Anyone here know how a ranque hilsch vortex tube works?
In summary, the vortex tube is a highly complex and still not fully understood phenomenon. It operates by creating a vortex from compressed air and separating it into two air streams - one hot and one cold. The temperature separation is caused by a combination of factors such as acoustic streaming, energy conversion, and turbulence effects. While there have been many theories proposed, a single unifying explanation for the Ranque-Hilsch effect has yet to be found and remains a hot topic of research. The efficiency and capabilities of the vortex tube are affected by the cold fraction and can be optimized for various cooling applications. Overall, the physics behind the Ranque-Hilsch vortex tube is still an area of ongoing study and investigation.
iScience
466
if you have a reference for someone with a semester of thermo (as opposed to a grad student with 3 semesters), a link would be appreciated .
meanwhile, a quick question: temperature, as determined by one of its factors for gases, translational kinetic energy, follows a Planck distribution. but with the way this separates hot and cool air, are the kinetic energy distributions of the separated air more or less constant ? I'm referring to the moment after they are separated.
If you can believe this graduate engineering student who goes to Berkeley it looks like it is still a "hot topic of research".
" 5 Summary
It is nearly impossible to explain and predict the phenomenon inside the vortex tube. Kurosaka believed that acoustic streaming produces the total temperature separation within the vortex tube. However, he does not mention any energy conversion effects. Ahlborn, et al. concluded that the conversion of kinetic energy into heat explains the Ranque-Hilsch effect, but no explanation of vortex whistle or turbulence effects was made. Furthermore, numerical analyses are highly dependent on the turbulence model used to create simulations. Studies confirmed some of the earlier observations, but the numerical data still do not completely explain the temperature separation. This author believes that a combination of the many observations may be able to explain why the vortex tube induces a radial temperature separation. It may be concluded that acoustic streaming, energetics, turbulence effects, etc. are somehow connected with each other, but the missing links are yet to be found. The conclusions presented here have not been entirely refuted, but the single unifying theory that accounts for the Ranque-Hilsch effect is still a hot topic of research."
From,
http://www.me.berkeley.edu/~gtdevera/notes/vortextube.pdf
From,
https://www.google.com/search?q=how...=Dd46VcasO-2xsASWi4DwBw&ved=0CAYQ_AUoAA&dpr=1
Also see,
http://www.newmantools.com/vortex.htm#vortex
From link,
Operation
Any fluid that flows and rotates about an axis such as a tornado, is called a vortex. A vortex tube creates a vortex and separates it into two air streams-one hot and one cold. Figure 1 shows how a vortex tube works. Compressed air enters a cylindrical generator which is proportionately larger than the hot (long) tube. The generator causes the air to spiral. The spiraling air is forced down the inner walls of the hot tube at speeds reaching 1,000,000 rpm. At the end of the hot tube, a small portion of this air exits through a needle valve as hot air. The remaining air is forced back through the center of the incoming air stream but at a slower speed. The heat in slower moving air is transferred to the faster moving incoming air. This super-cooled air flows through the center of the generator and exits through the cold air exhaust port.
Temperature Separation Effects
The Vortex Tube Creates two types of vortices: free and forced. In a free vortex (like a whirlpool) the angular velocity of a fluid particle increases as it moves toward the Center of the vortex-that is, the closer a particle of fluid is to the center of a vortex, the faster it rotates. In a forced vortex, the velocity is directly, proportional to the radius of the vortex-the closer the center, the slower the velocity.
In a vortex tube, the outer (hot) air stream is a free vortex. The inner (cold) air stream is a forced vortex. The rotational movement of the forced vortex is controlled by the free vortex (hot air stream). The turbulence of both the hot and cold air streams cause the layers to be locked together in a single, rotational mass.
The inner air stream flows through the hollow core of the outer air stream at a slower velocity than the outer air stream. Since the energy is proportional to the square of the velocity, the cold air stream loses its energy by heat transfer. This allows energy to flow from the inner air stream to the outer air stream as heat creating a cold inner air stream.
Cold Fraction
The percentage of total input air volume released through the cold air exhaust of a Vortex Tube is called the Cold Fraction. A valve located in the hot air exhaust of the Vortex Tube controls the Cold Fraction. For example, if the total compressed air input is 15 SCFM (424.5 SLPM) and the Cold Fraction is 70%, the amount of air exiting the cold end wilt be 10.5 SCFM (297.2 SLPM); 4.5 SCFM (127.4 SLPM) exits the hot end.
Cold Fractions of 60-80% produce maximum efficiency-greatest power (BTUH) output- and are ideal for cooling machining operations, electrical controls and enclosures, liquid baths and workers. Low Cold Fractions (less than 50%) have reduced airflows and produce the lowest temperatures for cooling glass, laboratory experiments and for testing electronic components.
The following might be a better explanation, but hardly simple as you wanted,
http://mtp.phys.tue.nl/publications/2012/LZKM12/PublicationPRL.pdf
Related to Anyone here know how a ranque hilsch vortex tube works?
1. How does a Ranque-Hilsch vortex tube work?
A Ranque-Hilsch vortex tube is a device that separates compressed gas into hot and cold streams without any moving parts. It works by creating a vortex flow in the tube, which separates the high-energy molecules (hot air) from the low-energy molecules (cold air).
2. What is the purpose of a Ranque-Hilsch vortex tube?
The purpose of a Ranque-Hilsch vortex tube is to provide a simple and efficient way to separate compressed gas into hot and cold streams, without the need for any external power source or moving parts. It has various industrial applications, such as cooling electronic components and separating gases in chemical processes.
3. How is the temperature of the hot and cold streams controlled in a Ranque-Hilsch vortex tube?
The temperature of the hot and cold streams in a Ranque-Hilsch vortex tube can be controlled by adjusting the position of the control valve, which regulates the amount of compressed gas entering the tube. The temperature difference between the hot and cold streams can also be controlled by adjusting the length and diameter of the tube.
4. What are the advantages of using a Ranque-Hilsch vortex tube?
There are several advantages of using a Ranque-Hilsch vortex tube, including its simplicity, efficiency, and lack of moving parts. It also does not require any external power source, making it a cost-effective and environmentally friendly option. Additionally, it is a versatile device that can be used in various industrial applications.
5. Are there any limitations to using a Ranque-Hilsch vortex tube?
While the Ranque-Hilsch vortex tube has many advantages, there are also some limitations to consider. For example, the temperature difference between the hot and cold streams is limited, and the tube can only operate within a certain range of gas pressures. Additionally, the exact performance of the tube may vary depending on the gas being used and the specific design of the tube.
  • Mechanical Engineering
9K
  • Electromagnetism
  • Thermodynamics
  • Thermodynamics
