Antiferromagnetic ground state due to superexchange
In summary, the conversation discusses the derivation of a Heisenberg-like spin Hamiltonian and the physical connection between two equalities in the Hamiltonian. The possibility of spin flips and the concept of minimizing the Helmholtz's free energy are also discussed as factors in determining the equilibrium state of the system. The question is raised of whether it would be better to ask the question in a different forum, possibly due to the topic being a combination of quantum mechanics and condensed matter systems.
physlosopher
30
TL;DR Summary
How does a virtual two-step tunneling process explain antiferromagnetic ordering?
Hi all, thanks in advance for your help!
For context, I'm generally new to condensed matter and many-body QM and am working through Altland and Simons' Condensed Matter Field Theory. I'm thinking in general about magnetic ordering.
I've seen a Heisenberg-like spin Hamiltonian derived by starting with a Hubbard Hamiltonian
$$H = -t\sum_{<ij>}a^{\dagger}_{i\sigma}a_{j\sigma} + U\sum_{j}n_{j+}n_{j-}$$
where the first sum is over nearest neighbors. As long as ##U/t >> 1## we can treat the tunneling terms as a perturbation. This gives us something like $$H = -2\frac{t^{2}}{U}(1 + a^{\dagger}_{i\sigma}a^{\dagger}_{j\sigma'}a_{i\sigma'}a_{j\sigma}) = 4\frac{t^2}{U}(\vec{S}_{i}\cdot\vec{S}_{j}-\frac{1}{4})$$
From the first equality, it makes sense to me that this Hamiltonian is accounting for a process in which we essentially flip two spins at sites ##I## and ##j##. Furthermore, because our model only accounts for tunneling which a spin does not change, I think this process has to be one in which one of the spins hops to the neighboring site, and the other hops to the site that was left unoccupied (please correct me if I'm wrong!). The second equality makes it clear to me that the ordering of the ground state will be antiferromagnetic, due to the positive coupling constant.
This is all fine mathematically. I think what I am confused by is the physical connection between these two equalities. I've seen the antiferromagnetic ordering explained as originating from a virtual process in which spins reduce their energy by briefly hopping to a neighboring site. How exactly does the possibility of this process lower the energy of the ground state? Maybe asked another way, why would a ferromagnetic state, in which this virtual process is unavailable due to Pauli exclusion, necessarily raise the energy of the system?
Disclaimer: I'm very far from being able to understand Atland's book, so I didn't really follow the post either. I just wanted to share my thoughts, hoping they make sense.
Well, at equilibrium the energy of the system has to be minimum only if you fix the volume and the entropy. But here you are asking which configuration of spins represents the equilibrium condition, so the entropy is not fixed. If you flip some spins the entropy will generally change. So, in order to find the equilibrium state, it's better to minimize the Helmholtz's free energy ##F##, which requires only to fix the volume and the temperature of the system (but not the entropy). So we should look at the minimum of ##F = E - TS##. So if you flip some spins, ##S## (the entropy) increases and so ##F## decreases. On the other hand ##E## might increase. It's a tug of war between ##E## and ##S## in order to minimize ##F##.
PS: How many times did I just use the word "so"? :rolleyes:
Thank you for the response! However, my question pertains more to quantum mechanics than to which Legendre transform of the energy is being minimized.
Oh sorry, I am a bit tired, I completely misunderstood your question. I though you were asking about a different thing. Sorry I can't help you
Sorry to post again, but does anyone know whether it would be better to ask this question in a different forum?Maybe it's awkward because it's sort of a QFT question about a condensed matter system?
I recommend you read my reply to a related question in the following post:
https://www.physicsforums.com/threads/what-causes-magnetism-at-the-atomic-level.958654/#post-6085949
To quote the most relevant part:
1) Local moment picture/Heisenberg model, (Insulators): Electrons are almost entirely bound to a particular atom, however there exists enough orbital overlap such that some hopping between neighbors can occur. Recall that for a 1D quantum box of length ##L##, the energy is proportional ##L^{−2}##, thus hopping allows electrons to effectively wander through a larger box, thereby reducing the kinetic energy.
Likes physlosopher
I will read your reply to the other post and think a bit, but this is very helpful. Thank you!
Related to Antiferromagnetic ground state due to superexchange
1. What is an antiferromagnetic ground state?
An antiferromagnetic ground state is a type of magnetic ordering in which the magnetic moments of neighboring atoms or ions are aligned in opposite directions, resulting in a net magnetic moment of zero.
2. What is superexchange?
Superexchange is a mechanism for magnetic interactions between atoms or ions in a solid material. It involves the indirect exchange of electron spins through an intervening non-magnetic atom or ion.
3. How does superexchange contribute to the antiferromagnetic ground state?
In an antiferromagnetic ground state, superexchange allows for the alignment of neighboring magnetic moments in opposite directions, resulting in a net magnetic moment of zero. This is due to the exchange of electron spins through non-magnetic atoms or ions.
4. What are some examples of materials with an antiferromagnetic ground state due to superexchange?
Some examples of materials with an antiferromagnetic ground state due to superexchange include manganese oxide (MnO), iron oxide (FeO), and chromium oxide (CrO).
5. How is the antiferromagnetic ground state due to superexchange different from other types of magnetic ordering?
The antiferromagnetic ground state due to superexchange is different from other types of magnetic ordering, such as ferromagnetism and ferrimagnetism, because it involves the alignment of neighboring magnetic moments in opposite directions, resulting in a net magnetic moment of zero. In contrast, ferromagnetism and ferrimagnetism involve the alignment of neighboring magnetic moments in the same direction, resulting in a net magnetic moment that is not zero.
  • Atomic and Condensed Matter
