Any quotes from verified physicists about superposition?
In summary: It has a particle-like nature, but is not exactly a particle. It has its own nature that is not either of those things, but which we can reduce to those concepts when we need to.In summary, the conversation discusses the extraordinary claims of quantum mechanics and the need for evidence to support them. The moderator suggests reading Giancarlo Ghirardi's "Sneaking a look at God's cards" for a physicist's perspective. The conversation also touches on the Heisenberg Uncertainty Principle and how it challenges our common sense notions. It is noted that QM does not violate these notions, but rather expands our understanding of the nature of
wittgenstein
216
<Moderator's note: Approved. The original thread has been this. The relocation in QM is better suited in case the thread turns into a direction where physical questions are the subject rather than quotations.>
I have heard many astounding things about QM. For example, that particles have no location until measured. However, I would like an actual quote from a validated physicist that before the wave collapses a particle has no specific location and can be anywhere.
I agree with Carl Sagan that extraordinary claims require extraordinary evidence. The claims of QM are extremely extraordinary. I will never understand the math and I know that one should be skeptical of authority but a quote from a big time physicist that confirms that QM violates common sense intuitions such as that an object must have a location will make me realize that Niels Bohr was right when he said, " If quantum mechanics hasn't profoundly shocked you , you haven't understood it yet."
If you're not going to look at the math you're never going to see what QM actually says, or even enough to judge for yourself whether the century of experimental evidence that we've built up is sufficient to justify the counterintuitive claims of the theory.
However, you could give Giancarlo Ghirardi's "Sneaking a look at God's cards" a try. It's written by a real physicist and has the supporting quotes that you're looking for.
So QM is not unusual? That , for example, Bohr's quote has to be seen in context and QM is not really that shocking?
I am beginning to believe that all this QM is different is just way overblown and there is nothing unusual about it. There isn't even one quote that specifically says how QM violates our common sense notions?
wittgenstein said:
The claims of QM are extremely extraordinary...For example, that particles have no location until measured. However, I would like an actual quote from a validated physicist that before the wave collapses a particle has no specific location and can be anywhere.
A specific quoted claim to discuss would make this easier. The actual "claims" of QM are not as extraordinary today simply because they are subject to experimental verification. Consequently, this discussion is really more about enlightening you to the extremely large body of specific tests of QM which have confirmed it within statistical limits.
Particles may have very specific positions at any time. There is nothing that requires anything otherwise. On the other hand, a quantum particle cannot have both a very specific location AND simultaneously a very specific momentum. That's a very simplistic statement of the Heisenberg Uncertainty Principle (HUP). Essentially, knowledge of one precludes knowledge of the other.
The HUP can be demonstrated experimentally in many ways, so there is no stretch required on this. Take a particle with a very specific location. Then measure its momentum. Whoops, now it is lost (!) - i.e. not in its expected location. I'm not sure I would use the phrase "it could be anywhere" to describe its location, but there is definitely no way to predict where it will be found with accuracy exceeding the statistical limits of the HUP.
You wrote, "On the other hand, a quantum particle cannot have both a very specific location AND simultaneously a very specific momentum. " I agree. But that is extraordinary. It is not saying that it is our inability to know both, its that the particle does not have both.
wittgenstein said:
...QM is not really that shocking?
"Shocking" is in the eye of the beholder. Bohr's comments were 80+ years ago. I don't think folks around here "hype" QM too much, it is what it is. For most people, the initial introduction into QM is in fact some degree of "shocking" or "mystifying". But once one gains more knowledge, it becomes familiar and therefore less "shocking".
Do you agree that QM violates our common sense notions, such as something cannot be A and not A? Particle and wave.
It is A ( a particle ) and not A ( a wave)
As far as experiments go, that would be the logical conclusion: "the particle does not have both."
However, there are interpretations of QM that allow both to exist, but they say that the HUP represents a lack of knowledge. So that is considered a viable alternative. The down side of that interpretation - Bohmian Mechanics - is that it requires non-locality (instant interaction of widely separated systems). That may bother you even more. :smile:
I apologize for my ignorance but my understanding is that until measured it is both a particle and a wave.
Neither is also weird! If it is not a particle or a wave , what is it?
I don't agree with that statement about "A and ~A", no. A quantum system is definitely not one or the other, it simply sometimes behaves as if it is one or the other at times. It can be any mixture of particle and wave at other times as well. It can be 90% particle and 10% wave, to make a simplification.
Wave-particle duality is an outdated concept. You can use 'search' button and look up for discussions about it. It's been discussed quite a few times.
Pardon the poor metaphor, so its like a lake with little rubber ducks on it?
That is a simplistic way of expressing it. The HUP states it mathematically... and precisely.
