Anticommutation of Fermions and the Lorentz irreps
In summary: This leads to the spin-statistics theorem, which states that fields with integer spin are quantized as bosons, while fields with half-integer spin are quantized as fermions. Additionally, the anticommutation relations for fermionic operators are necessary in order to correctly derive the path integral for fermions. This is due to the fact that coherent states for fermions cannot have usual c-number eigenvalues, as it would lead to contradictions and incorrect results. Furthermore, the Poincare group representation theory plays a crucial role in determining the spin
Trifis
167
Hi everyone!
I have two questions that arose during the path integral quantization of theories involving fermions.
First of all, when we prove the equivalence between the path integral formalism and the canonical quantization we make use of the eigenvalue defining equation: [itex] \hat{φ}(x)|Φ>=φ(x)|Φ> [/itex] in order to get rid of the operators and start working with numbers.
My first question is: What happens when we try to find the eigenvalue of a fermionic field? To my understanding, the eigenvalues of creation/annihilation operators for fermions, somehow, have to be decomposable into normal functions, i.e. numbers, and Grassman numbers.
And then a more general consideration came to mind: Does the anticommutation property of fermionic operators follow solely from the Lorentz group representation theory? I know that Dirac spinor part of the fermionic field transforms as the (1/2,0)⊕(0,1/2) representation of the Lorentz group but what about the creation/annihilation operators? As far as I can tell, anticommutation relations are not imposed on the spinors but on the operators! In other words, is the usage of Grassman numbers justified by the spacetime symmetry or there is some other kind of fundamental axiom?
That there are only fermions and bosons in Nature is due to the topology of many-body configuration space. If you have a space dimension larger or equal to 3, this implies that there are only fermions and bosons, if you assume that two particles must not be at the same place at a given time, which makes sense since the fundamental interactions are singular for two particles meeting at the same space-time point. This is due to the famous paper,
Laidlaw, M. G. G., DeWitt, Cécile Morette: Feynman Functional Integrals for Systems of Indistinguishable Particles, Phys. Rev. D 3, 1375, 1970
Then in the relativistic case, you assume that relativistic QT is described by local, microcausal QFTs with a stable ground state. From the representation theory of the Poincare group then you can deduce that fields with integer spin have to be quantized as bosons (equal-time commutator relations) and such with half-integer spin as fermions (equal-time anticommutator relations). This is known as the spin-statistics theorem. Another conclusion is that despite symmetry under the proper orthochronous Lorentz group (i.e., the subgroup continuously connected with the group identity) also the discrete operation, CPT (charge conjugation, followed by space reflections (parity) and time reversal) is necessarily a symmetry. It is proven that the weak interaction breaks P, T, and CP (each measured independently now!).
You need Grassmann numbers for the path-integral of fermions, because to derive the path integral, you have to introduce coherent states for fermions, and you cannot have usual c-number eigenvalues for anticommuting fields, because this would lead to a contradiction. Also the path integral would not give the correct result for fermions, when you'd use usual (real or complex) "field eigenvalues".
Likes Trifis and dextercioby
This is a very nice answer, thank you!
I would appreciate it if you could clarify some points though.
So the spin-statistics theorem can be derived, using ONLY the Poincare group representation theory? Can you provide such a proof?
Naively, one could write [itex] \hat{ψ}(x)|Ψ>=ψ(x)|Ψ> [/itex] with a fermionic field [itex]\hat{ψ}(x)[/itex] acting on some state. Does it make any sense to express the eigenvalue ψ(x) as some kind of combination of complex and grassman numbers? From a mathematical point of view, I cannot imagine how this could be done in a rigorous way, but even physically ψ(x) cannot be a grassman number, since ψ(x) has to be an observable!
What is more, I have never seen a derivation of [itex] \{\hat{a},\hat{a}^†\}=1 [/itex], coming from the representation theory. I was under the impression, that Poincare group does practically determine the spinor part ([itex] u^s(k) [/itex] for particles or [itex] v^s(k) [/itex] for antiparticles) of the fermionic field [tex] \hat{ψ}(x) \sim \hat{a}^su^s(k)e^{-ikx} + \hat{a}^{s†}v^s(k)e^{ikx} [/tex] and has nothing to do with the creation/annihilation operators.
Trifis said:
Hi everyone!
