RustyComputer
- 5
A 2-kilogram block slides down a 30 degree incline as shown above with an acceleration of 2 meters per second squared. The magnitude of the frictional force along the plane in most nearly:
Then some multiple choice answers.
F=ma
So the first thing I did was draw a free body diagram, with all three forces present. Force of friction going opposite of the direction the box is going, normal force perpendicular from the surface, and mass times gravity going straight down.
Then I tilted the diagram 30 degrees, to make the force of friction and normal force straight vertical and horizontal and put mg at an angle of 30 degrees to the left from it's initial point.
After that, I made a right triangle to find the horizontal and vertical components of mg, and wrote mg as the hypotenuse, mg_x as the horizontal component, and mg_y as the horizontal component.
Then here are the equation stuff I did.
F_f - mg = ma
F_f = ma + mg_x
F_f = ma + mgsin30
F_f = m (a + gsin30)
Then I plugged everything in,
F_f = 2(2+9.8sin30)
And came up with the answer
F_f = 13.8
But the problem is that there are no answers close to my solution with the given. So what I would like to know for this problem is, where did I go wrong?
