AP French Relativity chapter 3 problem
  • Thread starter Thread starter ka_reem13
    Ap Relativity
The discussion centers on solving a problem related to the relativistic Doppler shift in the context of a star's motion. Participants note that the problem may not require relativistic equations since the star's speed is significantly less than the speed of light. Instead, it suggests deriving the velocity function of the star over time and determining when light emitted from the star reaches Earth. The emphasis is on calculating the time of emission based on the star's velocity and the speed of light. Understanding these concepts is crucial for accurately addressing the problem.
ka_reem13
the question is contained in my attempt at a solution as I can't add images anywhere else
I assume we will have to use the relativistic doppler shift in order to find our answer, but that's all I can really gather from how to attempt this
ka_reem13 said:
Relevant Equations:: I assume we will have to use the relativistic doppler shift in order to find our answer, but that's all I can really gather from how to attempt this
I think French wants you to assume that the speed of light depends on the motion of the source. In which case, you cannot use the relativistic Doppler shift, but have to calculate the shift for yourself.
This problem does not require any results from relativity. The star's speed is much less than the speed of light. Consider the following:
(1) What is the function ##v_r(t)## that expresses ##v_r## as a function of time ##t## and the orbital period ##T##? For convenience, choose ##t = 0## when the star is farthest from the earth.
(2) Suppose someone on earth at an arbitrary time ##t## observes light from the star. At what earlier time ##t_0## was this light emitted from the star under the assumption that the light travels from the star to earth at speed ##c+v_r(t_0)##? Express ##t_0## in terms of ##t##, ##R##, ##c##, and ##v_r(t_0)##.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