Quantization of any system (of fields) is based upon Schrodinger equation [tex]i \partial_{t} | \Omega \rangle = \int d^{3} x \ \mathcal{H} ( \Psi , \Pi ) | \Omega \rangle ,[/tex] together with an equal-time operator algebra which, for fermion fields, is given by the following anti-commutation relations [tex]\{ \Psi_{\alpha} ( t , \vec{x} ) , \Pi^{\beta} ( t , \vec{y} ) \} = i \delta_{\alpha}^{\beta} \delta^{3} ( \vec{x} - \vec{y} ) ,[/tex] [tex]\{ \Psi_{\alpha} ( t , \vec{x} ) , \Psi_{\beta} ( t , \vec{y} ) \} = \{ \Pi^{\alpha} ( t , \vec{x} ) , \Pi^{\beta} ( t , \vec{y} ) \} = 0 .[/tex] The coordinate Schrodinger representation of the equal-time operator algebra is given by [tex]\Psi_{\alpha} ( 0 , \vec{x} ) | \psi \rangle = \psi_{\alpha} ( \vec{x} ) | \psi \rangle ,[/tex] [tex]\langle \psi | \Pi^{\alpha} ( 0 , \vec{x} ) | \tilde{\psi} \rangle = i \frac{\delta}{\delta \psi_{\alpha} ( \vec{x} )} \delta ( \psi - \tilde{\psi} ) .[/tex] Note that [itex]\Psi ( 0 , \vec{x} )[/itex] is an operator (the time-independent field/coordinate operator), while [itex]\psi ( \vec{x} )[/itex] is a time-independent field function (i.e., a “classical” field). Since the field operator [itex]\Psi ( 0 , \vec{x} )[/itex] squares to zero, its eigen-values, [itex]\psi ( \vec{x} )[/itex] must be spinors of anti-commuting components, [itex]\psi^{2}_{\alpha} ( \vec{x} ) = 0[/itex], i.e., functions taking values in the Grassmann algebra. Thus, quantization requires the “classical” spinor fields to be Grassmann-valued functions on space-time. However, like any other classical field on space-time, the classical Dirac field is defined to be a cross-section of the vector bundle [itex]E^{\omega}[/itex] (over [itex]\mathbb{R}^{(1,3)}[/itex]) associated with the Dirac representation, [itex]\omega ( r , \vec{p} ) \in ( 0 , 1/2 ) \oplus ( 1/2 , 0 )[/itex], of [itex]SL ( 2 , \mathbb{C} )[/itex] over [itex]\mathbb{C}^{4}[/itex]. In other words, the “classical” Dirac field has the following expansion (at [itex]t = 0[/itex]) [tex]\psi_{\alpha} ( \vec{x} ) \sim \sum_{r = 1}^{4} \int d^{3} p \ b ( \vec{p} , r ) \ \omega_{\alpha} ( \vec{p} , r ) \ e^{ i \vec{p} \cdot \vec{x} } .[/tex]
Some remarks are now in order.
(i) All factors in the expansion are numbers (not operators). It is in this sense we call [itex]\psi ( \vec{x} )[/itex] a classical field function (not operator).
(ii) In order for [itex]\psi ( \vec{x} )[/itex] to be the eigen-value of the field operator [itex]\Psi ( 0 , \vec{x} )[/itex], the number [itex]b ( \vec{p} , r )[/itex] must be a Grassmann number, [itex]b^{2} = 0[/itex]. Notice that this Grassmannian nature is not implied by the above definition of classical fields for the ordinary Lorentz group on the ordinary (not super) space-time. However, the classical Dirac field is Grassmannian in the representation theory of super-Lorentz group on super-space.
(iii) The plane wave expansion of the Schrodinger field operator is obtained by promoting [itex]b \to \hat{b} , \ \mbox{and} \ \psi_{\alpha} ( \vec{x} ) \to \Psi_{\alpha} ( 0 , \vec{x} )[/itex]: [tex]\Psi_{\alpha} ( 0 , \vec{x} ) \sim \sum_{r = 1}^{4} \int d^{3} p \ \hat{b} ( \vec{p} , r ) \ \omega_{\alpha} ( \vec{p} , r ) \ e^{ i \vec{p} \cdot \vec{x} } .[/tex]
(iv) If we expand the time-dependent state vector [itex]|\Omega (t) \rangle[/itex] in the coordinate basis [itex]|\psi \rangle[/itex], the component of [itex]|\Omega \rangle[/itex] in the [itex]|\psi \rangle[/itex] direction is [itex]\langle \psi | \Omega \rangle \equiv \Omega [ \psi ][/itex], which is a number, is called the wave functional. It is the probability amplitude for the field to be in the configuration [itex]\psi ( \vec{x} )[/itex] at time [itex]t[/itex].
(v) The quantization of the free Dirac field can, therefore, be reduced to solving the following Grassmann functional differential equation [tex]i \partial_{t} \Omega [ \psi ] = \int d^{3} x \int \mathcal{D} \ \tilde{\psi} \ \langle \psi | \mathcal{H} ( \Psi , \Pi ) | \tilde{\psi} \rangle \ \Omega [ \tilde{\psi} ] = \int d^{3} x \ \frac{\delta}{\delta \psi ( \vec{x} )} \left( - i \vec{\alpha} \cdot \vec{\nabla} \right) \psi ( \vec{x} ) \ \Omega [ \psi ] .[/tex]
Sam
Likes dextercioby and Trifis
Concerning the spin-statistics theorem: That's a very famous and well-known result by Pauli and Lüders. You find it in any textbook on relativistic QFT. The most comprehensive treatment for particles of any spin can be found in
Weinberg, The Quantum Theory of Fields, vol. 1
For the usual special low-spin cases, you can also find it in my lecture notes:
http://fias.uni-frankfurt.de/~hees/publ/lect.pdf
Further, the field eigenvalues are in general not observables. Particularly the Grassmann-valued eigenvalues of fermion fields do not represent observable values. What's observable are the probabilities encoded in the S-matrix elements and expectation values of observables like energy, momentum, and angular momentum. For free fields the latter are bilinear forms, obeying not anticommutators but commutators. Particularly the operators representing local densities commute at space-like separated arguments (principle of microcausality).
