Antenna Radiation and propogation doubts
In summary, the conversation discusses doubts about antenna radiation and propagation, specifically regarding the power dissipated across radiation resistance for a Hertzian dipole antenna. The first doubt is about the equation for power and whether only half of the power is actually radiated. The second doubt is about the components of an electric field and their meaning. The conversation also touches on the possibility of using DC current to create an antenna and the conventions for AC currents and voltages. There is some confusion and disagreement about the definitions and formulas used in the textbook being referenced.
TheArun
25
I have a few doubts regarding antenna radiation and propogation. Kindly look into it and clarify.
Consider a Hertzian dipole antenna,
DOUBT # 1. Generally, when the power is mentioned for an antenna elements such as the power dissipated across radiation resistance(Rrad)
P radiated = (1/2)I2Rrad
Doubt:
1. Generally, Power equation is P = I2Resistance, but according to the above equation only 1/2 of the power across the radiation resistance is actually radiated. Is it a case of power lost and where?
2. Does the half term come from the equation of power across load allowing ac power i.e.,
P = Vrms * Irms cos@
By taking the peak value of V and I and denoting V in terms of I it changes to, P = (1/2)I2R. If that is the case does that mean that,
a) Current, without mentioning explicitly is always considered to be an 'ac current peak value which is in phase with voltage'
and
b) If that is the case, does that also mean that Hertzian dipole or a current element that radiates as an antenna can only be made using a ac current and not dc current?
DOUBT#2: Consider a electric field having θ and φ component i.e.,
E = Eθ aθ + Eφ aφ
where,
E - electric field vector
Eθ - electric field component in θ direction and Eφ - Electric field compo in φ direction
So my doubt is what actually is this Eθ(or Eφ) which is a scalor along θ direction:
Is it a angle in θ direction ie say 30 deg in θ direction OR is it a distance?
Doubt:
and
E = Eθ aθ + Eφ aφ
where,
Regarding Doubt 1, I think it is just confusion about peak and RMS.
Of course, up to half the power is wasted in the generator resistance, as with any system, but we normally specify transmitter power as that portion actually being delivered to the load. So all the transmitter output power is radiated.
For a receiving dipole, only half the incident power is delivered to the load, the remainder being re-radiated. This is also because of the source/load sharing issue.
Thanks for the reply.But you have not cleared my doubt. So, what is the current in the above equations? Is it peak value or rms value?
It is the convention that AC currents and voltages are RMS values unless stated otherwise. So your formula should use RMS current and should not include the factor 1/2.
It seems no one is here to clear this doubt.
Thanks tech99 for replying. The equation I wrote here is from a textbook, so may be they meant peak value.
But no one is saying about, is it possible to make with DC current or my 2nd doubt
Radiation resistance is a fudge factor. It directly represents the power radiated into space through special relativity. As such it should not include the ½ (as tech99 stated.). If it does in your textbook, it is either a mistake, or their definition of radiation resistance includes some other losses. (Resistive losses due to power matching in the antenna make some sense, but who can say?) For a more generally used equation, check Wikipedia.
Your second doubt should be defined by the conventions the book is using. Variables mean what they are defined to mean. Usually θ and φ are defined as angles (but this is not a requirement). So Eθ aθ sounds like the E field in the θ direction times some number/function a that's associated with θ somehow. (What or where the field is isn't clear.) But without more information, it's hard to tell. Given the earlier ½ I don't even want to guess at the meaning.
Changing magnetic fields make currents. Charges will also travel through resistances to make currents. But unless there's a way to regenerate these, you will not get a DC current. DC generators move the rotor through a constant rate of changing field. Batteries produce new charge at a constant rate.
I'm not sure what you want to do with your E field, but it should be possible to get a DC current through some combination of these techniques. (It might not be easy though.)
What I meant by Eθ aθ is just according to normal convention. Eθ is the component of electric field in θ direction(as in spherical coordinates) and aθ is the unit vector (it is 'a caps θ' , I cudn't find a proper symbol for that)
If it was in rectangular coods, Eθ is a distance in aθ direction...what about this coods?
FAQ: Antenna Radiation and propogation doubts
1. What is antenna radiation?
Antenna radiation is the process by which electromagnetic energy is radiated outwards from an antenna into free space. This radiation can then be received by other antennas, allowing for wireless communication.
2. How does antenna radiation work?
Antenna radiation works by converting electrical energy into electromagnetic waves, which are then emitted from the antenna. The type and direction of the radiation is determined by the antenna's design and the frequency of the signal being transmitted.
3. What factors affect antenna radiation?
The main factors that affect antenna radiation are the antenna's design, shape, and size, as well as the frequency of the signal being transmitted. Other factors such as the surrounding environment, obstacles, and nearby objects can also have an impact on radiation patterns.
4. What is antenna propagation?
Antenna propagation is the process by which electromagnetic waves travel from one point to another. This includes the transmission of signals from an antenna to a receiver, as well as the reflection, diffraction, and scattering of these waves as they encounter different objects or mediums.
5. How does antenna placement impact propagation?
The placement of an antenna can greatly impact propagation. Factors such as height, orientation, and surrounding objects can affect the direction, strength, and quality of the signal being transmitted or received. It is important to consider these factors when designing and installing an antenna for optimal performance.
