AP Physics Help (Ski-er on Slope)
The discussion focuses on solving physics problems related to a skier on a slope and the dynamics of a block tied to a hanging block over a pulley. For the skier problem, participants highlight the importance of resolving the skier's weight into components to find the acceleration down the slope, which is proportional to gravity. There is confusion regarding the second problem due to insufficient information and too many unknowns, particularly in determining the mass of the skier. Participants emphasize that the static friction coefficient must be compared with the tension in the rope to ascertain whether the block is sliding. Overall, the thread illustrates the challenges of applying physics concepts to real-world scenarios and the need for clear problem statements.
weiseguy
1. http://sites.google.com/site/startngovr/
2. \SigmaF = \Sigmam*a
F_{k}=\mu*N
X_{f} = 1/2 at^{2}
V_{f} = at
For problem 1 we think the answers are as followed:
\mu_{s} does not = 0.2
a = 5.32m/s^{2}
For problem 2 we have no idea what to do. We have too many unknowns. We believe it is not enough info.
For problem 3, we didn't finish, but with what we did have we wound up with a negative velocity, which isn't the case correct? We solved for acceleration to be -150m/s^{2}. We then found time to = .023094 seconds. Using that information, we found velocity to be (-150)(.023094) = a negative value. This cannot be true can it?
If that is the sliding block tied to a hanging block with a line over the pulley, then one has enough information.
Part of the problem is to determine if μs is sufficient to maintain a static system, so one has to determine if the tension in the rope, T, is < or > than the friction force for μs = 0.2.
If the tension is > than the static friction force, then the block must be sliding, and so one has to determine the acceleration of both blocks, in which case one has to consider the mass of both blocks, which accelerate together.
Yes we know that. We actually have that one done. Problem 2 is the skier on the slope.
One can resolve the weight of the skier and the friction, which is proportional to the weight, so once can determine the downhill (parallel to the incline) acceleration which is proportional to g.
Resolve the weight into normal force on incline and forces parallel to incline (friction up the incline and accelerating force down the incline).
Here's a nice reference - http://hyperphysics.phy-astr.gsu.edu/hbase/N2st.html#c2
Ummm...what?
I don't understand how to deduce the weight/mass of the skier still.
Bump, its due tomorrow!
weiseguy said:
Ummm...what?
Weight is a force, and W = mg, where g is the acceleration (also a vector). Gravity always points down, but on an incline, the weight vector can be resolved into two components, one normal to the surface of the incline and the other parallel.
yes, I understand finding the 2 components of gravity in both the horizontal and vertical, but I do not have a mass to multiply the acceleration due to gravity by.
mg means mass*9.8 :P
