AP physics MOTION questions looking for help
In summary, the conversation is about a student asking for help with several physics problems, specifically regarding velocity, acceleration, and projectile motion. The person responding reminds the student that they are an expert summarizer and will not do the work for them. They also provide some tips and hints for solving the problems.
r3dxP
hi, i am having problems on these questions below.. if you can spend some time doing these and help me, it will be greatly appreciated. If you get a chance, showing the work won't hurt :)
1. In 1940, Emanuel Zacchini flew about 53 m as a human cannonball, a record that remains unbroken. His initial velocity was 24.2 m/s at an angle theta. What is the maximum height h Emanuel achieved during the record flight? (Ignore air resistance.)
3.
A. If the position of a particle is given by x = 20t – 5t2, where x is in meters and t is in seconds, when, if ever, is the particle’s velocity zero?
B. When is its acceleration zero?
C. When is a negative?
4. A hot air balloonist drops an apple over the side while the balloon is accelerating upward at 4.0 m/s2 during liftoff.
A. What is the apple's acceleration once it is released?
B. If the velocity of the balloon is 2 m/s upward at the instant of release, what is the apple's velocity then?
5. A stone is thrown horizontally from the top of a 24 m tower. It hits the ground 18 m from the base of the tower.
A. What is the initial velocity of the stone?
B. When is the velocity of the stone just before it hits the ground?
6. A projectile is launched with an initial speed of 30 m/s at an angle of 60o above the horizontal. Calculate the magnitude and direction of its velocity
A. at 2.0 s after launch.
B. at 5.0 s after launch.
7.A brick is thrown upward from the top of a building at an angle of 25o to the horizontal and with an initial speed of 15 m/s. If the brick is in flight for 3.0 s, how tall is the building?
9. A rocket is launched at an angle of 53.0o above the horizontal with an initial speed of 100 m/s. It moves for 3.00 s along its initial line of motion with an acceleration of 30.0 m/s2. At this time its engines fail and the rocket proceeds to move as a projectile.
A. What is the maximum altitude reached by the rocket?
B. What is its total time of flight?
C. What is its horizontal range?
10. A car is parked on a cliff overlooking the ocean on an incline that makes an angle of 24.0o below the horizontal. The negligent driver leaves the car in neutral, and the emergency brakes are defective. The car rolls from rest down the incline with a constant acceleration of 4.00 m/s2 for a distance of 50.0 m to the edge of the cliff. The cliff is 30.0 m above the ocean.
A. What is the car’s position relative to the base of the cliff when the car lands?
B. How long is the car in the air?
if you know any of these, any help will be greatly appreciated :) thanks in advance.
We are willing to help you, not do the work for you, so tell us about your attempts and explain why you are having problems with a specific problem.
As far as question 3 is concerned you need do differentiate the equation once w.r.t. time to get the equation for the velocity as a function of time. Differrentiating it again will give you the acceleration of the object as a function of time.
4a is an easy "recognize the concept" question that involves no calculation.
So is 4b!
FAQ: AP physics MOTION questions looking for help
What is the difference between speed and velocity?
Speed is a scalar quantity that refers to how fast an object is moving, while velocity is a vector quantity that refers to both the speed and direction of an object's motion.
How do I calculate average velocity?
Average velocity is calculated by dividing the total displacement of an object by the total time taken. This can be represented by the formula v = Δx/Δt, where v is the average velocity, Δx is the change in position, and Δt is the change in time.
What is acceleration and how is it related to velocity?
Acceleration is the rate of change of velocity. It is a vector quantity that refers to how much an object's velocity changes over a certain period of time. Acceleration can be found by dividing the change in velocity by the change in time, represented by the formula a = Δv/Δt.
How does Newton's laws of motion apply to AP physics motion questions?
Newton's laws of motion are fundamental principles that govern the behavior of objects in motion. They are often used to solve AP physics motion questions, as they provide a framework for understanding the relationship between forces, mass, and acceleration.
How can I improve my problem-solving skills for AP physics motion questions?
Practice is key when it comes to improving problem-solving skills for AP physics motion questions. Make sure to thoroughly understand the concepts and equations involved, and try working through a variety of practice problems to build your skills and confidence.
