MHB Ap1.3.51 are complex numbers, show that
The discussion focuses on proving two properties involving complex numbers, specifically that the conjugate of a product and the conjugate of a quotient can be expressed in terms of the conjugates of the individual numbers. Participants clarify that the bar notation represents the complex conjugate. The initial expressions provided are corrected to reflect the proper mathematical relationships. The conversation emphasizes the need for algebraic manipulation to derive the results. Understanding these properties is essential for working with complex numbers in mathematical proofs.
karush
MHB
$\textsf{ If $z$ and $u$ are complex numbers, show that}$
$$\displaystyle\bar{z}u=\bar{z}\bar{u}
\textit{ and }
\displaystyle \left(\frac{z}{u} \right)=\frac{\bar{z}}{\bar{u}}$$ok couldn't find good example on what this is
and I'm not good at 2 page proof systemsso much help is mahalo
Mathematics news on Phys.org
I would begin with:
$$u=x_u+y_ui$$
$$z=x_z+y_zi$$
And the see where the algebra leads. :)
MarkFL said:
I would begin with:
$$u=x_u+y_ui$$
$$z=x_z+y_zi$$
accually what does the bar over mean
That means "the conjugate of." And so, using my prior definitions:
$$\overline{u}=x_u-y_ui$$
$$\overline{z}=x_z-y_zi$$
\textit{ and }
There are some bars missing. I think that the problem should be asking you to show that $$\bar{z}u=\overline{z\bar{u}}
\text{ and }
\overline{\left(\frac{z}{u} \right)}=\frac{\bar{z}}{\bar{u}}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
