workbench 12?
To create an assembly in Ansys Workbench 12, you first need to create individual parts or components. Then, you can use the "Insert" command to add these components into a new or existing assembly. You can also use the "Mate" command to define relationships between the components, such as constraints or connections.
3. What types of simulations can I perform on assemblies in Ansys Workbench 12?
Ansys Workbench 12 allows for various types of simulations to be performed on assemblies, including structural, thermal, fluid, and electromagnetic analyses. These simulations can be used to study the behavior of the assembly under different loads, temperatures, and environments.
4. Can I import CAD models into Ansys Workbench 12?
Yes, Ansys Workbench 12 has the ability to import CAD models from various software programs, such as SolidWorks, CATIA, and AutoCAD. This allows for more accurate and detailed assemblies to be created and analyzed.
5. Is Ansys Workbench 12 suitable for beginners?
Ansys Workbench 12 can be used by beginners, but it does have a steep learning curve. It is recommended to have some familiarity with CAD software and engineering principles before using the software. There are also tutorials and resources available to help new users get started.
  • Mechanical Engineering
10K
11K
