jaumzaum
- 434
- 33
I was trying to solve the following problem from the Irodov book.
"A vertical cylinder closed from both ends is equipped with an easily moving piston dividing the volume into two parts, each containing one mole of air. In equilibrium at T0 = 300K the volume of the upper part is η = 4.0 times greater than that of the lower part. At what temperature will the ratio of these volumes be equal to η'= 3.0?"
I've first solved the problem the way the book solved it, than I thought this way was wrong and solved another way that gave a close but different result. I would like to know which of them is right, and why is this.
1st way: Be h the altitute of the cylinder. Be S the area. On the first temperature, the altitude of the lower part is x = h/5, and on the second temperature, y = h/4.
PV = nRT
Plower = Pupper + massupper.g
RT0/Sx = RT0/4Sx + Mg
RT0/Sx = 4/3 Mg
And RT/Sy = 3/2 Mg
T = (9/8) (y/x) T0 = 422K
*In the first way (that's the solution of the book) Irodov considered the pressure of the cylinders to be constant at any height . At the second, I've considered the pressure not constant.
2nd way:
Formulas:
P = P0e-Mgh/RT
n = P0S/Mg (1-e-Mgh/RT)
Where P is the pressure in the height h. P0 the initial pressure. n is the total number of moles of gas until height h.
This way, at the first temperature:
Be P0 the pressure at the botton of the lower cylinder. Be P1 the pressure at the piston. Be (1-Mg/P0S) = a
For the lower cylinder.
P0S/Mg (1-e-Mgx/RT0) = 1 mole
e-Mgx/RT0 = a
P1 = P0e-Mgx/RT0
For the upper cylinder.
P1S/Mg (1-e-Mgx/RT0) = 1 mole
P0e-Mgx/RT0S/Mg (1-e-4Mgx/RT0) = 1 mole
(1/(1-a)) a (1-a4) = 1
a4+a³+a²+a=1
By the same reasoning we get b=e-Mgy/RT and b³+b²+b=1
So T = logba y/x T0 = 404K
Which of them are right?
Thanks, John
PV = nRT
RT0/Sx = 4/3 Mg
And RT/Sy = 3/2 Mg
2nd way:
Formulas:
P = P0e-Mgh/RT
e-Mgx/RT0 = a
P1 = P0e-Mgx/RT0
a4+a³+a²+a=1
Thanks, John