Sam
I think, this makes it clear for me. So, the Grassmanian nature of the fermionic eigenvalues IS NOT an inherent characteristic of the Lorentz group. This, alternatively, means that the Spin-Statistics theorem cannot be derived solely by arguments about the Lorentz spacetime symmetry.
EDIT : It seems that the anticommutation of the fermionic creation/annihilation operators can be derived by Lorentzian spacetime symmetry considerations and thus the anticommutating nature of their eigenvalues, namely the Grassman numbers, IS in a way a consequence of the ordinary Lorentz group.
Moreover, I did enjoy your presentation of the Dirac field eigenvalues as having both spinor and grassmanian parts in their expansion. It was more or less, what I pictured in post #4, but I had my doubts how this could be expressed in a rigorous mathematical way.
Ok, so field operators after the second quantization do not follow the basic axioms of 1-particle QM. There must be a lot of mathematical subtleties in this one, but let us not go off-topic.
There's no second quantization. Quantum field theory is just many-body quantum theory in Fock-space representation. The spin-statistics theorem is not based on fermionic coherent state representations but follows under the assumption of a microcausal local relativistic QFT with stable ground state. These assumptions also imply that in addition to the symmetry under proper isochronous Poincare transformations the discrete CPT transformation is also a symmetry (Pauli-Lüders theorem).
Yes, and the fact that operators are no longer observables in this many-body QM context, makes me think that the basic Dirac-von Neumann axioms do no longer have to hold.
I've done some reading on the proof of the spin-statistics theorem. It seems that the basic assumption is indeed the Lorentz invariance. Of course, there are some additional prerequisites, such as a lower energy bound which is needed to prove the CPT theorem, an essential tool of the proof, propagation with finite mass, localized excitations (microcasuality) etc.
All in all, we are allowed to say that the spinor part of the fermionic eigenvalues comes from the representation theory of the Lorentz group and the grassmanian part comes from the general spacetime stracture, i.e. the spin-statistics theorem.
Of course, spin follows from representation theory of the special orthochronous Poincare group, which is the symmetry group of special-relativistic spacetime. That there is half-integer spin is due to the fact that in quantum theory we look for unitary ray rather than unitary representations. In the case of the Poincare group all these are induced by the unitary representations of the covering group, where the proper orthochronous Lorentz subgroup is substituted by its covering group, which is SL(2,C). There are no non-trivial central charges (as in the case of the Galilei group, where mass is a non-trivial central charge).
The fact that in theories with ##\geq 3## spatial dimensions one has only fermions and bosons (and not more complicated representations of the symmetric group representing symmetry under indistinguishable-particle interchanges, called "anyons", which can occur in 2 spatial dimensions) follows from quite general assumptions on the configuration space of many-particle systems (Laidlav, de Witt Morette). That the integer-spin particles are bosons and half-integer-spin particles fermions follows then from the assumption of a local, microcausal QFT with a stable ground state.
Even in basic QM the operators do not have to be observables. For example, the raising and lowering operators in the harmonic oscillator are not observables. Observanbles are operators, but operators don't have to be observables.
Related to Anticommutation of Fermions and the Lorentz irreps
1. What is the anticommutation rule for fermions?
The anticommutation rule for fermions states that when two fermionic operators, such as creation and annihilation operators, are exchanged, the sign of the wavefunction changes. This is in contrast to bosonic operators, which follow the commutation rule where exchanging operators does not change the sign of the wavefunction.
2. What is the significance of anticommutation in quantum mechanics?
Anticommutation is a fundamental property of fermions in quantum mechanics. It is what allows fermions to follow the Pauli exclusion principle, where no two identical fermions can occupy the same quantum state. This plays a crucial role in determining the behavior of particles in the microscopic world.
3. What are the Lorentz irreps in relation to fermions?
The Lorentz irreps, or irreducible representations, refer to the different ways in which fermions can transform under the Lorentz group, which describes the symmetry of spacetime in special relativity. These irreps are important in understanding the behavior of fermions in different reference frames and their interactions with other particles.
4. How are fermions classified in terms of Lorentz irreps?
Fermions are classified into different Lorentz irreps based on their spin and parity. Spin refers to the intrinsic angular momentum of a particle, while parity refers to its transformation under spatial inversion. Fermions can be classified as either Weyl spinors, Dirac spinors, or Majorana spinors, each with different transformation properties under the Lorentz group.
5. What is the connection between anticommutation of fermions and Lorentz irreps?
The connection between anticommutation of fermions and Lorentz irreps lies in the fact that the anticommutation rule is a fundamental property of fermions, and therefore affects how they transform under the Lorentz group. The anticommutation rule is also used to construct Lorentz invariant quantities, which are crucial in describing the behavior of fermions in relativistic systems.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Differential Geometry
  • Quantum Physics
  • Beyond the Standard Models
