Ap physics 1 velocity center of mass question
In an inelastic collision, adding mass to one block does affect the center of mass (CM) velocity of the system. The discussion highlights a scenario where a disk collides with a block, illustrating that the CM velocity depends on the masses and velocities of the colliding objects. Two cases are presented to demonstrate how the CM velocity remains constant before and after the collision, despite changes in mass distribution. The key takeaway is that while the CM velocity can change with mass adjustments, it remains consistent during the collision itself. Understanding these principles clarifies the relationship between mass, velocity, and the center of mass in collision scenarios.
ldkdkdjdj
Can anyone explain how if you add mass to one block colliding with another in an inelastic system, the center of mass velocity of the system changes? Doesn’t the center of mass velocity of a system only change if there is a net external force? In that case the force are equal and opposite, so center of mass velocity of the system doesn’t change, no?
Idk
Idk
Does it? Perhaps you need to define the situation more clearly.
From the 2021 physics 1 test:
(c) The disk is now moving at a constant speed v on the surface (frictionless) toward a block of mass Mg, which is at rest on the surface, as shown above. The disk and block collide head-on and stick together, and the center of mass of the disk-block system moves with speed Vcm
i. Suppose the mass of the disk is much greater than the mass of the block. Estimate the velocity of the center of mass of the disk-block system. Explain how you arrived at your prediction without deriving it mathematically.
It seems that you are confusing the constancy of the velocity of the CM during a collision with the dependence of the velocity of the CM on the velocity and mass of the colliding objects. For example
Case I
You have equal masses 6 kg each moving towards each other at 2 m/s. The velocity of the center of mass is $$V_{cm}=\frac{6~(\text{kg})\times 2~(\text{m/s})+6~(\text{kg})\times (-2)~(\text{m/s})}{6~(\text{kg})+6~(\text{kg})}=\frac{12~(\text{kg}\cdot\text{m/s})-12~(\text{kg}\cdot\text{m/s})}{12~(\text{kg})}=0~\text{m/s}.$$Case II
You move 2 kg from one mass to the other keeping the velocities the same. The velocity of the center of mass is $$V_{cm}=\frac{8~(\text{kg})\times 2~(\text{m/s})+4~(\text{kg})\times (-2)~(\text{m/s})}{6~(\text{kg})+6~(\text{kg})}=\frac{16~(\text{kg}\cdot\text{m/s})-8~(\text{kg}\cdot\text{m/s})}{12~(\text{kg})}=\frac{2}{3}~\text{m/s}.$$Of course, in each case the velocity of the center of mass after the collision is the same as before the collision. Here you are asked to estimate the velocity of the CM if most, i.e. almost all but not quite, of the mass is moved from one object to the other.
Ohh that makes more sense now, tysmm
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
