Anybody know how the x-zylo toy works? yours truly, physics noob
In summary, the x-zylo toy is known to fly over 200 yards and is a combination of an airfoil and gyro. The gyroscopic effects help maintain its orientation while the airfoil shape creates a low pressure area in the center of the toy. It works similar to a frisbee but with the axis of rotation parallel to the angle of attack. There is still debate on the exact impact of the gyro and air pressure on the flight of the toy.
robhlee
52
Hey surely you guys have heard of the x-zylo toy?
Its a toy that has been known to fly 200+ yards.
If you don't know about about it, do a google search on it.
How does it work?
also, are there any equations for the aerodynamic force and such?
Interesting technology. A sideways frisbee.
The only thing that comes to mind is that it is a combination airfoil and gyro. The gyroscopic effects help to maintain it's longitudinal axis in the orientation it was in when it was thrown. The airfoil shape, I would think, would have the camber facing towards the center of rotation to produce a low pressure area in the center of the toy. It is a pretty cool idea. That site's video is impressive.
Yes, in a nutshell, the gismo is an airfoil that is kept pointing in the right direction gyroscopically. Same principles as a frisbee, only the axis of rotation for gyroscopy is parallel to the angle of attack rather than perpendicular.
well, i knew about the gyro, but does the lowered air pressure pull the x-zylo forward or lift it? or both?
I have read somewhere that there is a special synergistic system going on between the gyro and air pressure that is still without general consensus.
The reason why i ask about whether its pulled or lifted is that in my aerodynamically novice head, the simple one-wing bernoulli diagram of lift is being applied at all parts of the cylinder, so the net force would be zero. So is the low pressure pulling it forward? please clarify.
Related to Anybody know how the x-zylo toy works? yours truly, physics noob
1. How does the x-zylo toy fly and spin in the air?
The x-zylo toy uses the principles of aerodynamics to fly and spin in the air. When thrown, it creates lift and also has a gyroscopic effect due to its shape and weight distribution, allowing it to maintain a stable flight and spin.
2. What makes the x-zylo toy different from other flying toys?
The x-zylo toy is unique in its design and construction. It is made of lightweight materials and has a patented aerodynamic shape that allows it to fly up to 600 feet in the air. Additionally, its ability to spin adds an extra level of fun and excitement.
3. How does the x-zylo toy achieve such a long flight distance?
The x-zylo toy's aerodynamic design and lightweight materials contribute to its long flight distance. When thrown at the correct angle and with enough force, it can reach distances of up to 600 feet. Its ability to maintain a stable flight also helps in achieving this distance.
4. Is the x-zylo toy safe for children to use?
Yes, the x-zylo toy is safe for children to use. It is made of lightweight and durable materials, making it safe for both indoor and outdoor play. However, it is always recommended to supervise children while playing with any toy.
5. Can the x-zylo toy be used in windy conditions?
The x-zylo toy can be used in moderate wind conditions. However, too much wind can affect its flight and make it difficult to control. It is best to use the x-zylo toy in calm weather conditions for optimal performance.
  • Mechanical Engineering
  • STEM Career Guidance
  • Beyond the Standard Models
  • STEM Academic Advising
  • New Member Introductions
