Any one of the integers ## 0, 1, 2, 3, 4, 5, 6, 7, 8, 9 ## can occur?
  • Thread starter Thread starter Math100
    Integers
Any integer can be expressed in terms of its units digit modulo 10, specifically as 0 through 9. The cubes of these integers yield specific units digits: 0, 1, 8, 7, 4, 5, 6, 3, 2, or 9. This demonstrates that any integer from 0 to 9 can indeed be the units digit of a cubed integer. The proof confirms that all integers in this range can occur as the units digit of a^3. Thus, the statement is validated.
Math100
Prove the following statement:
Any one of the integers ## 0, 1, 2, 3, 4, 5, 6, 7, 8, 9 ## can occur as the units digit of ## a^{3} ##.
None.
Proof:
Let ## a ## be any integer.
Then ## a\equiv 0, 1, 2, 3, 4, 5, 6, 7, 8 ##, or ## 9\pmod {10} ##.
Thus ## a^{3}\equiv 0, 1, 8, 27, 64, 125, 216, 343, 512 ##, or ## 729\pmod {10} ##.
Therefore, anyone of the integers ## 0, 1, 2, 3, 4, 5, 6, 7, 8, 9 ## can occur as the units digit of ## a^{3} ##.
Likes Delta2 and fresh_42
That's true.
I think you should still prove the following:
Given two positive integers ##a,n.##
##A.## ##\operatorname{gcd}(a,n)=1##
##B.## There are integers ##s,t## such that ##1=s\cdot a+t\cdot n.##
##C.## There is an integer ##b\in \mathbb{Z}## such that ##a \cdot b \equiv 1 \pmod n.##
Prove that all three statements are equivalent.
Hint: It is sufficient to show ##A \Longrightarrow B \Longrightarrow C \Longrightarrow A## or ##A \Longrightarrow C \Longrightarrow B \Longrightarrow A##
Math100 said:
Homework Statement:: Prove the following statement:
Relevant Equations:: None.
Proof:
Except for 0, 1, and 8, the rest are not numbers modulo 10.
I would write the above as:
Let a be the units digit of some integer. Then a is 0, 1 2, 3, 4, 5, 6, 7, 8, or 9.
##a^3## is one of 0, 1, 8, 27, 64, 125, 216, 343, 512, or 729, respectively.
Then the units digit of ##a^3## is 0, 1, 8, 7, 4, 5, 6, 3, 2, or 9, and the statement is proven.