I don't get the analogy. Trying to use metaphors is almost certainly going to keep you in the dark. Go back to Nugatory's wise comment about the math.
Please note that there is no requirement that the mathematical description of the quantum world be reducible to a simple and accurate analogy. The simpler it is, the less accurate it will be.
So we have no idea of what is going on? Sure I can talk about the square root of negative one and actually calculate with it. Do I understand what it is? Of course not! Imaginary numbers are useful but we have no idea how such a paradoxical thing can be.
You wrote, "The actual "claims" of QM are not as extraordinary today simply because they are subject to experimental verification." I have no doubt that QM has been experimentally verified. Similarly, I would still be astonished if it was proven that square circles exist on the subatomic level. Actually my sense of wonder would be increased rather then diminished.
There is nothing paradoxical about imaginary and complex numbers in general...
Again, that is not accurate from a scientist's perspective because the mathematical description *is* there.
When you ask "what is happening beyond where we can see" you are basically answering your own question...
The square root of negative 1 is incomprehensible because it is paradoxical. If the square root of -1 is negative, a negative times a negative is positive. If it is positive , a positive times a positive is a positive. How can we comprehend a number that is not positive, negative or zero?
Sure I can postulate square circles and might even be able to develop a whole geometry based on the idea that square circles exist. . But do I really know what a square circle is?
Suppose QM was based on square circles ( I know it isn't ) and a whole math was designed around the idea that square circles exist. Suppose I totally understand all that square circle math. Would I understand QM? My contention is , "no".
Hi wittgenstein,
It's both, it's neither. It's complicated. :smile:
(and so then it may follow you may consider QM to be weird, which is an opinion. :smile:)
Well, it's complicated only if we insist things must be either particles or waves.
Personally I view them* as quantum objects that behave according to the laws of quantum mechanics.
* The things we in physics often just call particles, e.g. electrons, protons, neutrons etc.
Paraconsistent logic ( https://en.wikipedia.org/wiki/Paraconsistent_logic BTW I wanted the Stanford encyclopedia of philosophy but it is down ) ) was designed as a response to quantum reality. It was designed to contain quantum reality to the sub-atomic level. If quantum level weirdness applied to the macro level then my feet are 3 miles long etc ( https://en.wikipedia.org/wiki/Principle_of_explosion ) Suppose I understand how to apply paraconsistent logic. Do I understand how A and -A can both be true? My contention is , no. I do not understand paraconsistent logic even if I know how to use it. Similarly, if I understand the math behind QM, do I understand QM? My contention is , no. That is why I want a quote from a major physicist that shows that the principles of QM are truly common sense destroying. Note, that I am not questioning the reality of quantum reality. I am asking for a quote from a knowledgeable physicist ( like Bohr's quote, yet with a particular example ) that says that QM is truly paradigm destroying.
Ok.
I understand. I am thinking about it. :biggrin:
No, it isn't. Complex numbers are perfectly consistent mathematically. Claims like this will get you a warning for misinformation.
You should not be looking for quotes, from "knowledgeable physicists" or anyone else. You should be looking at what QM actually says--the math, as @Nugatory told you early in this thread--and how it compares with experiment. Science does not work by quoting authorities. It works by constructing models that make accurate predictions.
This thread is closed.
Likes weirdoguy
Related to Any quotes from verified physicists about superposition?
1. What is superposition in physics?
Superposition in physics is a principle that states that a physical system can exist in multiple states or configurations simultaneously. This means that a particle can exist in two or more places at once, or have multiple values for certain properties like spin or energy.
2. How does superposition relate to quantum mechanics?
Superposition is a fundamental concept in quantum mechanics. It explains the behavior of subatomic particles, such as electrons and photons, which can exist in multiple states at the same time. This is in contrast to classical mechanics, where an object can only exist in one state at a given time.
3. What did renowned physicist Richard Feynman say about superposition?
In his famous lectures on quantum mechanics, Richard Feynman described superposition as "the heart of quantum mechanics". He also stated that "no one has ever been able to define the difference between interference and superposition satisfactorily."
4. How is superposition observed in experiments?
Superposition can be observed in experiments such as the double-slit experiment, where a single particle is sent through two slits and creates an interference pattern on a screen. This demonstrates that the particle exists in multiple states at once, and only collapses into a single state when it is observed or measured.
5. Can superposition be applied to macroscopic objects?
While superposition is primarily observed in the quantum world, there have been recent experiments that demonstrate its effects on larger objects. For example, a group of researchers at the University of Vienna were able to place a molecule that contains over 800 atoms in a superposition state. However, the effects of superposition on macroscopic objects are still not fully understood and are an active area of research in physics.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Sticky
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
