Any good HEAT TRANSFER books out there?
For graduate-level heat transfer studies, several specialized books are recommended. "Heat Conduction" by Necati Ozisik focuses on conduction, while "Convective Heat and Mass Transfer" by Kays covers convection in detail. For radiation, "Radiative Heat Transfer" is a key resource. Additionally, "Heat Transfer" by A. E. Mills serves as a bridge between undergraduate and graduate material. These texts provide a comprehensive foundation for advanced heat transfer concepts.
Jennifer_88
any good HEAT TRANSFER books out there??
Hi,
I am looking for a heat transfer book for Graduate level. i am actually familiar with good undergraduate books like fundamental of heat transfer. please tell me a little bit about whatever book you are recommending
thanks in advance
At the graduate levels, conduction, convection, and radiation are usually broken up into separate books. Here are some that I would recommend for starters:
Conduction: Heat Conduction, Necati Ozisik
Convection: Convective Heat and Mass Transfer, by Kays
Radiation: Radiative Heat Transfer, Modest
"Heat Transfer" by A. E. Mills is a good graduate-ish level book that would generally be a bridge between the undergraduate class and the graduate classes that are broken into cinduction, convection and radiation.
thank you guys.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
